  1. Mar 15, 2021 at 6:44 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
  2. Mar 15, 2021 at 6:57 PM
    tvterry
    tvterry Active Member
    In the Hills of WV
    2024 Underground- Tacoma SR5- 4X4- DCSB
    I live in Harrison County. Just about in the north central part of the state. This is the first tonneau style cover I have had on a truck. I had cab high shells on 3 of my trucks. a 71 F100, a 77 F150, and a 91 Isuzu. They were all metal caps. Bought all trucks new. My Tacoma's were a 2007, 2013, and my 2020 SR. Yes, my birthday was good. I woke up above ground, and so far I still am.....LOL
  3. Mar 15, 2021 at 7:01 PM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    Got a case of wool wax and an application kit is spray,can trigger and a tube with some spray jets on it.... Goin on ....on a nice hot day....
    JDSmith and rgljr831 like this.
  4. Mar 15, 2021 at 7:14 PM
    CreekCrawler
    CreekCrawler Well-Known Member
    Erik
    2019 SSM TRD Sport
    Like that fridge slide. How was the install? Bolt through the bed? Backer plate needed? See that you did a cutout on the bed mat.
    Been thinking about a fridge slide for my Yeti 65. Between the bed mat and the cooler feet/weight, that thing is a PITA to “slide” in and out under the tonneau cover.
  5. Mar 15, 2021 at 7:17 PM
    speedlimitz
    speedlimitz Well-Known Member
    Cave creek, Arizona
    2019 cement trd off-road 4x4
    New wheels mounted up.
    Soddy Taco, Shayne, TnTHicks and 43 others like this.
  6. Mar 15, 2021 at 7:19 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Super simple. Four SS hex bolts, just large enough to fit through the rack and into the case with just enough room for the nuts. Used two larger than average washers per bolt, and nylock nuts so they won’t vibrate loose. Laid the case on top of the racks exactly where I wanted it to sit, then went underneath the rack with a sharpie and marked straight lines along the bottom of the case through the slits in the racks then drilled the four holes where I wanted them along the marked lines. Worked out perfectly.
    This case is temporary or I would’ve also added silicone around the bolts. I will when I mount the permanent case. I would’ve used carriage bolts but I couldn’t find any the right size at the time. I will when I mount the permanent case though.
    rgljr831 likes this.
  7. Mar 15, 2021 at 7:50 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Turn phone sideways.
    Tap “rollbar” on my build thread links.
    Happy to chat if you don’t find good info.
    Couple more views over the years
  8. Mar 15, 2021 at 7:56 PM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2016 Blazing Blue TRD Sport DCSB 4x4
    Quick side bar on "bright" colored vehicles:
    Several years ago, I went to a 9-1-1 training class. The trainer was a former dispatcher from the Jackson, Mississippi area. She kept some tapes that were obviously for training purposes. She plaid a tape of a bank robbery from the Jackson area. The get-away car was YELLOW Nissan Xterra. Suffice it to say, the police located the vehicle rather quickly.
    Word to the wise: if you're gonna at least commit a major crime, do it in a vehicle that is rather inconspicuous.
  9. Mar 15, 2021 at 7:58 PM
    playdixie
    Mississippi
    Last pic looks like a tree limb growing out of the truck :rofl:
    TRD-ED, rgljr831 and Cudgel[QUOTED] like this.
  10. Mar 15, 2021 at 8:09 PM
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    Didn't go through all the pages but if no one called dibs on your black one I want it!!
  11. Mar 15, 2021 at 8:18 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Sorry, I’ve already got a guy that wants it and another one after him.
    AbnMP13 and rgljr831 like this.
  12. Mar 15, 2021 at 8:26 PM
    ReelAddict
    ReelAddict Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    Install was pretty easy. Bolts right through the bed. I didn't have to use a backer plate. I bought the Rough County 45L fridge/freezer. It's 17.5" tall, the slide adds another 1/2,", and I should have about 2" of space between the fridge and my tonneau cover.
  13. Mar 15, 2021 at 8:32 PM
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    Mounted the ditch lights (thank you @daleclough), tail-gate theft deterrent and checked the portable compressor. The Husky, your Home Depot $33 special, brought the tire from 19 to 30 lbs pressure in 2-3 minutes. Works for me and cheaper than a Vlair.
  14. Mar 15, 2021 at 8:59 PM
    DanMan611
    DanMan611 Well-Known Member
    Dan
    Hellertown, PA
    2021 DCSB TRD OR 6MT 4X4
    That looks awfully similar to what I did to my truck tonight... :thumbsup: Except I went the K&N route!
    It's the K&N drop-in filter plus the resonator-delete intake tube. I got it for a great price on Amazon; $165 with a $25 off instant savings coupon! I believe that deal is still live (https://www.amazon.com/57-9039-Performance-Air-Intake-System/dp/B081G77CZF). Took all of 10 minutes to install and sounds great! Hopefully the extra 1/2 HP gain will offset the 1" taller tires I just installed. :fingerscrossed:
  15. Mar 15, 2021 at 9:44 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Installed black sequential turn signals and 2021 pro tail lights.
  16. Mar 15, 2021 at 10:35 PM
    Jerry1026
    Jerry1026 Well-Known Member
    Jerry
    PNW
    2019 TRD OR DCSB
    Changed out my fog light bezels and stock fog lights for some Diode Dynamics SS3 Pro fog lights. The light output on these really compliment the Morimoto XB headlights.
    Castle 4, TnTHicks, markram and 11 others like this.
  17. Mar 16, 2021 at 12:02 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    That was the brand- I couldn’t think of it. I have the unholey mount matched with a ram magnetic base. Love it
    Ah it’s basically a well nut. I’m not sure I’d be able to use the wing nut version on my t4r trail wheels but I should add this to my roadside repair kit.
    Only accidentally if your hand is on the knob playing clicky clicky- which is actually quite satisfying. Makes my top 3 list for sure (as a whole with ect and front cam integrated)
    so leather seat covers over your leather seats?
    did you drill new holes in the bed or use the bed bolts? Considering a fridge, maybe a slide but not interested in cutting the mat either
    rgljr831 and TacoMartini[QUOTED] like this.
  18. Mar 16, 2021 at 12:37 AM
    ayobreezie
    ayobreezie Well-Known Member
    Cav Blue TRD Pro
    Which turn signals you order? Looking into that myself. Yours looks how I want it.
  19. Mar 16, 2021 at 6:20 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Happy Birthday!
    tvterry[QUOTED] and rgljr831 like this.
  20. Mar 16, 2021 at 6:27 AM
    str8edgMTBMXer
    str8edgMTBMXer Well-Known Member
    Central Ohio
    2021 SR5 DCLB; midnight black metallic
    awesome!!! I am on it...that is probably going to be the next mod in line...and I will probably be stealing the "Tonka" thing too b/c Tonka's were my first trucks back in the 70s!!!
    Cudgel[QUOTED], dlb97as and rgljr831 like this.
