  1. Apr 1, 2021 at 5:39 PM
    1997tacomav6
    Denver
    Mmmmmm, 1st gen put a virus in the 3rd gen forum I heard
    rgljr831 likes this.
  2. Apr 1, 2021 at 5:44 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    20210401_144440.jpgdefinitely have some rubbing I need to address and order my cab mount relocation. But these trucks look perfect on 35s vs 33s
    13txtaco, arrijay, TnTHicks and 14 others like this.
  3. Apr 1, 2021 at 5:55 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    So with removing the top you can access the metal clips? I would have done it that way if I knew that :facepalm:
  4. Apr 1, 2021 at 5:55 PM
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    April fool's joke on 3rd genner's...
    imjustabill1970 likes this.
  5. Apr 1, 2021 at 5:56 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Damnnnnn that’s sexy. I’m jelly. Nice upgrade.
    rgljr831 and Vegasstunts[QUOTED] like this.
  6. Apr 1, 2021 at 6:13 PM
    igod69m
    igod69m Where do squirrels go during hurricanes?
    Wyoming
    2019 TRD OR Cement Gray Taco
    K&N COI, OV tuned, UpTop overland Alpha rack, backflip tonneau cover, rough country full bed molle system, cut in storage drivers side bed-added airline port inside, pro shift knob, meso customs interior cement kit, meso interior led lighting, meso pro shifter button mod, meso push start, meso mirror intermediate smoke turn signals, meso headlight trim, rigid diffused fog lights and brackets, rigid ditch lights, morimoto Low beam HID kit, morimoto license plate housing and lights,(4) Baja Designs rock lights on Alpha rack, meso pods for BD lighting, switch-pros 9100, extremeLED 38” s6x Amber/white light bar, extremeLED single 30” light bar, magnaflow cat back exhaust, level kit, front camera with switch, pop lock tailgate, 17” fuel trophy D551 wheels, AT3LS tires 265/70R17, Caliraised step sliders, ARB twin compressor, ARB 1 gallon air tank, M.O.R.E bracket for air tank/compressor, powertays holding blue seas fuse block/bussbar/switch pros, Fab Fours slimline bumper, custom TacoVinyl grill, eezi awn 2000 1.5 sepoia, UpTop awning mount, ARB recovery point, Cascadia 4x4 85 watt hood solar panel, RDJ smooth lineX fender flares, Nextbase 622GW dash cam,
    Yes there is! It’s an option on the order page. Grill is cut out for it as well as the bracket is prepped
    rgljr831 and AbnMP13[QUOTED] like this.
  7. Apr 1, 2021 at 6:14 PM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    I’m assuming you’re referring to the razor blade looking things, and yes when removing the entire bumper end you can access all plastic clips and those metal ones as well.
    rgljr831 and barf[QUOTED] like this.
  8. Apr 1, 2021 at 6:15 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Hm. Too late now lol. But no wobble so no big deal. Good to know though. Thanks.
    rgljr831 and BOSS-DS2[QUOTED] like this.
  9. Apr 1, 2021 at 6:19 PM
    behique
    behique Member
    '21 TRD Off-Road
    Hi there, those are Clazzio Leather, black color with red stitches.
  10. Apr 1, 2021 at 6:19 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Front and rear?
    How many miles?
  11. Apr 1, 2021 at 6:33 PM
    MGMDesertTaco
    Might want to add an aftermarket power steering cooler from Derale or Hayden with those 35's in the summer heat. You can even use a frame rail transmission cooler or get one with a fan if you need something larger.
    rgljr831 and barf like this.
  12. Apr 1, 2021 at 6:50 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    I’ve never heard of this being mentioned for 35s. My list of parts for my 35” tire journey continues to grow :frusty:
  13. Apr 1, 2021 at 6:53 PM
    MGMDesertTaco
    I'm sure drivers with 285's or 33's could benefit from one as well. Heck, the factory trans cooler is pretty tiny too. They don't cost much $30-$40 for a basic one or about $150 for one with a fan.
    Cheap:
    https://www.amazon.com/Derale-13200-Power-Steering-Cooler/dp/B0006HNM66
    Not so cheap:
    https://www.amazon.com/Derale-13700...15d3f669bf7&pd_rd_wg=z0USe&pd_rd_i=B001QITRBS
    rgljr831 and JDSmith like this.
  14. Apr 1, 2021 at 7:05 PM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    582C7CF1-E218-4F72-BB46-662F06E01B54.jpg Wiped/cleaned under the hood to matched the exterior color.
    TnTHicks, rgljr831, roothog and 8 others like this.
  15. Apr 1, 2021 at 7:09 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    You can also just buy the bumper covers: https://www.ecoological.com/bumpershellz.html
  16. Apr 1, 2021 at 7:17 PM
    cargreg
    cargreg Member
    Greg
    Fort Mill, South Carolina
    2020 TRD Offroad 6M
    Bilstein 6112 on 6/5th notch front, Wheeler's Offroad AAL in rear with Bilstein 5160 shocks.
    Added a little color a couple weeks ago after removing the TRD OR decals.
    redeyehal, reymataco, Shayne and 36 others like this.
  17. Apr 1, 2021 at 7:22 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    This morning my wife asked me what I want for my birthday next week.
    I said I didn't know.
    She said something for your Tacoma?
    Joke's on her, I already ordered something for the Tacoma.
    A net to hopefully keep the bulldog in the backseat when we take her to the dog park. It was a whole $9. :laugh:
    Yes, I know I need to clean the bulldog slobber off of the seats. Sounds like a good day off of work tomorrow job.
    TnTHicks, rgljr831, japjoe7 and 8 others like this.
  18. Apr 1, 2021 at 7:33 PM
    Concrete_taco
    Concrete_taco Well-Known Member
    CA
    2020 TRD Off Road
    What color. I don't see no stinking color.:rofl:
    rgljr831 and manncyclesupply like this.
  19. Apr 1, 2021 at 7:37 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Right click the pic and press open in new tab
  20. Apr 1, 2021 at 7:44 PM
    Wapiti_chaser77
    Wapiti_chaser77 Well-Known Member
    IDAWHOE
    17 OR dcsb 6mt
    886’s, 90000’s, jba uca’s, ecgs, Fox 2.0 resi's and Icon rxt mediums in rear, wheelers super bumps, softopper, warrior products roof rack, smittybilt 10k, 255/85r16’s, coastal offroad front bumper, diff breather and a couple stickers
    Got these little gems in today. Can’t wait to install them. Ss3 yellow combo
    TnTHicks, rgljr831, dleriche and 7 others like this.
