  1. Apr 13, 2021 at 7:33 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    What product(s)? I’m thinking about trying it. I’d like the scoop on an easy process....
  2. Apr 13, 2021 at 7:45 PM
    HanShotFirst
    HanShotFirst Well-Known Member
    Don
    Edenton, NC
    2021 Magnetic Gray Tacoma DC LB V6 4X4
    Mud Guards
    These are the 2 I've tried. Both are good. The black bottle was a sample from a vendor at work. Chemical guys make one, too.
    romafern, TnTHicks, markram and 2 others like this.
  3. Apr 13, 2021 at 7:45 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Some random guy parked across 5 parking spots at my school (yeah I’m a senior in high school) last year with a massive truck and whoever owned the truck basically abandoned it there and they couldn’t tow it for some reason. they had to get a rotator out there to get it off the lot. Ended up losing my parking space for a week and it was right before ‘rona haha
  4. Apr 13, 2021 at 7:45 PM
    Kane50
    Kane50 Well-Known Member
    2016 TRD Sport
    Count me in for 4 also... :thumbsup:
  5. Apr 13, 2021 at 7:52 PM
    str8edgMTBMXer
    str8edgMTBMXer Well-Known Member
    Central Ohio
    2021 SR5 DCLB; midnight black metallic
    cool!! thanks for the pics as well...that helps.
    I am definitely looking for no drill...and would also prefer no tape...would prefer tape over drilling if it came to that...
  6. Apr 13, 2021 at 7:54 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Just watched Griot’s video for that green 3 in 1. Not really one to buy something based on an ad. But based on your recommendation and how easy it looks to use, I’m definitely in for trying it out. Thanks for the suggestion.
    TXnativeson and rgljr831 like this.
  7. Apr 13, 2021 at 8:20 PM
    speedlimitz
    speedlimitz Well-Known Member
    Cave creek, Arizona
    2019 cement trd off-road 4x4
    Installed some alpharex headlights.
    honey, Shayne, savin yours and 15 others like this.
  8. Apr 13, 2021 at 8:29 PM
    MGMDesertTaco
    Anything with SiO2, ceramic, or graphene is going to get you the results you want.
    Ceramic is a labor intensive process and prices vary significantly depending on which products are used. The surface has to be squeaky clean so it can bond to the paint and then it has to have time to cure. Once that's done you just maintain it with regular washes and the occasional top coat of your choosing like a ceramic boost spray.
    Ceramics 101 via Pan the Organizer:
    https://www.youtube.com/watch?v=tC-YpSGawRU
    CarPro CQuartz followed up with CarPro Reset Shampoo is a really popular choice. If you want to try cheaper first, look into graphene or ceramic products from Turtlewax and 303. Jescar has just released a middle priced option called ultra lock plus. It's a traditional sealant, but infused with ceramic and SiO2. Ethos makes several mid priced ceramic products also.
    Some links to get you started...
    https://clean-garage.com/categories/car-care/ceramic-coatings.html
    https://www.obsessedgarage.com/collections/paint-coatings
    https://www.turtlewax.com/products/hybrid-solutions-ceramic-wax-spray-coating-16-fl-oz
    https://www.turtlewax.com/products/hybrid-solutions-pro-graphene-flex-wax-23-fl-oz
    https://clean-garage.com/303-graphe...MIs8PQt9_87wIV7B-tBh127gS3EAQYAyABEgKTKfD_BwE
    https://jescarfinishing.com/collections/surface-protection-cleaning-products
    https://ethoscarcare.com/collections/all
    :boom:
    BigJanko, CXYyuppie, markram and 6 others like this.
  9. Apr 13, 2021 at 8:34 PM
    NinGee87
    NinGee87 Well-Known Member
    AZ
    19 Cement DCSB TRD Sport 4x4
    I have the AVS and it wasn't drilled or taped. Just screws in to existing holes.
    honey, RCrumb, RKEWL and 10 others like this.
  10. Apr 13, 2021 at 8:42 PM
    semonster
    semonster Well-Known Member
    Zachary
    PC, UT
    20 Silver DCSB TRD OR
    Looks nice, so does the the Dometic slide mount into the track you added or is that part of the Dometic slide?
    romafern likes this.
  11. Apr 13, 2021 at 8:58 PM
    bern_10
    bern_10 Active Member
    Brendon
    Spokane, WA
    2017 Tacoma TRD Off Road
    OV Tune, cali raised rock sliders, 12v power outlets and usb in bed cubby, , Group 27 battery with monitor and solar port for charging, Bed lights, pop n lock for tail gate,
    The T track is separate; meant for 1/4” bolts that I used to mount to slider. Drilled my own holes in the slider because the orientation of the T Track on the bed.
    romafern and semonster[QUOTED] like this.
  12. Apr 13, 2021 at 9:29 PM
    Visualkev
    Visualkev Well-Known Member
    Phoenix
    2019 Tacoma TRD Off Road MT
    Snug top Bed cap with Yakima rack, UpTop Bravo cab rack, BA 4x4 Hiline front bumper with Badlands Apex winch and Rough Country 20" light bar
    It's a great looking bumper.That is what i chose.
    rgljr831 likes this.
  13. Apr 13, 2021 at 10:23 PM
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    I’m down for 4:D
    EDDIESDASHYT[QUOTED] likes this.
  14. Apr 13, 2021 at 10:48 PM
    JFanaselle
    JFanaselle Well-Known Member
    Joe
    Murrieta, CA
    2020 TRD Off-Road DCSB 4x4
    More cheers from another local here. :cheers: I'll be keeping an eye out for your rig around town. That's a sweet looking truck. :hattip:
    Do you mind if I ask what components your setup consists of? I'm on the brink of upgrading from my current setup (OEM TRD Pro Fox 2.5s with a Headstrong AAL in the rear and a Westcot spring perch in the front). I was looking at King setups, as well as the Old Man Emu BP-51s and the Fox 2.5 adjustable setups. I'm having a hard time deciding, and it looks like everyone is basically out of stock on everything anyway.
  15. Apr 14, 2021 at 1:40 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    They line up, it’s just not installed. Like mentioned I’m waiting on the @MESO Total Taillight kit because I need to pull the tail lights to install the Bed Stiffeners. You have to drill a hole for one of the fasteners. Once the brackets are installed, I’ll add the new taillight kit and reinstall the Taillights.
  16. Apr 14, 2021 at 2:58 AM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    The WeatherTech gives you plastic tabs that insert into existing holes. You use those to mount the deflector.
  17. Apr 14, 2021 at 3:01 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Just be careful not to drop them in the engine bay when installing them. :eek:
  18. Apr 14, 2021 at 3:07 AM
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    hey....i'm already thinking about bigger tires after 2-3 mo. brand new ko2s......what is your plan for the old tires?....you just gonna sell em after take off or keep em?....or is there some sort of trade in you can do?....and if you are selling them, how much of a hit do you plan on taking $???.....thanks
  19. Apr 14, 2021 at 4:29 AM
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Good to know it does the job well! I researched the hell out of these machines, seemed like the best for what I wanted it for. Mainly for motorcycles but I wanted to be able to do everything else also.
    Thanks for the heads up on cones also, haven’t gone through everything it came with yet so I’ll do that today. Hopefully it came with cones that will do Tacoma wheels!
  20. Apr 14, 2021 at 4:29 AM
    Silver'16TRDSportDCLB
    Silver'16TRDSportDCLB Well-Unknown Member
    Nate
    South-Eastern PA
    2016 Silver Tacoma 4x4 Sport DCLB
    Lights, stickers, audio, and a grille…
    I drive for big brown, we do give shippers packaging guidelines, unfortunately for larger heavier items those shipping guidelines are very expensive. High strength large boxes are not cheap, also proper packaging materials and reinforcements are all also costly and time consuming. Most shippers find it cheaper to improperly package large heavy items, and just eat the occasional damage costs, rather then pay to try and meet our absurd packaging guidelines we require. I’m not trying to make excuses for roughed up boxes, but big brown moves millions of parcels everyday, and while we do are best to get things delivered in one piece, stuff happens. Most damage to parcels occurs not from an employee’s lack of care, but from the thousands of miles of conveyoring systems we utilize to move parcels as quickly and efficiently as possible. Especially when those systems get “jammed” with thousands of parcels.
    All that to say, sorry some of your parcels show up damaged! It is by no means intentional! We appreciate any and all business, as it keeps food on our tables! Cheers!
    Nate.
