What Have You Done To Your 4th Gen Today?
Discussion in '4th Gen. Tacomas (2024+)' started by Gmak621, Jun 1, 2024.
  1. Apr 26, 2025 at 12:27 PM
    #2461
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    ARB makes these red recovery loops (front and rear) for Toyota as an OEM supplier.
    I trust ARB recovery gear.
  2. Apr 26, 2025 at 4:10 PM
    #2462
    JimScotty
    JimScotty Well-Known Member
    2024 Tacoma TRD Pro
    The gear may be fine and of good hefty material. The question is what they are mounted to. What will that structure support? There are limitations in how they are to be used safely.
    Goin2drt likes this.
  3. Apr 26, 2025 at 4:37 PM
    #2463
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    '25 4 runner installation instructions of same part number enclosed below. Subframe. Should be similar in ours.
  4. Apr 26, 2025 at 6:38 PM
    #2464
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    No bueno from me. Looks tacky.
    gpb, Vidman, Goin2drt and 1 other person like this.
  5. Apr 26, 2025 at 6:43 PM
    #2465
    Taco Ji
    New Jersey
    This black hook is Toyota factory front recovery hooks I took off my Tacoma… if you’re going to trust this, I’m going to trust these I installed by bonobos also.
    WHIT4K3R, PDKTaco, Delta09 and 2 others like this.
  6. Apr 26, 2025 at 7:13 PM
    #2466
    BigDaddyJuan
    BigDaddyJuan Well-Known Member
    2024 Black Tacoma SR5
    Lift, tires, fender flares, fangs, engine cover, window tint, window channel deflector, skid plate.
    I don't remember, but they are available all over the place.
  7. Apr 26, 2025 at 7:50 PM
    #2467
    TACODOC1
    SoCal
    The key word here is metallurgy. You’d be hard pressed to yank apart that OEM Toyota recovery point in anything less than frame deep Georgia red dirt.
    Bonobo? From their product page:
    “machined from premium 6061 billet aluminum”
    Aluminum is no bueno for recovery gear. I don’t care if they say it’s got a WLL of 11,000 lbs. Especially since they don’t cite any sources of independent testing to failure.
    From Grok AI:
    Cons of 6061 Aluminum for Recovery Points:
    1. Lower Strength Compared to Steel: While 6061-T6 (tempered) has a tensile strength of about 40-45 ksi (276-310 MPa), high-strength steels commonly used in recovery points can exceed 100 ksi (690 MPa). Recovery points endure extreme dynamic loads (e.g., snatch recoveries), and aluminum is more prone to deformation or failure under such forces.
    2. Fatigue Resistance: Aluminum has lower fatigue resistance than steel, which is critical for recovery points subjected to repeated dynamic loading during off-road recoveries.
    3. Shear and Abrasion Resistance: Aluminum is softer than steel, making it more susceptible to shearing or abrasion from recovery straps, shackles, or hooks, potentially leading to failure over time.
    4. Load Rating Concerns: Recovery points must be rated for loads well above the vehicle’s weight (often 2-4 times the gross vehicle weight for dynamic recoveries). Aluminum’s lower strength may limit its ability to meet these requirements without significantly overbuilding the component, negating weight savings.
    Key Considerations:
    • Design and Thickness: To use 6061 aluminum, recovery points must be designed with thicker sections or reinforcements to compensate for the lower strength. Finite element analysis (FEA) or engineering calculations are recommended to ensure the design can handle expected loads.
    • Temper: Use 6061-T6 for maximum strength. Untempered or lower tempers (e.g., 6061-O) are significantly weaker and unsuitable.
    • Attachment Points: The recovery point must be securely bolted or welded to a strong part of the vehicle frame (preferably steel). Aluminum-to-steel connections require careful design to avoid galvanic corrosion.
    • Application: For light-duty off-roading or vehicles with lower weight (e.g., UTVs or small SUVs), 6061 aluminum might be sufficient if properly engineered. For heavy-duty applications (e.g., large trucks, extreme recoveries), steel or higher-strength aluminum alloys (e.g., 7075) are preferred.
    Taco2zzDay, TacoYankee and dleithaus like this.
  8. Apr 26, 2025 at 8:20 PM
    #2468
    tonymac
    tonymac Well-Known Member
    Waco, TX
    2024 TRD Sport
  9. Apr 26, 2025 at 8:49 PM
    #2469
    crookedcoast
    crookedcoast Well-Known Member
    2025 OR MT
    The factor55 stuff is aluminum and it's an excellent recovery option.
    https://www.factor55.com/p-hitchlink-2-0
    GrrrMaker likes this.
  10. Apr 26, 2025 at 9:17 PM
    #2470
    TACODOC1
    SoCal
    GrrrMaker and Goin2drt like this.
  11. Apr 26, 2025 at 10:52 PM
    #2471
    usmcflyr
    usmcflyr Member
    2025 Bronze Oxide Tacoma Trailhunter & 2017 Quicksand Tacoma TRD OR
    The red ARB recovery points are each rated for 1.5 X GVW
    TACODOC1 likes this.
  12. Apr 27, 2025 at 3:34 AM
    #2472
    Goin2drt
    Goin2drt Well-Known Member
    Good news all this banter about recovery hooks most are just installing them for looks at the mall and they will literally never have to be used. If you are going to actually use them you are best to do a little research on not only the hook material but mounting spot because many of these companies don’t test any of their stuff and actually know most are just buying for looks because they don’t want to spend the money for actually good stuff. I am sure there are other companies but Factor 55 is who I would use as there stuff (albeit mostly Jeep) is very well tested. Now back to the mall I go with no tow hooks. I won’t need them and they just add weight and ugly.
  13. Apr 27, 2025 at 4:17 AM
    #2473
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Remember when people would put those big track car tow hooks on Granny's hand me down Civic when they souped them up? I recall seeing that before I ever heard of Bezos, Temu, or Shein.
    Goin2drt[QUOTED] likes this.
  14. Apr 27, 2025 at 4:27 AM
    #2474
    Goin2drt
    Yep sure do. Pep Boys was the place to shop. They were way before their time. Get all the Chinese crap you wanted and the more they slapped on the better. :thumbsup:
    batacoma[QUOTED] likes this.
  15. Apr 27, 2025 at 4:38 AM
    #2475
    Taco Ji
    New Jersey
    You guys are goofy.
    R242, bbartol, dleithaus and 2 others like this.
  16. Apr 27, 2025 at 5:36 AM
    #2476
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Stick around a while; it only gets worse :rofl:
  17. Apr 27, 2025 at 5:50 AM
    #2477
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
  18. Apr 27, 2025 at 11:57 AM
    #2478
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Removed air damn and installed the TRD skid plate. Looks so much better now!
    nurp42, WHIT4K3R, tonymac and 9 others like this.
  19. Apr 27, 2025 at 12:50 PM
    #2479
    Taco Ji
    New Jersey
    Look great. This is something that is on my list but I’m waiting for a holiday sale discount. Would installing the skid plate affect oil changes ? Meaning would you have to remove it every time to gain access to the oil drain plug?
  20. Apr 27, 2025 at 1:22 PM
    #2480
    jrgutierr
    jrgutierr Well-Known Member
    24 TRD Pro
    Added the OEM transmission and rear differential skid plates today. Not sure why don't come on the Pro. Added the red tow hooks in the front as well.
    nurp42, Burns, BigDaddyJuan and 4 others like this.
