What Have You Done To Your 4th Gen Today?
Discussion in '4th Gen. Tacomas (2024+)' started by Gmak621, Jun 1, 2024.
  1. Nov 10, 2024 at 9:18 AM
    #1321
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I haven’t changed my oil yet. But while I was under the truck changing my skid plate, I did take a pic of the oil filter that came from the factory. Here it is.
    Rojogrande70 likes this.
  2. Nov 10, 2024 at 9:29 AM
    #1322
    Hacienda
    Hacienda Active Member
    East Kootenay's, British Columbia
    2024 DCLB TRD Sport Premium
    Greenlane skid & step/sliders with bump out
    Flat with full top deck and rear bump out.
  3. Nov 10, 2024 at 11:30 AM
    #1323
    Ironium
    Ironium Well-Known Member
    Mark
    Oceanside, CA
    24’ TRD O/R Premium
    Here are my quick installation tips…
    First, make sure the dealership gives you a printed copy of the instructions. Mine didn’t, but thanks to @Poot Klopp for posting a clean version that I was able to follow! :thumbsup:
    Step 2-B: Instead of aligning with the front of the bulkhead (as the instructions say), I found it easier to line up with the back end of the bed.
    Step 4-L: The instructions say to fold up the tonneau cover to tighten the elevator bolts after aligning, but I suggest doing it differently. Leave the tailgate open so you can see the latch alignment and carefully align the left/right position. Once that’s set, close the tailgate to adjust front/back alignment according to the diagram in 4-H.
    Final Tightening: Once everything is perfectly aligned, open the tailgate carefully, crawl inside, and tighten the bolts in place.
    Step Sequence Tip: Do Step 4-O at the same time as 4-J, then add the clips from 4-M after these steps.
  4. Nov 10, 2024 at 11:41 AM
    #1324
    Iam_Q
    Iam_Q New Member
    Andrew
    2024 Underground Tacoma SR
  5. Nov 10, 2024 at 12:20 PM
    #1325
    Iam_Q
    Iam_Q New Member
    Andrew
    mine is making that chirping noise. What did they find with your Taco?
  6. Nov 11, 2024 at 3:56 PM
    #1326
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    YZZN1 is the correct OEM replacement Tacoma filter. YZZF1 is the Tundra filter I think.
    The factory installed filter is different then what you will find at the dealers. It is around $4.50 for a YZZN1.
  7. Nov 11, 2024 at 4:47 PM
    #1327
    Forest Moon
    Forest Moon Well-Known Member
    Greater Lowell Area
    '24 OR 6mt Supersonic Red
    Ordered an overpriced LEER cap Saturday, upTOP Overland bed stiffeners in preparation for it. No drilling required for these.
  8. Nov 11, 2024 at 5:11 PM
    #1328
    CrispyTacoLover
    fyi, those stiffners use the same holes on top as the Extang Solid Fold ALX tonneau cover.
  9. Nov 11, 2024 at 5:20 PM
    #1329
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    I would have went for those had I known they existed. My biggest fear of removing the tail lights and drilling 4 holes was fumbling a brand new tail light on the driveway.
    Rojogrande70, DeafGryphon and PDKTaco like this.
  10. Nov 11, 2024 at 6:03 PM
    #1330
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Those look nice...pricey but nice!
  11. Nov 12, 2024 at 5:18 AM
    #1331
    Hender
    Hender New Member
    2024 Red Tacoma limited
    Installed the new WeatherTech mud flaps. Great fit, easy install but expensive. Finally some added protection when I need to drive gravel roads over the OEM flaps. Front tire shown, no drilling needed.
    Rojogrande70, MCCM, tvterry and 2 others like this.
  12. Nov 12, 2024 at 5:19 AM
    #1332
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    On the bed sides closest to the rear window has anyone come up with a solution to stop the side pieces from lifting at the front.
  13. Nov 12, 2024 at 6:33 AM
    #1333
    JB_TN
    JB
    Tennessee
    Assuming you are talking about the bed side caps? If so then more double sided tape.
    Ryan's Taco[QUOTED] likes this.
  14. Nov 12, 2024 at 8:43 AM
    #1334
    Ryan's Taco
    Yes that is what I was talking about ty
  15. Nov 12, 2024 at 8:48 AM
    #1335
    JB_TN
    JB
    Tennessee
    You have about 5 or 10 pounds of weight you can set on top of it after you add the tape? That is what I would do to make sure it seals good.
  16. Nov 12, 2024 at 9:00 AM
    #1336
    Vitamins
    2024 TRD OR
    That works for a few months but it peels up again. I tried that.
  17. Nov 12, 2024 at 11:23 AM
    #1337
    Bluznvice
    Bluznvice Well-Known Member
    Can confirm that. Did the same thing, about 4 miles past empty. 16 gallons to fill up.
  18. Nov 12, 2024 at 1:07 PM
    #1338
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    I just ordered this as well!!!
    Hacienda and Gmak621[QUOTED][OP] like this.
  19. Nov 12, 2024 at 2:57 PM
    #1339
    Goin2drt
    Goin2drt Well-Known Member
    I tried the vinyl on the stock wheels over the silver. It did not hold up so I continued to shop for a black wheel I liked without poke. I guess I am the oddball because everything has poke so I bought and had installed today the TRD Toyota OE wheels. These are perfect for what I wanted.
    Ordered from Toyota Direct - Free Shipping $762.18 delivered to my door.
    Wheel part # - PTR56-35242-F1
    Center Cap part # - PT998-34221-2F
    IMG_9737.jpg IMG_9736.jpg IMG_9735.jpg IMG_9734.jpg IMG_9733.jpg IMG_9738.jpg
    JPTx, Burns, PEAKIT and 5 others like this.
  20. Nov 12, 2024 at 7:44 PM
    #1340
    budbodnar
    budbodnar Member
    Brian
    2024 Toyota Tacoma Sport
    I took mine back into the place that installed my bed cover. They put a wedge on the bedside of the caps. Fixed it.
    Hacienda likes this.
