What have you done to your Pickup / 4Runner today? (Old School Edition)
Discussion in 'Toyota Trucks & SUVs' started by BuzzardsGottaEat, Mar 3, 2013.
  1. Apr 10, 2013 at 10:03 AM
    #61
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    I only put 2 in mine with a HP. It doesn't change between the 2.
  2. Apr 10, 2013 at 11:38 AM
    #62
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    :drool:
    Cool. I know high pinion has an oil slinger but I want to be sure.
  3. Apr 10, 2013 at 7:10 PM
    #63
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    So I'm adjusting my torsion bars right now and I'm not seeing any difference in height. I have only turned the nut about one full turn, so that might be it, but I'm not entirely sure what to expect, so I've been going slowly.
    Also, when I jacked up the front end to adjust the torsion bars I checked the tire spin to see if there was any binding. The passenger wheel spins great but the driver one gets stuck but you can force it and the differential wiggles a little to let it go. Is that binding or is that a sign that the axle isn't in properly?
  4. Apr 10, 2013 at 9:36 PM
    #64
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    I set it down and rolled it and didn't see the movement of the differential, so I'm guessing that the reason why the wheel got stuck was because of binding at full droop.
    Going to get it aligned tomorrow! Hopefully they can fix my ridiculous camber...
  5. Apr 11, 2013 at 12:58 PM
    #65
    ajohnson
    Andy
    Charlotte, NC
    finally got dis chit put in
  6. Apr 11, 2013 at 7:26 PM
    #66
    BuzzardsGottaEat
    BuzzardsGottaEat [OP] Well-Known Member
    Some Toyotas
    Round tires
  7. Apr 11, 2013 at 9:57 PM
    #67
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Nice job ajohnson, looks great!
    I got my truck aligned and it turned out great! Much less vibrations because the tires had so much camber that the knobs on the tire edge were the main contact with the road.
    I also put in some washers to space down the carrier bearing, which reduced the vibrations a little bit. The skid plate covering the bearing is a little too close to the driveshaft so that when the drive line shifts with downshifting the u-joint hits the skid. I have to space it down a bit more, I'll do that tomorrow and I'll get a BPV relocation bracket, too. Almost done!
  8. Apr 12, 2013 at 8:38 AM
    #68
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    ok n00b question. WTF is that? What is the purpose of the outboard shifters?
  9. Apr 12, 2013 at 8:55 AM
    #69
    ajohnson
    Andy
    Charlotte, NC
    Dual transfer cases. The front portion (gear box, or crawl box) of a transfer case bolted to the front of a transfer case with an adapter, allowing for a much lower crawl ratio. That is a triple stick setup that brings the twin sticks for the rear case up to the front case shifter. The twin sticks allow it to be shifted into 2wd or 4wd with any gear combination, so it can be in double low 2wd. The front case is stock 2.28 gearing, the rear case is 4.7 gearing. I can be in stock low, crawler low, and stupid turtle low in 2wd or 4wd.
  10. Apr 12, 2013 at 10:27 AM
    #70
    Crosis
    Dunedin Fl
    Very cool. Sound like a hard core offroader thing, not for us casual trail riders.
  11. Apr 13, 2013 at 7:06 PM
    #71
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Finished with my brake proportioning valve extension bracket :)woot: I have full braking power again!). For any SoCal/San Diego folks, I just had James at the Truck Shop fab one up real quick and he gave it to me free of charge. Of course I have had him do a few other things in the past and my mom had all of her new suspension done there, so that might be it, but he's awesome regardless. I was happy to change out my Off road warehouse (Didn't have a very good experience there) front plate border for an SD truck shop one. :)
    Going out to a trail tomorrow to test everything out!
  12. Apr 13, 2013 at 7:13 PM
    #72
    ajohnson
    Andy
    Charlotte, NC
    I installed my 4innovations motor mounts and discovered the stock driver side mount is broken :eek:
    Tomorrow I am putting ALL new fluids in her, including a coolant flush.
  13. Apr 15, 2013 at 12:54 PM
    #73
    Javi22RE
    Javi22RE Active Member
    Javi
    Chandler
    1993 Pickup 5spd/4x4 chassis swap
    I'm currently trying to figure out why it won't start? The fuse box in the engine bay is giving me problems. Truck just keeps cutting off while driving. Did a U-turn last night and it shut off. The wire that runs to the starter from the fuse box became loose and it wouldn't start last week but this time its not that. Ready to blow this sucker up! Also losing power when climbing and its not carburated. Seems like the MAF is going out as it is causing a rough idle.
    Anyone got a match?
  14. Apr 19, 2013 at 2:42 PM
    #74
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Finally time to make a little progress on the to do list. So much for studying for finals this week :)
  15. Apr 19, 2013 at 2:46 PM
    #75
    ajohnson
    Andy
    Charlotte, NC
    Those are sweet Buzzard!
    I loaded my junk up, heading out in the morning for some 'wheeling
  16. Apr 19, 2013 at 2:55 PM
    #76
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    :drool: wants 4Runner . . .
  17. Apr 19, 2013 at 2:56 PM
    #77
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I also did the sweet switch your shift knobs and confuse the crap out of your friends mod the other day and haven't switched em back yet haha don't ask me why, I don't have a valid answer
  18. Apr 21, 2013 at 7:10 PM
    #78
    Boomtacoma01
    Houston
    Cleaned up my spare driveshafts and re-greased them. Also cleaned out the garage since my truck is out of there. I found a good spot to mount my 42" Pioneer flat screen. I might do that this week. Kept the labor intensive stuff to a minimum due to a hangover.
  19. Apr 25, 2013 at 7:36 PM
    #79
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Being powder coated at this very moment. $50 :cool:
  20. Apr 25, 2013 at 7:59 PM
    #80
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    So beautiful :)
