What have you done to your Pickup / 4Runner today? (Old School Edition)
Discussion in 'Toyota Trucks & SUVs' started by BuzzardsGottaEat, Mar 3, 2013.
  1. May 7, 2013 at 5:58 PM
    #101
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I thought about it but I'll just keep these halogens atleast for now. I ordered an upgrade harness from rallylights.com so I should have plenty of light when that goes in.
  2. May 13, 2013 at 7:02 PM
    #102
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Drained the oil out of my duals to check for any carnage from Jambo. Good so far. Still looking for where the leak is originating from.
  3. May 13, 2013 at 7:15 PM
    #103
    ajohnson
    Andy
    Charlotte, NC
    I pulled my oil pump to replace the o ring and front seal, and swapped in my Powermaster GM 100 amp alternator.
  4. Jun 1, 2013 at 3:15 PM
    #104
    ajohnson
    Andy
    Charlotte, NC
    Finally gave the hoerunner a bath. This is the cleanest it has been in a year.
  5. Jun 2, 2013 at 12:11 PM
    #105
    ajohnson
    Andy
    Charlotte, NC
    Today I got the water pump off. I'm going to replace the gasket when it comes later this week, and put sealant on the bolts where it was leaking oil. Then I put on my Addicted front bumper. I'm picking up my new winch tomorrow.
  6. Jun 2, 2013 at 12:34 PM
    #106
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Lookin good!
  7. Jun 2, 2013 at 12:57 PM
    #107
    ajohnson
    Andy
    Charlotte, NC
    Thanks dood!
  8. Jun 2, 2013 at 2:20 PM
    #108
    BuzzardsGottaEat
    BuzzardsGottaEat [OP] Well-Known Member
    Some Toyotas
    Round tires
    Look it over for rust. The V6 is susceptible to head gasket leaks. If its all structurally and mechanically sound I would do about that price. Depends on supply and demand in the area. I've had offers for three times that here in the Dakotas and Nebraska area.
  9. Jun 2, 2013 at 6:50 PM
    #109
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I paid $3,650 for mine a few months ago. It's a '90 SR5 V6 with 256k miles on it and a cap. Engine and trans are strong. Body and interior are in good shape. Sounds like a good deal to me as long as everything is in decent shape.
  10. Jun 4, 2013 at 4:59 PM
    #110
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Just re-torqued all of my new suspension and found grease all over the outside of my front driver's side CV boot on the differential side.:mad:
    I think I either didn't get the axle back in correctly after installing the BJ spacers or the CV angle is too steep so the boot tore.
    I don't have time or patience to do it myself so it's going to the shop tomorrow.
  11. Jun 17, 2013 at 11:30 PM
    #111
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Just ordered a front diff drop kit to help those CV angles!
    I've been hauling a lot of stuff around recently and the springs have held the weight beautifully. I had a bed full of wooden stakes, probably 200-300 pounds worth, and the springs were still higher than the stock suspension was with no weight. It's awesome! I also did a trip out to Santa Cruz a week ago and the handling on the very curvy roads was still really good given the change in height. I do have squeaks in my leaf packs now, so I might try OZ-T's solution of sandwiching a piece of rubber in between the leaves of the Dakars on his truck to see if that helps.
    I've also been working on mounting an LED light onto the back of the truck and now I just need to wire it all together, hopefully that gets done tomorrow or something.
    I should probably start a build thread...
  12. Jun 20, 2013 at 5:03 PM
    #112
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    MOAR PICS!
    1.5" bj spacer and 1" diff drop . . . ?
  13. Jun 20, 2013 at 5:56 PM
    #113
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Haha, yeah I'll get some up soon. I'm pretty busy with work right now so I've been slacking with a lot of pictures that I need to add both here and on Facebook.
    Well from what I understand, there is about an inch, maybe a little more, of space between the bottom of the front differential and the bottom of the frame. If you drop the front diff lower than the frame, you risk hitting it on rocks, which I would rather not do. And I don't think you need much to help those front axle angles, just enough to prevent the ribs of the boots from rubbing together. I also will probably need to drop the torsion bars a little, if not to just level out the front because the passenger side is noticeably lower than the driver side.
  14. Jun 22, 2013 at 12:01 PM
    #114
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    So I was looking at the instructions for installing the diff drop and the torque specifications are conflicting. I ordered the kit from 4crawler offroad and their instructions say to use the FSM torque or 50-70 ft lbs if you don't have the FSM. The FSM says 123 ft lbs...anyone know what to use?
  15. Jun 22, 2013 at 2:15 PM
    #115
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Dammit, didn't realize that the sway bar drop is needed in order to drop the front diff...need to order that now
  16. Jun 22, 2013 at 8:23 PM
    #116
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Dang, wish I woulda said something ha I just assumed . . .
  17. Jun 24, 2013 at 1:02 PM
    #117
    Bobert14
    Bobert14 .
  18. Jun 26, 2013 at 6:18 PM
    #118
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Did you do a front diff drop? I'm having trouble getting the passenger side bolt in on the differential after dropping it... I think it just needs some pry bar action or something but I could be screwing something up :(
  19. Jun 26, 2013 at 8:29 PM
    #119
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
  20. Jun 26, 2013 at 9:45 PM
    #120
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Nope, no diff drop, no lift, pretty much stock. Just new shocks and stabilizer as well as a saggy leaf fix. I don't believe in lifting if you don't have to :D
    Glad you got it figured out though!
