  1. Jan 15, 2021 at 10:14 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    A few years ago when mine broke I shelled out the bucks for an OEM replacement and it only lasted six months. The latch (the part that actually holds the door shut) gets gummed up over the years and it takes more effort to open. This puts more stress on the handle, especially when it's cold outside. If you clean and lube that latch real good, your new handle will last, even if it’s a cheap one. If you don’t, your new handle probably won’t last, even if it’s OEM. After replacing the handle several times in quick succession I took the latch out and gave it a thorough cleaning. It wasn't really that hard to get out, and was filthy. You just have to disconnect the bottom of the window track on that side to give you room, and it will come out. I had tried just lubing it in the past, but that didn't make much difference. Now I can open my door with my little finger, and my cheap, eight dollar Amazon door handle is holding up just fine.
    Or you could get the metal one when it comes back in stock. https://www.amazon.com/dp/B07YQBM1Y4
  2. Jan 15, 2021 at 10:22 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Thanks guys, just ordered a cheap handle and gonna see how it goes. That metal handle is awesome lol
  3. Jan 15, 2021 at 10:33 AM
    Phessor
    Phessor Well-Known Member
    I need to do this on my truck.
    But on a good note, I did do an oil change, oil filter, air filter, spark plugs, five tire rotation and front skid plate install on my Forester, does that count?
    Digiratus[QUOTED] likes this.
  4. Jan 15, 2021 at 10:36 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Why do I do a 5 tire rotation? or why the pattern?
  5. Jan 15, 2021 at 10:38 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is the one I use. I got it from @drr
    As long as the rotation pattern is the same each time, it probably doesn't matter which pattern is used. I do like the one from Dan because it allows me to jack up the whole rear axle one time to do both sides.
    Why not?
  6. Jan 15, 2021 at 10:39 AM
    betterbuckleup
    Ian
    Concord, CA
    Yea it was just one of the patterns I saw for a 4wd vehicle online. And what @Digiratus said. As long as it's the same everytime you do it.
  7. Jan 15, 2021 at 10:45 AM
    Phessor
    Right or wrong, but I rotate like this.
    Digiratus likes this.
  8. Jan 15, 2021 at 10:48 AM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Do you guys have directional tires? I have directional Falken AT3W and I'd have to get the tires removed from the rim and flipped in order to make any of these patterns work. Curious how others approach it...
  9. Jan 15, 2021 at 11:04 AM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Jan 15, 2021 at 11:16 AM
    betterbuckleup
    Ian
    Concord, CA
    That's why
  11. Jan 15, 2021 at 11:40 AM
    slodoug
    slodoug Well-Known Member
  12. Jan 15, 2021 at 12:22 PM
    YotainOregon
    YotainOregon Well-Known Member
    Oregon
    1st gen Tacoma TrD
    Mine aswell because steers wear faster
  13. Jan 15, 2021 at 1:08 PM
    ToyotaFanatic91
    ToyotaFanatic91 Member
    Joey
    Alaska
    Tan 2000 Tacoma, ext. cab.
    Added a decal that I though was pretty cool. +1 on the coolness scale and +3 HP.
    Enjoy your weekends!
  14. Jan 15, 2021 at 2:02 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Question about Ubolts.
    About 1.5months ago I installed brand new OME Dakars with brand new U bolts. During the time the D43XL AAL was out of stock so I just went with the pack alone. Today I bought a pair of the OME AALs. Can I just add them on reusing the ubolts or do I have to get nee ubolts again?
  15. Jan 15, 2021 at 2:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have always understood that the process of torquing the u-bolts to spec deforms (stretches) the threads. And that makes them one-time use items.
    If it was me, I would use new ones.
    Jiveydude likes this.
  16. Jan 15, 2021 at 2:13 PM
    eon_blue
    Azusa, CA
    Get new ones. I've refused them before temporarily but only for a short while (got the wrong sized ones for my custom pack once and reused my old OME ones). Eventually got the right ones and swapped them out
  17. Jan 15, 2021 at 2:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You'll be fine to use them again.
    Blue92, nagorb, Reh5108 and 1 other person like this.
  18. Jan 15, 2021 at 2:29 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Okay. Guess I’ll order new Ubolts. Maybe I’ll just do a whole ubolt flip and relocate the lower shock mount to the axles.
  19. Jan 15, 2021 at 5:22 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Back to LED's...just had a tundra behind me with them. Fuck him.....
    ToyotaDriver and JBTacoma like this.
  20. Jan 15, 2021 at 5:25 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I’m so glad that when I was looking at headlight “upgrades,” I didn’t go with LED’s. Those people make me so mad.
