  1. Jan 20, 2021 at 7:27 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Let's go move some pallets.
    Just kidding, I don't have lights wired yet.
    Metal roofer, aroma, Phessor and 6 others like this.
  2. Jan 20, 2021 at 8:40 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Looks good!
    0xDEADBEEF[QUOTED] likes this.
  3. Jan 20, 2021 at 8:43 PM
    0xDEADBEEF
    Thanks! I like it :) I need to park it on level ground so I can see what needs tweaking, but overall i'm very pleased with it so far.
    For sure I need to rework the passenger shock, or get a longer one - when I did hte ubolt flip, I think I got the lower shock mount too low, so its at full extension sitting in my garage (floor is not flat due to floor drain). OR, I have the wrong shock. It'll need some investigation.
    jmferg and Speedytech7 like this.
  4. Jan 20, 2021 at 9:14 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    will 01-04 corner lights fit either of them?
  5. Jan 20, 2021 at 9:21 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Technically they are the same shape. But the way they mount is different. The 95-97s use two screws on the outside that screw into the fender. The 01-04s have that compression clip thingy.
    Im not totally sure if you can put the compression clip on the 95-00 fenders or not honestly.
  6. Jan 20, 2021 at 9:23 PM
    cool_hand_pete
    cool_hand_pete lost, no idea: who when what or where
    Peter
    Houston, TX
    2015 DCSB 4cyl, 1999 4cyl 4x4 (2002 DCSB OR TRD, sold)
    2015, just a daily commuter. 1999 - mudding toy
    worked on steering & suspension over weekend( i didn't do it, a mechanic friend did)
    and last but not least ...
    SwampYota, Locot@co and nagorb like this.
  7. Jan 20, 2021 at 9:23 PM
    AV8R4LIFE
    AV8R4LIFE Aircraft Mechanic
    Jonah
    St. Augustine Beach, FL
    Black/2004/Toyota/Tacoma/PreRunner/2.7L I4/2WD
    Nice! Care to elaborate on how you combined the two and why? I'm looking into doing my exhaust at some point and am trying to learn as much as possible.
  8. Jan 20, 2021 at 10:12 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    no pics of the shiny new parts? o_O
  9. Jan 20, 2021 at 10:17 PM
    cool_hand_pete
    Peter
    Houston, TX
    All the parts I'm putting in are OEM or same quality, so I figured everyone knows what those look like.
    I figured the 21 year old, used and abused parts would be more fun to look at...
    Edit:
    For anyone in Houston area, look at my album, "work done so far"...
    if you need any of those used parts, let me know, I will hold on to them for a couple of weeks before I trash them.
    I will also post in local FB groups.
  10. Jan 20, 2021 at 11:06 PM
    malburg114
    Las Vegas, NV
    Ahh thanks for the info. I’ll get them to work as there’s not much left of the front at this point.
  11. Jan 20, 2021 at 11:45 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I spent the day recovering after a hard day working on my 1st gen yesterday. I replaced the sway bar end links and greased the drive shaft. So glad I did the end links, the boots on both of them were cracked all the way around. Now before you die laughing at all my hard work, take a look at my avatar, and you'll understand the needed recovery time. My dam arthritic hands hurt worst of all. I want to know how everyone is greasing the zerks on the cardan joint. I can't get my grease gun to snap on, and have to use a needle valve to grease them which is a major pita. Sorry no pics of the arthritic hands.
  12. Jan 20, 2021 at 11:50 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Haven't been to Big Bend since I was a kid. Great place to go fossil hunting if your into that.
    DashMaple[QUOTED] likes this.
  13. Jan 21, 2021 at 12:14 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I recognize everything else, so what is this part?
  14. Jan 21, 2021 at 7:06 AM
    cool_hand_pete
    Peter
    Houston, TX
    Antenna...whats left of it.
  15. Jan 21, 2021 at 7:40 AM
    eon_blue
    Azusa, CA
    My grease gun doesn't snap on to the zerk fittings easily either, it takes some pressure and moving it around while applying force to get it to attach. It can definitely be a pain to get it to connect to the zerks that are tucked into the cardan joints, usually getting it to disconnect is the more difficult part for me
    Stuffing a rag in there to wipe the grime and dirt off the zerks makes it go on more easily IMO.
    ToyotaDriver likes this.
  16. Jan 21, 2021 at 8:59 AM
    krustytaco
    krustytaco Well-Known Member
    2013 Taco Single Cab
    i need to grease everything on my truck. ran out of grease last time i was doing it and keep forgetting to order some
  17. Jan 21, 2021 at 2:09 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    speaking of grease guns, what brands does anybody recommend. My brother has a cheap piece of crap that leaks all over you while under the truck. I've looked at the pistol gripped LockNLoad and the Mcnaught K32. Anyone by chance using the PTS Pro Tools Solution grease gun coupler. I went ahead and purchased the Holt grease gun that harbor freight sells for $26.00. Seems to be made of decent metal, and at least it's not made in china.
  18. Jan 21, 2021 at 2:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I got a NAPA gun and had a local Parker make me a soft high pressure hose with the right fittings and a locknlube tip. It works
    krustytaco likes this.
  19. Jan 21, 2021 at 2:23 PM
    commandeeredwifestruck
    commandeeredwifestruck Member
    2003 1st gen 4 door 4x4
    Bumper w/winch, bilstiens all around, K&N intake, snugtop shell with racks
    I joined the tall and skinny club. 255/85R16 Cooper discoverer s/t maxx. They fit great with no rubbing even at full lock. I know I need to redo my grill. Good thing you can’t see the paint on the hood.
    JPinFL, ireymon, razhick4x4 and 4 others like this.
  20. Jan 21, 2021 at 3:46 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Source for latch?
