  1. Jan 27, 2021 at 2:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :luvya: I actually said they were great. But I guess I will retract that now so I fixed this for you. :)
  2. Jan 27, 2021 at 2:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :rofl:
  3. Jan 27, 2021 at 3:27 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    thanks fellas, ordered up!
  4. Jan 27, 2021 at 4:32 PM
    Orange01tAcO
    Orange01tAcO 2jz swapped 2001 tacoma
    Ephraim
    Beaver Utah
    2001 Orange 2jz swapped Tacoma
    2jz swapped, Manual swaped, Raptor lined and much more.
    This is what you need for a front axle
  5. Jan 27, 2021 at 5:41 PM
    Boba_Taco
    Boba_Taco Active Member
    Joe
    Asheville, NC
    2002 Tacoma TuRD SR5 3.4L 4WD
    For those of you who have ever had to do the “under the hood” temp change or what I like to call going into winter or summer mode, I finally found a replacement servo for my heat blend valve. Toyota wanted $230 for a new one but I just couldn’t pull the trigger until I found one at our local ‘Yota Gaveyard. I get to adjust the temp from the cab now, like a fancy person.
  6. Jan 27, 2021 at 6:23 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Oh, excuuuuuuze me. I guess I should take back my thanks then. :p
    So now I say the same to you as Monte - stop being such a downer. :luvya:
    Blackdawg and Digiratus[QUOTED] like this.
  7. Jan 27, 2021 at 6:30 PM
    Taco1Gen
    Taco1Gen Member
    Alan
    ‘04 Black Tacoma
    Front 2.5” strut extensions Rear 1.5” lifted (Perform. Nitro 9000’s) Running 265/75/16’s
    Threw some 255/85’s on the first gen today. D290117E-35F3-44B0-9006-4ABF3F6C509C.jpg
  8. Jan 27, 2021 at 8:17 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    I finished the process of Raptorlining my taco today
  9. Jan 27, 2021 at 8:19 PM
    eon_blue
    Azusa, CA
    Looks good, but it's gotta be a mortal sin to raptor liner an imperial jade mica 1st gen lol.
  10. Jan 27, 2021 at 9:10 PM
    Nicklovin
    Nick
    Tacoless
    Ha is it a rare color? Personally my clear was failing and I like this a hell of a lot better. Plus red brothers woo :bananadance:
    eon_blue[QUOTED] likes this.
  11. Jan 27, 2021 at 10:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They make colored and/or flavored lube now? What a time to be alive
  12. Jan 27, 2021 at 10:41 PM
    Nicklovin
    Nick
    Tacoless
    The paint was in crap condition, if it was clean I would've kept it. Clear was failing and things were starting to rust
    Digiratus and alee891 like this.
  13. Jan 28, 2021 at 6:08 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    Looks meaty with those on
    Taco1Gen[QUOTED] and m3bassman like this.
  14. Jan 28, 2021 at 7:26 AM
    Betsy-95taco
    Betsy-95taco Member
    Max
    Placer County
    95 Tacoma extra cab 4x4
    There it is. A little far away for me. I found a 87 JGW for sale nearby. Do you know which year waggys had the vacuum disconnect?
  15. Jan 28, 2021 at 2:34 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Sometimes it’s the little things. Replaced the drivers door handle and lubricated the passenger side (kept locking when pulling the handle).
    Also replaced the spare tire carrier. First time ever getting a flat in 16 years of driving and I had to use Kleins to cut the wire. You can see why.
  16. Jan 28, 2021 at 5:00 PM
    Orange01tAcO
    Ephraim
    Beaver Utah
    I don’t know that. I’m right here about 40 minutes away from this one. I don’t know if the axle is worth that much though.
  17. Jan 28, 2021 at 5:23 PM
    ccraider
    ccraider Well-Known Member
    Carson City
    If you do a search for Wagoneer on Reno C-list there’s always a guy selling Waggy axles and parts on there.
  18. Jan 29, 2021 at 5:43 AM
    An3
    Andrew
    What color paint did you use for the console? Want to do the same to mine
  19. Jan 29, 2021 at 6:37 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I used rustoleum charcoal. I did the seat sides in rustoleum graphite.
    An3[QUOTED] likes this.
  20. Jan 29, 2021 at 6:52 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @turbodb , just curious as to how long is this tunnel, would kinda creep me out driving through this.
    2stroke-Taco and Endless like this.
