  1. Feb 10, 2021 at 6:41 PM
    Running Board Man
    Running Board Man Well-Known Member
    That's a question for the epa
  2. Feb 10, 2021 at 6:58 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    @Speedytech7 answered it well. Likely because of the load it sees. Sized for the 3rz engine & tank
  3. Feb 10, 2021 at 7:17 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    My 97 2rz has it.
  4. Feb 10, 2021 at 7:52 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Pulled the cage out decided to put some weather striping on the bottom. There was a lot of dirt was bill up underneath from the first set up and water was getting to the bolts and rusted a couple of the previous ones. Took the trucks V-Card drilled new holes in the bed added new bolts. Locked in. Rear bumper off.
    0609E0CB-4E68-415E-99CD-D6DE0609F7C6.jpg 436A3FE2-DBF7-4C08-ADF1-9A432D734E79.jpg A2259230-50B6-47D3-9F31-DCB9DCC26072.jpg
    chrslefty, ontarioyota and SwampYota like this.
  5. Feb 10, 2021 at 8:18 PM
    vonellis
    Some and some more
  6. Feb 10, 2021 at 8:23 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I really need to get a family photo when the 01 is running again...
    vonellis[QUOTED] likes this.
  7. Feb 10, 2021 at 8:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Oof by then you'll have to rustore the rest of the family
  8. Feb 10, 2021 at 8:27 PM
    Empty_Lord
    Dan
    Ouch.
  9. Feb 10, 2021 at 9:12 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Has anyone tried these grommets yet.
    I'm wondering if you've had positive or negative results extending the life of your spherical bearings.
    Speedytech7 likes this.
  10. Feb 10, 2021 at 9:14 PM
    Speedytech7
    Older king models use to have those, wonder why it's not an option anymore when you order custom
  11. Feb 10, 2021 at 9:18 PM
    Empty_Lord
    Dan
    theyre good at keeping shit out. but also good at keeping shit that does get in, in
  12. Feb 10, 2021 at 9:31 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    I've been having a weird issue lately. When I rev it out to around red line and let my rpms drop back down the truck will stall. I've tested it a few times and it always happens.
    Could this be an IAC issue or a fuel system issue? I was leaning towards IAC since the truck seems to run fine otherwise and maybe a dirty IAC can't catch the truck from stalling in time when it drops in RPM from high revs?
    Any thoughts are much appreciated.
  13. Feb 10, 2021 at 9:36 PM
    Empty_Lord
    Dan
    my truck did this for the longest time after putting my magnaflow catback on. After doing the headers it stopped... is your exhaust modified?
  14. Feb 10, 2021 at 9:38 PM
    Speedytech7
    kinda sounds like a busted dashpot
  15. Feb 10, 2021 at 9:39 PM
    Empty_Lord
    Dan
    the autos dont have it.. i never really figured it out. the a/f would go SUPER lean. and after the headers it was fixed.
  16. Feb 10, 2021 at 9:40 PM
    Speedytech7
    AF going lean at top out on a toyota usually means the maf voltage went over 3.9... you flowed more than it expected
  17. Feb 10, 2021 at 9:41 PM
    Empty_Lord
    Dan
    usually. but i didnt have the fancy scanner back then to log all that.
  18. Feb 10, 2021 at 9:43 PM
    Speedytech7
    Kinda sounds like you ran right off the map, but coasting back down should give it tons of time to figure shit out and come back. I've never killed one that way, but who knows, the computers on these things are ancient. Lots of quirks hiding in there
    Running Board Man likes this.
  19. Feb 10, 2021 at 9:43 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    [QUOTE="An3, post: [/QUOTE]
    that mk2, with a 07k swap...
  20. Feb 10, 2021 at 9:45 PM
    Empty_Lord
    Dan
    i learned you could coast for miles, if you didnt touch the gas, it would die when you came to a stop. But if you tapped the throttle before coming to a stop thing would come back to life.. it was odd. but again. .the headers? problem completely disappeared.
