  1. Feb 17, 2021 at 5:59 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Finally went the switchback route. Got a setup from Ricky Evans on Facebook. Swapped out the relay and the rest was plug and play.
    love it! And now I have LEDs for rear blinkers and tail lights. All I need are decent LED reverse lights and the damned Dome Lamp... that stupid thing.
    while I was replacing the relay, I yanked out the linear spring and installed a brake pedal spring. What a difference!
    Silver02Taco likes this.
  2. Feb 17, 2021 at 6:01 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
  3. Feb 17, 2021 at 8:11 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    230 dont sound bad brotha
    DashMaple[QUOTED] likes this.
  4. Feb 17, 2021 at 8:14 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    It isn't, but I'd be waiting on parts then for him to do all the work to it. Might as well get an oem for $30 less at that point. If I hadnt found one within 2 hours of me I'd for sure go that route.
  5. Feb 17, 2021 at 8:38 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    If you don't plan on using it much it looks great! If you do, I think you'll find yourself getting hung up on the LCA and diff mounts.
    Lil Puke[QUOTED] and Dan8906 like this.
  6. Feb 18, 2021 at 7:46 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Got the busman put in and all wiring harnesses in. 7AC91C6C-921B-4EFF-977D-39009F75CE70.jpg1B44CC83-77D6-4AFF-B897-0E2EC44E0ABB.jpg
    Any have any pictures of where to tie in for a reverse camera? Preferably closer to the rear of the truck? I’ve read under the trim drivers seat or under the dash somewhere? Not 100% and I suck at electrical work.
  7. Feb 18, 2021 at 7:52 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Under the carpet directly under the driver seat is the electrical junction where the tail light and fuel pump harness plugs in. Your reverse light signal is in there
    Yossarian and vonellis[QUOTED] like this.
  8. Feb 18, 2021 at 7:55 AM
    vonellis
    Some and some more
    Thanks!
    Bulk/red ?2F658446-D31B-4603-86C9-DB235171F1FF.jpg
  9. Feb 18, 2021 at 8:01 AM
    Speedytech7
    Sure looks like if that's what that guy is tapping it is a Red wire with a black tracer (stripe)
    vonellis[QUOTED] likes this.
  10. Feb 18, 2021 at 8:02 AM
    vonellis
    Some and some more
    Cool cool thanks again I’ll try that spot later .
  11. Feb 18, 2021 at 9:25 AM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    Yeah I probably should’ve given a little bit more info on this. More than anything, it’s to protect the lower radiator area while trying to maintain a decent approach angle. I don’t wheel super hard or anything so I’m not as critical on performance as other people might be, but it still is a factor, so any constructive criticism anyone has to lend on this little build is appreciated.
    My longer term plan is to add on a second section that will cover the LCA mounts and Diff mounts. I want it to be separate that way I can quickly unbolt it for oil changes and alignments without having to dismantle the whole setup. I’m putting that off for a little while though until I build a better setup for bending tight a radius.
    Reh5108[QUOTED] likes this.
  12. Feb 18, 2021 at 9:55 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Technically Tuesday I guess, but I've been driving since I took the photo so it feels like today.
    Brought back some great memories, @Digiratus @Blackdawg.
  13. Feb 18, 2021 at 9:57 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Nice. I miss that place.
    jubei and turbodb[QUOTED] like this.
  14. Feb 18, 2021 at 10:28 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Im guessing it was not a warm as the last time we were there haha
    turbodb[QUOTED] likes this.
  15. Feb 18, 2021 at 10:43 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Such an awesome spot. Fun little hike down to the river too.
  16. Feb 18, 2021 at 11:09 AM
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    icicle mod in NC
    Das it mang likes this.
  17. Feb 18, 2021 at 12:43 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That’s one of my all-time favorite places, right there.
    I’m more than a little jealous :D
    turbodb[QUOTED] and Digiratus like this.
  18. Feb 18, 2021 at 1:28 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    It was pretty special to be able to show it to @mrs.turbodb, esp. after we weren't able to get there last year.
    Definitely cooler, but quite pleasant. 60's during the evening, high 40's at night.
    We went about halfway down in the morning. Decided to turn around and explore more of the plateau, rather than continue down. There's actually quite a bit of cool stuff that I hadn't seen the last time I was there.
    Getting there was a little nerve racking. Not because of the road, but because we'd stopped along the way - about halfway between the Bar 10 and the point - to do a little searching for rock art on some surfaces that seemed promising. As we were looking around, we heard a vehicle pass. Dang. Then, just as we were returning to the truck, a full-size truck with pop-up camper came rumbling down the road - so now two vehicles "in front" of us - didn't expect that in the middle of the week.
    We jogged the rest of the way back to the truck and a little speed allowed us to catch up to the pop-up, which thankfully pulled to the side. Then, as we got another mile or so down the road, here comes a rental jeep back up towards us. Our fingers crossed, we rumbled onto the plateau to find all the camp areas open. We took our pick, and then the pop-up folks eventually picked a spot over by the side canyon.
    Lucky us!
    jubei[QUOTED] likes this.
  19. Feb 18, 2021 at 2:04 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's where I tapped too, under the seat that is. 99% sure it's that black/red but you can always test it at the tail light pins to be sure. Or unplug the harness and test there.
    Speedytech7 likes this.
  20. Feb 18, 2021 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wonder how long it would take to crack the case haha you almost found out haha
