  1. Mar 11, 2021 at 1:00 PM
    HighPlainsTaco
    HighPlainsTaco I am haunted by waters…
    Ethan
    Comancheria
    2002 3.4L 4WD TRD
    Tacodude_93[QUOTED] likes this.
  2. Mar 11, 2021 at 1:34 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Personally I’m not a fan of the inset style mesh grilles. The grillcraft I have is my favorite of all the options.
  3. Mar 11, 2021 at 1:36 PM
    Shortman5
    Supercharged TRD
  4. Mar 11, 2021 at 2:08 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Like @Squeaky Penguin said, give a closer look at where the bed actually mounts.
    An3[QUOTED] likes this.
  5. Mar 11, 2021 at 2:41 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Raptor Lights are for Raptors. Even then I still think their dumb.
    The thing with the OEM 01-04 grill is that its the only Taco grill across all generations that has the vertical ribs which mimick the early 80's Toyota trucks. For that reason I think its cool as hell so I vote OEM.
  6. Mar 11, 2021 at 3:40 PM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    In preparation of removal of the 3" Spacer Lift, to the soon install of the OME Suspension Lift Kit, I sprayed all the nuts and bolt with Kroil.
    I also dropped the (never used) factory spare. I plan to relocate the Falken matching spare to a mount in the bed.
    Oh, I also removed the Sway Bar.
    nagorb likes this.
  7. Mar 11, 2021 at 3:42 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    I would have left it stock.
  8. Mar 11, 2021 at 4:07 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Sell me the Toyota emblem on the stock grill
  9. Mar 11, 2021 at 5:15 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Looks dope. Another benefit to the bare mesh is that you can run behind-the-grill lights if you're into that.
  10. Mar 11, 2021 at 5:16 PM
    eon_blue
    Azusa, CA
    I have the same one, it's a nice clean looking grill
  11. Mar 11, 2021 at 5:51 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    Got my new ScanGauge 2 plugged in. Still need to program and mount it, but....
  12. Mar 11, 2021 at 6:41 PM
    Running Board Man
    Running Board Man Well-Known Member
    Idle air control valve
  13. Mar 11, 2021 at 7:16 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm so shiny!
    Yetimetchkangmi, nagorb and SwampYota like this.
  14. Mar 12, 2021 at 6:23 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    From a few weekends ago. Got some new tail lights (reverse lights have been finicky since I replaced the clutch, gotta look into it more), finally got blinkers back for the longest time. Come to find out (after I drilled holes) they sent me 01-04 corner lights so until these break oh well. Also added bed stiffeners, had to do some finagling due to not fitting with the new tail lights so be ware of that
    Area51Runner, jubei, vonellis and 6 others like this.
  15. Mar 12, 2021 at 6:44 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    Which taillights are those? Want to upgrade my '96 ones
  16. Mar 12, 2021 at 6:45 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
  17. Mar 12, 2021 at 7:05 AM
    An3
    Andrew
  18. Mar 12, 2021 at 7:24 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Truck turns 22 at around noon today. (eastern time)
    Annual fun fact.
    Truck has never been disconnected from 12v power.
    jubei, Jiveydude, m3bassman and 5 others like this.
  19. Mar 12, 2021 at 8:48 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    After swapping out rear shocks, leafs, ubolts, and greaseable shackles, what’s the procedure for torquing what when? My current plan is below:
    Upper/lower shock bolts - torque in air
    Rear shackles/front eye - hand tight in air, grease them, drop truck, torque with truck weight
    U bolts - torque in air
    I know I’m getting in my head on this more than I should, but would appreciate some advice.
    Taco2021LB likes this.
  20. Mar 12, 2021 at 10:05 AM
    bodhi armor
    bodhi armor 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    UPDATE:
    After putting everything back together and driving it for a couple days, 100 miles or so, It sits like this...
    As you can see it has settled a good bit in that amount of time.
    Unfortunately the Left side sits about an inch higher than the right and I’m not sure why... :(
    285-75-16’s If anyone was wondering.
    The Right (lower) side is right where I want it to be. JUST the right height!
    Now if I can figure out how to get the left side down I’ll be a happy camper.
    I torqued my bolts to spec today because it was suggested on another thread that I tighten the leaf and shackle bolts to about half torque, then drive for a while before torquing them completely so They can settle.
    What can I do to level the Right and left side of the truck???
