  1. Mar 14, 2021 at 3:04 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Dang that sucks.
    I had similar happen during a water crossing, didn't realize till steam started coming out the hood. But it's a pretty easy fix luckily.
    ireymon[QUOTED] likes this.
  2. Mar 14, 2021 at 3:10 PM
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    Total bonehead moment, after I got it buttoned back up I stared at the engine making sure i got everything hooked up and back together and didn't even think about the 1/2" ratchet on the crank bolt.
    it's my DD so I need to find something hopefully within the next day or two!
    Edit: luckily i can work from home all week if I have to but it's nice to have 2 working cars in case the wife is at work and I have to pick up kids or something.
    Das it mang and nagorb[QUOTED] like this.
  3. Mar 14, 2021 at 3:18 PM
    Longfellow
    Longfellow Member
    NH seacoast
    2004 TRD Xtracab Black
    First time installing a radio. PO had glued the A/C knob on in the middle so that was forced off. Autozone had some spare random knobs and I was lucky to find one that fit and glue her in. Sony xav-ax1000 was 299 on crutchfield. Pretty sweet with volume knob and carplay. Velcro'd the bluetooth mic behind the pimp cane e brake.
  4. Mar 14, 2021 at 3:18 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Lol, I can't say I haven't made my share of similar dumb mistakes. I picked up a replacement from O'Reilly's, been going good for 8ish years.
  5. Mar 14, 2021 at 3:51 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I thought I put plenty.
  6. Mar 14, 2021 at 4:05 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    Did you check the crank bolt torque after this happened? Back in the day that’s how I would loosen that bolt if I didn’t have room for an impact gun.
  7. Mar 14, 2021 at 4:24 PM
    ireymon
    Kenneth
    Winston-Salem, NC
    not yet, i threw in the towel for today. good call on checking it though!
    Das it mang and m3bassman like this.
  8. Mar 14, 2021 at 4:24 PM
    Krogers128
    Krogers128 Well-Known Member
    Kyle
    WA
    1995.5 Paradise Blue Tacoma SR5 V6
    OME complete kit. 881 coils. Dakar Leafs. JBA UCA. 265/75-16 Goodyear Ultraterrain.
    Reporting back with dog photos after building a platform for her last week, took a few days to get to know one another before we took a ride. Her name is Penny and she loves riding in the truck!
    5280, jubei, CS_AR and 18 others like this.
  9. Mar 14, 2021 at 4:45 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I did on my 2nd gen. Wouldn't hesitate to do it on the 1st gen.
    Will be tough to drill without pulling, but not impossible. You'll need to drill though the arm, outer sleeve, and bushing, but stop when you hit the inner sleeve. You'll also probably need to loosen your cams to grease it properly.
    I swear you can never have too much grease for poly bushings. I put a zerk on everything I can at this point.
  10. Mar 14, 2021 at 4:56 PM
    Krogers128
    Kyle
    WA
    Why thank you! She was very timid at first, I assume from leaving her litter/mom, a new home, transport from Texas, but she is really coming around now! Looking forward to taking her with us on adventures in the truck.
  11. Mar 14, 2021 at 5:14 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    I feel like I’m on repeat! Repined repeat replace! Gremlins!13A4BEAC-0E1A-43E0-BB46-3B0E2FC6720C.jpg
    Das it mang likes this.
  12. Mar 14, 2021 at 5:29 PM
    bodhi armor
    bodhi armor 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Im having trouble adjusting my kings?
    Firstly, In order to loosen the collar, I’m having to push on the Allen wrench so hard I’m afraid I’m going to break something..
    Second, I have a spanner wrench but the shock collar only has 4 holes to insert the round peg into. While still installed I can’t get the spanner into any of them..
    Should I remove the coilovers to adjust them?
    If I remove them, is it as easy as removing the big bottom bolt, then the 3 top nuts to pull them out? Or are there additional steps?
    I definitely can’t afford to F@&K something up right now.
    Thanks
  13. Mar 14, 2021 at 5:47 PM
    KevinButler35
    KevinButler35 Active Member
    Charlotte NC
    1998 Single Cab Tacoma
    2.5'' Bilstein 5100 Lift Kit Limited 4runner seats
    Found some seats out of a 3rd Gen 4runner Limited. After lost of drilling and swapping brackets the seats are installed. Feels WAY better than the 23 year old cloth seats that where in it.
  14. Mar 14, 2021 at 5:51 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Shock will pull out super easy just removing those 4 bolts you mentioned. Couldn't hurt to pull it to check your lower spherical bearings for wear and play. They should be tight not loose.
    If you're trying to crank the coilovers down for more lift it will be hard but not impossible depending on how strong you are.
    Personally the spanner wrenches suck. The pin will bend and then fall out if the handle. A better cheaper option is to go buy a pack of pry bars from orielys and then pick the second longest one then grind the tip down to fit the holes. The steel is stronger and the bar is longer for better leverage.
    Then you put the longest pry bar on two of the studs and the one on the collar and pry both together or whatever direction you want to go.
    Note I did mine straight but if you left the angled tip on and ground it down it would actually be useful on the truck itself.
    Again it will be hard to add lift as you'll be fighting the coil and is not recommended. If you're lowering it it'll go just fine.
    Seagull233, SwampYota and ontarioyota like this.
  15. Mar 14, 2021 at 6:07 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Anybody have any advice for cleaning this grunge without it falling into the passage?
  16. Mar 14, 2021 at 6:21 PM
    howied
    howied Well-Known Member
    stuff it with paper towels and then vacuum before you pull the paper towel out?
  17. Mar 14, 2021 at 6:27 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Looks great I just swapped my old ones out for new ones in my 4runner today.
  18. Mar 14, 2021 at 6:42 PM
    Shortman5
    Supercharged TRD
    Easy there. No need to be sarcastic about it. there’s junk all stuck to the side right below the surface. I need to get that out of there without any falling down. If I stuff anything in there I might scrape some off and it’ll fall in.
  19. Mar 14, 2021 at 6:45 PM
    KevinButler35
    Charlotte NC
    Have you used any leather conditioning products on the seats before? What works best for these seats?
  20. Mar 14, 2021 at 6:53 PM
    Tour991
    James
    South Reno/Tahoe
    I have not, but I will be looking for something good.
