  1. Mar 15, 2021 at 9:49 AM
    eon_blue
    Azusa, CA
    No bushings on Kings/ADS/Icons etc. just spherical bearings and misalignment spacers
  2. Mar 15, 2021 at 9:53 AM
    Running Board Man
    Running Board Man Well-Known Member
    Oh I thought y'all were talking about the typical poly squeeking subject
  3. Mar 15, 2021 at 10:23 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Spanners come with different "arcs" and even "adjustable" with improvised scratch guards.
    Between these I can usually get er done on the truck. Disregard for 2.5" shocks.
  4. Mar 15, 2021 at 10:25 AM
    eon_blue
    Azusa, CA
    My Kings came with a big punch for adjusting the collar, not a spanner wrench like the Icons use.
    Looks like this except mine doesn't have the T handle.
    The Allen bolt is probably just a little stuck, as long you're turning it the right way to loosen it, just keep going until it breaks loose. Make sure the Allen key is all the way in and it's free of any dirt/grime so you don't strip it.
    I've always been able to adjust my Kings with them still on the truck, getting around the UCA can be a little tricky but I haven't had any issue with it. I think it might depend on your UCAs though.
  5. Mar 15, 2021 at 10:42 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Link?
  6. Mar 15, 2021 at 10:44 AM
    eon_blue
    Azusa, CA
  7. Mar 15, 2021 at 11:35 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Went to a Toyota grave yard today that I’ve never been to got a couple of goodies. DB3616BC-BF63-437A-95A9-97FC9431E992.jpg9DE6D869-7B2B-47AB-ACFE-BDD8EDF81FA6.jpg
  8. Mar 15, 2021 at 11:36 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    We have one of those?
    Wut
  9. Mar 15, 2021 at 11:44 AM
    vonellis
    Some and some more
    It’s in Lehi just of I-15 Japanese auto parts 2501 n 200 w dude has everything we’ll all most everything
    Yetimetchkangmi likes this.
  10. Mar 15, 2021 at 11:45 AM
    JKO1998
    Utah
    That's good to know about, thanks.
  11. Mar 15, 2021 at 3:22 PM
    badboypro
    badboypro Well-Known Member
    Sunnie
    Pittsburgh, PA
    1997 Tacoma SX
    Boy does that red really pop. Looks great!
    vonellis[QUOTED] likes this.
  12. Mar 15, 2021 at 4:28 PM
    bodhi armor
    bodhi armor 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Good to know. When I bought the kings, King wanted $90 for a spanner!!
    The FOX version was $40 and it “looked” the same, but I suppose it’s not
  13. Mar 15, 2021 at 8:54 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
  14. Mar 15, 2021 at 9:30 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    It's not an issue, I have them and they spray out easily
  15. Mar 16, 2021 at 8:19 AM
    Stevegraces
    Stevegraces Active Member
    2000 Tocoma base
    S’up Mang!? If i slam jam it at speed it bottoms out and bows my fender out straight up from center,you can also see that little humdinger just behind center where the fender buckled. Because those Fabtech lift spindles push the wheels outward that 2-3” you reffered to awhile back,but its not a racetruck so i wont be doing that again. Then,it rubbed at the fender trim,so i measured the clearance at the bottom right end (toward the front) where the fender meets the plastic. Then i dotted it with a sharpie for a reference,looked at it,eyeballed in the line to match the angle that the fender starts coming down at,inked it in for a final line i was happy with,and trimmed it off with my tin snips. There was a limit to how far away from the tire i could go because of the bumper/inner fender mounting hard plastic doohicky. Then i trimmed some of the side out going forward too as you can see. I only did that so i can look in from the side without having to crawl under the front for whatever reason may come up. I may trim it all the way across the front and remount the license plate. To give it the illusion of more ground clearance.
    Das it mang likes this.
  16. Mar 16, 2021 at 8:27 AM
    Stevegraces
    2000 Tocoma base
    9134EE75-68D2-41A1-8A7F-F42DD6E0DD15.jpg Hey Mang,take a look at this picture of my front bumper,ad opposed to yours. The steel portion of my bumper doesn’t come all the way back like yours does. Yours will alot harder to trim than mine was. EDFB6968-F7F6-46E4-9AB6-61ECBE8D5020.jpg
  17. Mar 16, 2021 at 2:32 PM
    benUPnorth
    benUPnorth Member
    Ben
    96 Tacoma
    Im whooped but this afternoon i installed a OME kit on my truck. Coilovers in the front just swap in no problem. On the rear i got new brake line,shackles, leaf pack, and shocks. It was a pain in the dick to do by myself. I gained 4” in the front with 882 coils and i gained 3” in the rear but i had a stock leaf pack with an add a leaf. My wife said stop spending money I said no problem i just need some wheels and tires hahaha
  18. Mar 16, 2021 at 2:57 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    882's on a single cab?
    Im interested to see what your CV angles look like.
  19. Mar 16, 2021 at 2:58 PM
    benUPnorth
    benUPnorth Member
    Ben
    96 Tacoma
    881’s sorry
  20. Mar 16, 2021 at 3:00 PM
    benUPnorth
    benUPnorth Member
    Ben
    96 Tacoma
    Correction. 6F445F64-C545-4495-9D1D-43FAB150E898.jpg 881’s
