  1. Mar 16, 2021 at 3:07 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    You're likely going to tear the boots pretty quickly with the fins touching. Diff drop may help just enough.
  2. Mar 16, 2021 at 3:49 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Hope your good at changing em.
    benUPnorth[QUOTED] likes this.
  3. Mar 16, 2021 at 3:54 PM
    benUPnorth
    benUPnorth Member
    Ben
    96 Tacoma
    My cv’s only spin when i tell them to
  4. Mar 16, 2021 at 6:01 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I'm going to look real dumb for a second, even if it's a regular occurrence. I plead ADD hubs.
    Isn't "cv's only spin when I tell them to" the way manual hubs work?
    benUPnorth, eon_blue and Fernando like this.
  5. Mar 16, 2021 at 6:03 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    It is with manual hubs
    benUPnorth likes this.
  6. Mar 16, 2021 at 6:03 PM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    I took mine for some Swaybar Delete / Pre-OME Lift playtime.
    Flare side Taco Lover likes this.
  7. Mar 16, 2021 at 6:17 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    I was about to say I'd go around with an angle grinder, sketch it out and cut them like this guy did. If u smacked once u will again unless u address it. Looks good so far tho!
  8. Mar 16, 2021 at 6:17 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Yes, that is how manual hubs work.
    You do not look dumb for asking that question.
  9. Mar 16, 2021 at 6:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Either way..thats too much lift. Those poor CVs and ball joints. Ouch.
    turbodb and m3bassman like this.
  10. Mar 16, 2021 at 8:09 PM
    tpeavy
    tpeavy New Member
    taco2021,
    which shell is that on back? been looking for one for mine
  11. Mar 16, 2021 at 9:06 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    It's a Leer 100XQ
  12. Mar 16, 2021 at 9:09 PM
    jesus619taco
    jesus619taco Well-Known Member
    The good stuff
  13. Mar 16, 2021 at 9:11 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's always good when the thrust bearing shits itself out in pieces
  14. Mar 16, 2021 at 10:58 PM
    MOTACO
    MOTACO Well-Known Member
    SW Missouri
    Tacoma 4x4
    Proper air pressure in tires, clean windows, coins under seats.
    Be sure to rotate your crankshaft by hand until the valves are closed on that port before cleaning it.
  15. Mar 17, 2021 at 4:31 AM
    KevinButler35
    KevinButler35 Active Member
    Charlotte NC
    1998 Single Cab Tacoma
    2.5'' Bilstein 5100 Lift Kit Limited 4runner seats
    I added power seats to my tuck this past weekend. Where would it be easiest to get power for the seats? I just need power and ground and both seats would function. Is there a wire or two in the cab I can tap into that can carry the load?
  16. Mar 17, 2021 at 7:16 AM
    Duderz7
    Duderz7 Member
    Dann
    95.5 Tacoma SC 3.4 4x4
    Stock
    Speaking of seats, what would bolt into a 95.5 single cab 4x4? I'd like to replace the worn buckets someday. Somebody said something about some acura once but didn't know model or year.
  17. Mar 17, 2021 at 8:39 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Only bolt in seats are other Taco seats.
    Taco critter likes this.
  18. Mar 17, 2021 at 9:12 AM
    2stroke-Taco
    2stroke-Taco Well-Known Member
    Nick
    ‘98 Tacoma SR5
    looks good, primary colors :thumbsup:
  19. Mar 17, 2021 at 9:14 AM
    Wulf
    rock raisin
    excluding aftermarket seats/brackets for $$$$
    Seagull233 likes this.
  20. Mar 17, 2021 at 9:15 AM
    2stroke-Taco
    Nick
    ‘98 Tacoma SR5
    dang.. you ain't kiddin' about mall crawlin'.. looks good
