  1. Mar 20, 2021 at 1:16 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    What?
    Taco critter likes this.
  2. Mar 20, 2021 at 1:34 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah say what?
  3. Mar 20, 2021 at 1:56 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    If the rear pads are adjusted properly and there’s no more adjustment on the rear cable then my guess is it’s stretched
  4. Mar 20, 2021 at 3:20 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    It's all good, just didn't know if I needed to go smack talk some one.
  5. Mar 20, 2021 at 6:50 PM
    badboypro
    badboypro Well-Known Member
    Sunnie
    Pittsburgh, PA
    1997 Tacoma SX
    Definitely an easy and basic 'mod' but it's the little things, right?
    Took advantage of the beautiful weather here in Pittsburgh today by cutting down sanding down some 2x10 treated lumber. As many of you know, the little slots in our Taco's bed accommodate for a 2x; just cut your stock down to 60", taper in by 4 degrees on either side, round off the edges, and you'll get a nice a snug fit. No more Trader Joes bananas flying everywhere...
    I came across a Milwaukee Packout container so I'm using it to house bungees/carabiners/cargo-net/ratchet straps. I'm quite happy with it, I'd recommend for anyone looking into a heavy duty water resistant bed storage solution. I also use it for miscellaneous hardware, rope, gloves, simple first aid kit, etc. Hooked into the bed's corner hooks with a heavy duty bike cable/lock. The cable is definitely still cuttable but at least I'll hear it happening... and the bolts holding the corner hooks in are seized beyond belief :)
  6. Mar 20, 2021 at 7:30 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    chrslefty likes this.
  7. Mar 20, 2021 at 7:31 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Its so clean.
    ChaseBOOM[QUOTED] likes this.
  8. Mar 20, 2021 at 7:58 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    That’s a very useful modification… Great job! The Toyota bedliner sure allowed to make that happen.
    Have you popped out the bedliner to see what your bed is like underneath? Might be worth a peek if you haven’t.
    badboypro[QUOTED] likes this.
  9. Mar 20, 2021 at 8:00 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Drove my 1st Gen to the hardware store, to buy more thinset... so I could finish another project.
    The list of projects doesn't seem to be getting shorter though.
  10. Mar 20, 2021 at 8:13 PM
    Duderz7
    Duderz7 Member
    Dann
    95.5 Tacoma SC 3.4 4x4
    Stock
    Mine was missing the pivot bolt just left.of the pumpkin on the rear axle when I got. Parking rake barely worked until I replaced it.
  11. Mar 21, 2021 at 2:35 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Battery light is flickering. Besides a bad alternator, any other causes?
    Running Board Man likes this.
  12. Mar 21, 2021 at 5:38 AM
    0xDEADBEEF
    Loose wire somewhere, like a battery cable or on the back of the alternator.
    malburg114[QUOTED] likes this.
  13. Mar 21, 2021 at 6:12 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    How long do you think it takes to reset the ECU after the battery was disconnected? I went to smog it and my OBD is not reading. Everything else passed. I have put about 100 miles on it since i picked it up from the shop
  14. Mar 21, 2021 at 6:23 AM
    0xDEADBEEF
    Fernando[QUOTED] likes this.
  15. Mar 21, 2021 at 6:28 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  16. Mar 21, 2021 at 6:33 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    If it's all good under there, give it a coat of wheel bearing grease, if you are putting the bedliner back in. Just use an old paint brush, and apply liberally to all the surfaces. Saved my bed for many years.
  17. Mar 21, 2021 at 7:21 AM
    badboypro
    Sunnie
    Pittsburgh, PA
    1997 Tacoma SX
    Thanks! Admittedly a bit too scared to do that because I'm worried about what I'll find... though the bed looks A+ from the underneath. Have a bit of scraping/minimal surface rust right at the tailgate with water run-off but otherwise I'm hoping it's clean....
    At some point I'll be pulling it out to do what @Seagull233 kindly recommended though.
    ontarioyota[QUOTED] likes this.
  18. Mar 21, 2021 at 7:28 AM
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Could you feel a difference?
    Tour991 likes this.
  19. Mar 21, 2021 at 9:27 AM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    That’s a great idea!
    My buddy just pulled the bedliner out of his 93 Chevy that he only drives in the summer and the bed is all rotten… Your idea would’ve saved it!
  20. Mar 21, 2021 at 10:02 AM
    02blancotaco
    02blancotaco Well-Known Member
    Colby
    02 Toyota Tacoma 4x4 Trd
    yessir RPT1s!
