  1. Mar 22, 2021 at 3:14 PM
    eon_blue
    Azusa, CA
    I always treat myself after passing smog every two years, I've got the right certs for my supercharger and headers but the URD 7th injector is most definitely a fail-on-the-spot mod in CA.
    Luckily they just haven't noticed it lol. Or have any idea what it is. Still makes me sweat a little each time though.
  2. Mar 22, 2021 at 4:25 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Would you replace the expansion plugs?
  3. Mar 22, 2021 at 4:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only if you're confident in your ability to replace them. They look scabby enough that I'd want to replace them, but it's not really a fun process.
  4. Mar 22, 2021 at 4:31 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I was using Phillips head bolts but it was a PITA but the Allen bolts are so easy to deal with. I wanted to go black bolts and swap out the little brackets for black too but black Allen bolts always seem to rust.
  5. Mar 22, 2021 at 5:29 PM
    Shortman5
    Supercharged TRD
    From what I’ve seen it looks simple enough. Use something like a flat head screwdriver to knock it halfway in and pull it out with pliers then TRV the new one and tap it in with a seal punch.
    Am I missing anything?
  6. Mar 22, 2021 at 5:33 PM
    Speedytech7
    No, but you wouldn't believe how many ive seen leak because they're over driven or under drive
  7. Mar 22, 2021 at 5:52 PM
    eon_blue
    Azusa, CA
    No meth either, there's no CARB approved meth kit for our trucks that I know of anyhow.
    Yeah the fuel line for the 7th is really all that stands out, so I just wrapped it in black electrical tape. Once dirty it looks like any other vacuum line in there
    Wulf and m3bassman[QUOTED] like this.
  8. Mar 22, 2021 at 6:47 PM
    Shortman5
    Supercharged TRD
    I didn’t see any pinholes in the crossover pipe, but by judging by the look of the center plug and the manifold gaskets it probably either or both.
    Another decision I have to make is to pull the exhaust studs out or to leave them in an reuse the factory hardware. In that case I’m going to have to hope that jacking the engine up enough will allow me to slip the JBA header in. Otherwise I’ll be forced to install the LCE studs I have to get it in since you have to remove 4 of them anyway to get it in.
    ontarioyota likes this.
  9. Mar 22, 2021 at 7:05 PM
    Speedytech7
    Fuck dude, the coolant crossover port is roached. There's your leak haha. Gonna need to really work to seal that back up.
  10. Mar 22, 2021 at 7:29 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Thats just black oxide, not really for use for anything that doesn't stay oily. You can get SS black oxide and will not rust. Check out McMaster Carr, they're expensive, but easy to search.
    0xDEADBEEF likes this.
  11. Mar 22, 2021 at 7:37 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    BoltDepot has been really good for me. Not quite the selection of mcmaster, but the prices are excellent, especially if you need a bunch of'm.
    nagorb[QUOTED] likes this.
  12. Mar 22, 2021 at 7:40 PM
    Shortman5
    Supercharged TRD
    It all cleaned up I think. I’ll have to get some pictures tomorrow.
  13. Mar 22, 2021 at 8:12 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I've used them as well, they're good. I usually use McMaster to start my searches if it's something I'm unfamiliar with. Their customer service is amazing though.
    0xDEADBEEF[QUOTED] likes this.
  14. Mar 22, 2021 at 9:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It's too clean. Looks outa place. Need to get it dirty. :rolleyes:
    ToyotaDriver likes this.
  15. Mar 22, 2021 at 10:00 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    look closer...you'll spot some fresh..uh..dirt ha
    Digiratus[QUOTED] likes this.
  16. Mar 23, 2021 at 6:42 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    BYJOSHCOOK likes this.
  17. Mar 23, 2021 at 7:01 AM
    Phessor
    Phessor Well-Known Member
    Hey, that's what I do...
    m3bassman[QUOTED] likes this.
  18. Mar 23, 2021 at 7:24 AM
    Shortman5
    Supercharged TRD
    here it is with the gunk scraped off. It feels pretty smooth to the touch. And from what I can tell no pitting that I can feel. Picture probably looks worse than it does in person.
  19. Mar 23, 2021 at 7:52 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It needs professional help.
  20. Mar 23, 2021 at 7:58 AM
    Speedytech7
    I'd pull the studs, block the ports, and scotchbrite it first to see if it cleans up, if it doesn't then I'd three stage sand it with a flat block. That's not looking hot though, I've sealed some nasty shit with blue hylomar, but that's not even clean enough for that yet.
    Running Board Man likes this.
