  1. Mar 25, 2021 at 4:14 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Who else has tried to teach a tow truck driver about off road recovery and failed? :annoyed:
  2. Mar 25, 2021 at 4:17 PM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    I'm a poser that way.
  3. Mar 25, 2021 at 4:17 PM
    Pyrifera
    Oregon
    Icon makes black ones
    Tour991 and AssQuake[QUOTED] like this.
  4. Mar 25, 2021 at 4:18 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I had some on my back shocks, and all they did was keep shit in, but they were rubber so, who knows.
  5. Mar 25, 2021 at 4:20 PM
    Pyrifera
    Oregon
    The rubber cover I have on my rear Icons I put on in hopes that it would keep rocks from flying up at speed and pitting the exposed shafts. Maybe I should pop them off and see if I have a collection of "stuff" trapped inside.
  6. Mar 25, 2021 at 9:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Dan8906[QUOTED] likes this.
  7. Mar 26, 2021 at 7:17 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
  8. Mar 26, 2021 at 7:24 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I go other way around, trans > external cooler > radiator > trans if I don't use a thermostat
    That way it still warms up fast in winter and can still cool the excess heat in summer
    DashMaple[QUOTED] and Digiratus like this.
  9. Mar 26, 2021 at 8:13 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The cooler Mike linked has a bypass to help fluid warm up time in the winter. I have mine after the radiator, doesn’t really matter though. Still would work fine the way you routed it.
    I also put a Magnefine filter in-line after the external cooler because why not.
  10. Mar 26, 2021 at 8:14 AM
    Speedytech7
    Well that's a neat feature. Never seen a thermostat built into a cooler before
  11. Mar 26, 2021 at 8:31 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I was thinking of black bags on the kings. they get nasty in the winter.
  12. Mar 26, 2021 at 8:42 AM
    JKO1998
    Utah
    It’s like they’re the same shock
  13. Mar 26, 2021 at 9:00 AM
    Tour991
    James
    South Reno/Tahoe
    This time they are only dirty not busted!
    JKO1998[QUOTED] likes this.
  14. Mar 26, 2021 at 9:45 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    What’s the torque rating for the lower coilover bolt?
  15. Mar 26, 2021 at 9:46 AM
    eon_blue
    Azusa, CA
    From my torque sheet, says LCA to shock absorber - 101 ft/lbs (may vary with aftermarket equip)
  16. Mar 26, 2021 at 10:02 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That's what I use. That's 3 uhgaduggas on the Milwaukee. :D
  17. Mar 26, 2021 at 10:05 AM
    Dan8906
    Daniel
    Concord, California
    I think I may have done 5 uhgadugass on the 1/2” Milwaukee and I blew the bearing out it’s so noisy. I thought the ptfe fixed it but I’ll just order a new one and replace it
  18. Mar 26, 2021 at 10:06 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Ready for the oceano dunes
  19. Mar 26, 2021 at 10:07 AM
    eon_blue
    Azusa, CA
    Get there while you can, heard they officially are going to close it for good soon. Sometime over the next few years, probably going to phase it out slowly.
    It can be fun if you go when the crowds aren't there, but when there are crowds I can't stand the place.
    Reh5108 likes this.
  20. Mar 26, 2021 at 10:19 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've never been but I constantly see new litigation to shut it down. It's a bummer to see so many people against people having fun just because it isn't an activity they participate in.
