  1. Mar 30, 2021 at 7:24 AM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    I do have an OME Lift with 882s and Dakars.
    Are the steering bushings something I need to keep a watch on?
    I don't plan to wheel hard core.
  2. Mar 30, 2021 at 7:47 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    You don't have to 'wheel hard core'.
    Check for slop in the steering rack, if there is excessive play then replace them. If you've invested the money and time into a suspension lift, then do it right. You'll definitely notice a difference.
  3. Mar 30, 2021 at 8:17 AM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    Copy that, and Thanks.
    My truck has never been wheeled previously, so I'm green to the scene.
    But I'm learning a lot, from those who share like yourself!!
    Currently, everything is pretty tight on my rig.
    betterbuckleup likes this.
  4. Mar 30, 2021 at 10:51 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    With the sleeve broken at the welds like that, does your rack make any odd noises when turning on flat ground stationary?
    Mine sort of creaks and pops and i'm wondering if I might have the same sort of thing.
  5. Mar 30, 2021 at 12:01 PM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    Tour991[QUOTED] likes this.
  6. Mar 30, 2021 at 12:19 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    This looks clean
  7. Mar 30, 2021 at 12:19 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was wondering if you had the CS144 too since I have it and it gets around 14.3 usually. Maybe the CS144 with a diode is the easiest solution if you already have the big 3 upgrade and CS144.
    I am at around the same too, 14.3 when it's running normal.
    I thought that was more of a second gen thing but it seems like I would benefit from it too, especially since I want to go duals and have no interest in fucking with solar.
  8. Mar 30, 2021 at 2:46 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Didn’t someone sell a big 3 kit? I need to do that as well.
  9. Mar 30, 2021 at 2:52 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I bamatoy used to, but it's easy enough to make yourself. Welding cable, some lugs and a lug crimper and it's easy. It's actually like a big 5 upgrade because there are more than just 3. I need to look back at what it was though.
    Dan8906[QUOTED] likes this.
  10. Mar 30, 2021 at 3:08 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Not that I'm aware of. There a nice fine rusty crack line around the weld though. Pretty easy to see.
  11. Mar 30, 2021 at 6:37 PM
    FlipSideUp
    FlipSideUp Active Member
    Went Skinny!
    I've been running 32s ever since I first lifted this truck 16 or so years ago.
    My Cooper STTs had run their course and after reading that Expeditions West article by Scott Brady, I decided to go with skinnies.
    All I can say is... WHAT A DIFFERENCE! I love the way it rides.
    But what's interesting is this...
    20210330_202817.jpg I had to take her out on the road to see the effect of these tires on actual (Waze GPS) vs indicated speed (speedometer). These are the results:
    Indicated 20mph = Actual 20mph
    I 30mph = A 30mph
    I 40mph = A 40.5mph
    I 50mph = A 51mph
    I 60mph = A 61mph
    I 70mph = A 71mph
    ireymon, UtahTacoma02, nagorb and 2 others like this.
  12. Mar 30, 2021 at 7:13 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I feel a bit ridiculous trying to explain this stuff to a bunch of dudes who know more about it than I do :oops:
    One of life’s lessons, sometimes it’s better to listen than speak- all info is appreciated
    vonellis and betterbuckleup like this.
  13. Mar 30, 2021 at 7:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No reason to feel that way. All info and experiences are good and worth sharing.
    Laxtoy[QUOTED] and m3bassman like this.
  14. Mar 30, 2021 at 7:44 PM
    kvalleyvet
    kvalleyvet Active Member
    03 XtraCab 4x4 M/T
    Replaced the gasket around the transfer case shifter. I should have done it when I bought the truck.
  15. Mar 30, 2021 at 8:12 PM
    betterbuckleup
    Ian
    Concord, CA
    After replacing mine and having it leaf again later down the line, I ended up just using silicone as a gasket between the two.
    Running Board Man likes this.
  16. Mar 31, 2021 at 11:36 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Don't feel that way at all. Even though I have both that alternator and an AGM battery, I am not really sure if the AGM is achieving it's full charge, especially with how little I drive it. I always figured 14+ was enough but it seems like I was incorrect there too. Half the shit I do I learned from youtube or make up as I go along so I'm flying by the seat of my pants man.
    All of this ^
    ToyotaDriver and Laxtoy[QUOTED] like this.
  17. Mar 31, 2021 at 12:53 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    While it's true an AGM likes higher voltage charging. The amount of "under charge" (1st gen/CS144) is minimal and inconsequential in the real world.
    This from Northstar.
    Will there be a list of vehicles that we do not want to sell product into because of their alternators?
    No, the number of vehicles and systems that exist today would make it difficult to identify, manage and update a list on a regular basis. So instead we have set the charging parameters of between 14.1 volts and 14.8 volts as an acceptable charging range. So long as the battery charging remains within these tolerances the battery will perform to its engineered specifications. It is recommended that for every application the customer test the charging voltage to ensure it is within the acceptable limits.
  18. Mar 31, 2021 at 1:53 PM
    ak97taco
    ak97taco Well-Known Member
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Exterior 2.5" leveling kit Rocktrix 17" wheels 285/65/17 Yokohama Geolandar's Leer shell Diode Dynamic fogs Morimoto XB Amber headlights Alpharex taillights Body Armor Hiline bumper Prinsu roof rack TRD Pro Grille Caliraised LED 42" amber light bar 2 - bumper light bars and 2 pods behind grille Overland Equipped aux power tray Meso Customs puddle pods with switch Interior LED light kit Meso Customs stealth pro shift knob Oostroma dual latching relay for shift knob Clazzio leather seat covers Clazzio seat warmers Quick charge USBs Dual, amber & white lightbar switch from Cali Raised N2 Designs remote start with app Meso customs interior black out kit AJT Designs interior black out kit Taco Garage DSM phone mount
    Replaced my shifter bushing finally, every gear could move around like neutral :eek:
    kvalleyvet, nagorb and SwampYota like this.
  19. Mar 31, 2021 at 3:10 PM
    halfbid
    halfbid Well-Known Member
    Central Oregon
    1996 Tacoma DLX 2.7L, 5 speed, 4wd
    I’m finally getting around to removing my driver door panel to inspect a few issues that had been worsening with time. The door handle was acting odd, it seemed like unless I grabbed it right above the key cylinder it would rise more on the left than the right and I felt like it was going to break. I was hoping it was a loose nut or something simple.
    Everything seemed secure, I blasted some silicon spray in there and wiped away as much of the grime as I could which seemed to help. The other nuisance issue was the key lock. Every time it would take two tries. The first try it wouldn’t go all the way, but it would always pop the lock the second time. The same treatment on the little pivot point where it was hanging up seemed to fix this too.
    Aside from a thorough cleaning, what else should I do in there?
    Are there any things I should grease? Is the silicon spray enough for the handle or should I use some type of grease? I've seen people say to grease the door handles as a regular maintence item. I'm not really sure where they are refering to unless it is where the door actually latches to the body.
    Also, does anyone know what the black adhesive holding the plastic to the door body is?
    The plastic is toast, I’m not able to remove it without the plastic falling apart. I think if someone can help me figure out what the adhesive is I will just replace it with some visqueen.
    kvalleyvet likes this.
  20. Mar 31, 2021 at 3:15 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I believe it's Butyl tape.
