  1. Apr 3, 2021 at 9:25 PM
    philksigma82
    philksigma82 Active Member
    1999 Red Tacoma, Regular Cab 4x4, 2.7L
    It's pretty straight forward, definitely harder in the regular cab with so little space to maneuver the flooring when it was way oversized. I would say the best way to do it would be to start by lining up the molded areas then slowly trimming away at the back of the cab where you have a nice straight line. Go slow and use some heavy duty scissors, I found them to be much easier to use than a box cutter blade. Then I drilled out a hole for a bolt on both sides of the cab to fasten the floor securely while I worked on fitting the floor to the front, I used the two bolts that fasten the seatbelt ends.
    With the flooring secured and not moving, trimming up front was pretty straight forward, I cut too much away when fitting the shift boot but in most places you have a decent amount of leeway in how much you trim because the trim covers it. The biggest pain was locating all the holes I had to drill. I used a pin vise with a small drill bit to make "exploratory" holes, once I found where the bolt was going I used a large sharp drill bit in my handheld driver at a slow speed to make the bolt hole.
    The flooring is pretty stretchy and quite forgiving if you go slow and take your time. If you pay close attention to how much your plastic trim covers when you disassemble you shouldn't have any problems. I had weeks between disassembly and floor install because I had to scrub each piece and disinfect after a nasty mold issue.
    nagorb and JKO1998[QUOTED] like this.
  2. Apr 4, 2021 at 10:17 AM
    Running Board Man
    Running Board Man Well-Known Member
    I've had that jack for 5 years now... Great piece of kit
    ontarioyota likes this.
  3. Apr 4, 2021 at 10:23 AM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    I bought a Snap-On Floor Jack, brand new (the guy needed cash NOW) 25+years ago for $200.00
    It's been a great investment!!
  4. Apr 4, 2021 at 2:00 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  5. Apr 4, 2021 at 2:13 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Pulled the old girl out of the garage first time in 10 weeks. I have been doing a wheel well makeover. Hopefully in a couple more weeks I will have the fender flares and liners installed...new clips in hand.
  6. Apr 4, 2021 at 2:19 PM
    HighPlainsTaco
    HighPlainsTaco I am haunted by waters…
    Ethan
    Comancheria
    2002 3.4L 4WD TRD
    Man that truck is CLEAN. I've been meaning to try the plastic restoration on mine, looks damn good.
  7. Apr 4, 2021 at 4:40 PM
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
  8. Apr 4, 2021 at 6:04 PM
    FlipSideUp
    FlipSideUp Active Member
    Painted the area behind the bumper the same black as the bumper. Now the small (motorcycle) front turn signals show up a lot brighter.
    I also painted the small trim piece under the headlights, since they were all chipped up, but I think that was a mistake. Oh well...
  9. Apr 5, 2021 at 11:00 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    OH! that d-ring is supposed to be straight? I thought it was supposed to be bent:rofl:
  10. Apr 5, 2021 at 11:03 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What about a d-ring with a welded backing rib and some delrin bushings?
  11. Apr 5, 2021 at 11:13 AM
    DashMaple
    Louisiana
    Id be interested to see how that holds up
  12. Apr 5, 2021 at 3:04 PM
    YotainOregon
    YotainOregon Well-Known Member
    Oregon
    1st gen Tacoma TrD
    Question: anyone have had a problem opening from the outside driver side door and it locks on you I just want to confirm if this is the switch in the door itself? 2001 trd
    thanks in advance.
  13. Apr 5, 2021 at 3:07 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Raptor lined the bed and installed the bed stiffeners
  14. Apr 5, 2021 at 3:10 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    how was the raptor line job? Did you do it outside? Id like to do mine but dont have an indoor space to do it and right now I feel like it would turn out yellow with all the pollen in the air
  15. Apr 5, 2021 at 3:19 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    What brand bed stiffeners are those? They look nice!
    Tttacodan likes this.
  16. Apr 5, 2021 at 4:28 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I've thought about making it stronger more then a few times. I've decided not to. If I make the d-ring bend proof I'm positive I'll bend the rack. lol
  17. Apr 5, 2021 at 4:34 PM
    Speedytech7
    I think the rack would probably crack at where the steel tube is pressed into the alum rack body. But we've also seen the dring stud and bolt hole rip right out of the frame too, not sure which happens first haha
  18. Apr 5, 2021 at 5:46 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    ADS got a new bearing. It needed it.62535430-C81C-4398-A898-D0F65A59E0B4.jpg
  19. Apr 5, 2021 at 6:23 PM
    RandyO
    RandyO Well-Known Member
    Randy
    SF Bay Area (Calif)
    Silver '03 AC PreRunner
    Bed Liner and Bed Tool Box - nothing much...
  20. Apr 5, 2021 at 6:26 PM
    RandyO
    Randy
    SF Bay Area (Calif)
    Adding a couple of "before" photos - taken just before I applied the Restorer and Dressing.20210402_172644.jpg 20210402_172625.jpg
