  1. Apr 21, 2021 at 10:57 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    For sure, I’ll take it.
  2. Apr 21, 2021 at 11:02 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So which size did you go with on those tires?
  3. Apr 21, 2021 at 11:05 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    255/80/17
    Had BFG KO2 34x10.5R17 before. They came with the truck and worked great, but are too darn expensive in that size to get again. The AT3s are a little narrower and a tiny bit shorter, but not by much.
    chrslefty and 0xDEADBEEF[QUOTED] like this.
  4. Apr 21, 2021 at 11:10 AM
    0xDEADBEEF
    Cool. I keep looking in the 255 70/75/80 range, trying to decide whats the best combo of weight and height for my engine and gearing. Those AT3s seems like good tires, and not crazy heavy. How does that E load ride?
  5. Apr 21, 2021 at 11:15 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Looks great. I am considering Pizza cutters also. I feel my 265/75s are to close to the spindle gussets. If I go up to 285/75/16 they may rub. I am considering 255/85/16s and a better back spacing wheel.
    Area51Runner likes this.
  6. Apr 21, 2021 at 12:34 PM
    RattleTractor
    Harry
    VT
    Seems fine so far but it's too early to tell. They come with a pretty long tread life "warranty" and are cheaper than ST Maxx tires in the same size, so I figured I should try them out.
    0xDEADBEEF[QUOTED] likes this.
  7. Apr 21, 2021 at 12:43 PM
    Lukass
    Lukass Well-Known Member
    Luke
    Payson Arizona
    Extraordinarily Stock ‘99 Tacoma TRD
    Bilstein 5100’s
    You’re ambitious haha. I’m at 230,000 on stock coils, pulleys, ac compressor, and water pump :rofl:
  8. Apr 21, 2021 at 2:03 PM
    UCPA111
    UCPA111 Active Member
    shawn
    2002 Tacoma
    Nice! What springs/shock setup do you have now? Also, what did you paint with? My new to me 2002 has a newer frame. I intend to remove the bed and hit with a two part epoxy and then Fluidfilm inside and out. But, I want to replace tired springs and shocks without a lot of lift.
  9. Apr 21, 2021 at 2:06 PM
    UCPA111
    shawn
    2002 Tacoma
    I hear ya. I wasn't sure what previous owners did or did not do...and I wanted to play it safe.
    I just had valve cover gaskets replaced today with new coils, plugs and plug wires as well.
    Lukass[QUOTED] and unstpible like this.
  10. Apr 21, 2021 at 3:44 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Ordered a softopper today based on my experience with my 2nd gen. Should have my project moved to my new place next week. Hoping to get the back half of the frame cleaned up and the reinforcement kits burned in before I have to go back to work in June.
    unstpible and Tour991 like this.
  11. Apr 21, 2021 at 7:06 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I had this issue. I’m not sure why felpro doesn’t have silicone on both sides of the gasket.
    When I get my truck back together I’m going to try OEM.
  12. Apr 21, 2021 at 7:20 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Making small steps as able
  13. Apr 21, 2021 at 8:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dat boosted life tho..this is the real reality of boost Lol
    yeah Id just go OEM.
    Also, just to check, are you torqueing it down in a specific order? Helps to start at the middle and torque outwards. And of course having even torque is important.
  14. Apr 21, 2021 at 9:12 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I would also check to make sure that both mating surfaces are dead flat
    Speedytech7 likes this.
  15. Apr 21, 2021 at 10:57 PM
    Dan8906
    Daniel
    Concord, California
    Whose running a front elocker? I’m looking at a Eaton, am I crazy?
    unstpible likes this.
  16. Apr 21, 2021 at 11:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no matter what. Get a selectable one. That one is the electric one right? Be a great unit. What I'd buy now over the ARBs. Simpler to setup. And has a couple features that are nice.
    Dan8906[QUOTED] likes this.
  17. Apr 21, 2021 at 11:02 PM
    Dan8906
    Daniel
    Concord, California
    Yeah I’d like to stay selectable electric over air
  18. Apr 21, 2021 at 11:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah other than it's insane price, its a great option.
  19. Apr 21, 2021 at 11:05 PM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
  20. Apr 21, 2021 at 11:05 PM
    Dan8906
    Daniel
    Concord, California
    I’m seeing 1250, arb is 1000 so not much more
    Fernando and betterbuckleup like this.
