  1. Apr 28, 2021 at 12:21 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If I wanted to make my FJ80 switch have independent front and rear I would add a secondary switch that would disable the rear. I wouldn't bother starting over with two new switches. If you are starting from scratch then you don't have this issue unless you are dead set on using a Land Cruiser switch.
    6P4[QUOTED] likes this.
  2. Apr 28, 2021 at 12:40 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    For those of you ( @Dan8906 , @Phessor )who went the Rago Fab route for Bed Stiffeners, what did you use for the bed side of the bracket since we don't have existing bolts like the 2nd+ gens? Curious if they included additional hardware for that or if it was an extra trip to the local fastener store to complete install?
  3. Apr 28, 2021 at 12:55 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I have them installed and they gave me enough hardware for all the holes
    Area51Runner[QUOTED] likes this.
  4. Apr 28, 2021 at 12:57 PM
    Area51Runner
    Did you use anything for added support on the underside of the bed or was it simply a washer/nut? Thx.
  5. Apr 28, 2021 at 1:03 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Just a washer and nut
  6. Apr 28, 2021 at 1:20 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I’ve found that I have more stability climbing loose rock hills with ruts and holes if I use just the front locker.
    unstpible and Speedytech7 like this.
  7. Apr 28, 2021 at 1:52 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    That makes sense. I wonder why they built this limitation into earlier Land Cruisers.
    Tour991 likes this.
  8. Apr 28, 2021 at 2:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can disable it, there's a couple wiring mods to maneuver around it. Front lockers on Toyotas run the risk of grenading the ring and pinion in reverse due to the high pinion setup, so Toyota has a sticker staying how it should be a last resort in general to engage the front locker.
    unstpible and ToyotaDriver like this.
  9. Apr 28, 2021 at 2:37 PM
    akmcallister
    akmcallister Well-Known Member
    Andrew
    GA
    ‘04 Tacoma
    PreRunner Auto converted to 4WD Manual hubs w/ J shift Tundra brake upgrade ARB Bumper Icon 3” lift w/ OME springs 285/75/16 Toyo AT3’s Doug Thorley w/ Flowmaster 40 Series FN 5 spoke 16” wheels HID projector retrofits
    Finally got my 4Runner wheels mounted. All said and done was $200
  10. Apr 28, 2021 at 3:00 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Dupli-color? Looks great. I've got the same wheels waiting to be painted, and gunmental is on my short list.
    What did you do with the Toyota logo in the rear center caps?
  11. Apr 28, 2021 at 3:04 PM
    ToyotaDriver
    Idaho
    Even for the rear locker in the Tacoma’s there’s a placard stating that it’s only to free yourself from being stuck. I feel like you just have to be careful and cognoscente of the loads you’re putting on the drivetrain in your particular situation. My experience has been that most of the time if I get stuck, the locker isn’t going to help me any. Actually happened to me today...
    04694C4C-13CA-4337-8B55-C9DE0FDD6A93.jpg Can’t wait to have my 1st gen back in action
    unstpible and Tour991 like this.
  12. Apr 28, 2021 at 3:05 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Mmmmm late spring snow is the best snow :rofl:
  13. Apr 28, 2021 at 3:07 PM
    ToyotaDriver
    Idaho
    I would have made it through that drift too if my dog didn’t decide to stop and take a shit in the middle of it. :poking: Buried it to the frame. That pickup is getting a winch ASAP!
    JKO1998[QUOTED] likes this.
  14. Apr 28, 2021 at 3:15 PM
    akmcallister
    Andrew
    GA
    ‘04 Tacoma
    Just painted the center caps to match. Its nice to have a buddy who sand blasts - helped the paint stick. I did 2 primer coats and 4 coats of rustoleum flat soft iron, no clear coat
    unstpible likes this.
  15. Apr 28, 2021 at 3:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    locking the axle while using the traction matts helps a lot. just fyi.
  16. Apr 28, 2021 at 3:22 PM
    ToyotaDriver
    Idaho
    You think I didn’t try that?
  17. Apr 28, 2021 at 3:25 PM
    JKO1998
    Utah
    Sometimes the only thing that really helps is a shove
    unless you have a winch
    Or you’re with people
    ToyotaDriver likes this.
  18. Apr 28, 2021 at 3:28 PM
    ToyotaDriver
    Idaho
    I’ve also discovered that my cheap ass Amazon traction boards only grab mud tires or very aggressive all terrains. The lugs on the Laufenn x fit tires leave some to be desired for anything more than your average forest service road.
  19. Apr 28, 2021 at 3:29 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
  20. Apr 28, 2021 at 3:29 PM
    ToyotaDriver
    Idaho
    I actually laughed out loud.
    Rldanie and unstpible like this.
