  1. May 13, 2021 at 12:28 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Thanks, added to the "inner joint" folder.
    Wulf[QUOTED] likes this.
  2. May 13, 2021 at 12:28 PM
    eon_blue
    Azusa, CA
    That is true, on factory ADD trucks the front driveshaft is disengaged in 2wd. I can crawl under the truck and rotate the front driveshaft by hand to grease all the zerks.
  3. May 13, 2021 at 12:32 PM
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    Having swapped my ADD hubs for manual hubs, I would agree with most of the sentiment here. The benefits are not worth it in retrospect. It gives the truck an "old school cool", but that is about it. I haven't noticed much gain in MPGs, and makes maintenance a bit more time consuming. Some serious carnage above :eek:. I have yet to break mine, but I'm sure it's only a matter or time....
    ... So anyone interested in some used manual hub swap parts I have for sale? :D
    Laxtoy and Winkle99 like this.
  4. May 13, 2021 at 12:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I think I have an ADD stub shaft you can have. Might not be the cleanest thing as it's been sitting in the junk pile a while now.
  5. May 13, 2021 at 12:39 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    you will be fine, I never broke them until I geared and locked the truck on 35s. With stock gears and 35s I never had an issue.
    I notice about 2mpg better with the hubs unlocked, when my truck was a DD it made a big difference.
    Area51Runner and m3bassman like this.
  6. May 13, 2021 at 12:43 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Correct. The driveshaft will spin when the ADD actuator is engaged.
  7. May 13, 2021 at 12:45 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    I’ve got some patchwork to do.
    unstpible likes this.
  8. May 13, 2021 at 12:48 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    :sawzall: for 35s
    JoeyWales[QUOTED] and m3bassman like this.
  9. May 13, 2021 at 12:48 PM
    Cattywampus
    Mark
    Colorado
    I assume you went back to ADD afterwards?
  10. May 13, 2021 at 12:50 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yep, tru nuff.
    Many moons ago the generally well respected fabricator/owner of Trails Less Traveled ran that set up. He went so far as to claim 18 MPG. That was a 3rz at 70 mph, 35"mt's, 529 gears, a ton of armor, a pig of an Atlas and the aerodynamics of a parachute. Humorous to say the least
  11. May 13, 2021 at 12:53 PM
    Wulf
    rock raisin
    No, my truck was never ADD and I see no reason to swap it. I'm still on the manual hub setup.
    Area51Runner likes this.
  12. May 13, 2021 at 12:58 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I tried to add a "little" bling and spruce up the appearance of my 03 DC. I re installed my factory skid plate that I re-painted. I don't do any hardcore off road trails or anything. For me it's something to keep small critters and such from flying up into my engine bay. And it will serve as a brush guard for fire roads.
    My poor 18 year old clam shell rims are showing they're age. I tried to clean them up a bit, and I replaced the center caps with some off brand knockoffs. they look okay. And I replaced my chrome lug nuts with black ones. thought a little contrast would look good. But after the tire shop gets done rotating my tires next time, I wonder how the paint will hold up on them. At least with them being black, I can always touch them up with a rattle can.
    chrslefty and SwampYota like this.
  13. May 13, 2021 at 1:00 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Rocks don't hit trucks, drivers hit rocks.
    Drivers break CV's.
  14. May 13, 2021 at 1:00 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I'M THAT GUY.................
    :duh:
  15. May 13, 2021 at 1:03 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Yea maybe 18mpg downwind and downhill lol.
    Thanks but I think i'm just gonna stick with the manual hub setup until I start (if) grenading parts. I have a set of ADD spindles and OEM axles on deck for if I ever decide to swap over.
  16. May 13, 2021 at 1:12 PM
    Reh5108
    Idaho
    Can confirm.
  17. May 13, 2021 at 1:36 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    Just got back from the first wheelin trip in my 1st gen. The klunker impressed me on some tight and steep trails. Now it’s washed and put away for another 5 weeks..
  18. May 13, 2021 at 1:39 PM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    Good to see you here Mike!
  19. May 13, 2021 at 1:49 PM
    Darrell942
    Darrell942 Active Member
    Darrell
    Byron Georgia
    2000 Toyota Tacoma Prerunner Extra Cab 4cyl 2.7 Ltr
    None, why mess with a good thing
    I neglect my Taco way too much and it definitely does not get the TLC it deserves.
    Don't get me wrong,
    - I'm not a spit and polish, baby cloth wiping, fretting over any scratch sort of person.
    - But I'm also not hamburgers under the seat, 20 used bottles or fast food wrappers every where either.
    "What have you done to your Tacoma Today?"
    - Took it out to the car wash to get some of the baked on pollen and grim off, well at least the first layer, so I can do more soon.....
    Jiveydude and m3bassman like this.
  20. May 13, 2021 at 2:33 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Decided to tuck my ECT switch behind the dash to install my front locker switch in its place. 7B551BD9-3E8B-4B99-AC88-0A73A820B8A5.jpg
