  1. May 28, 2021 at 7:44 AM
    1997tacomav6
    Denver
    You just put it back in for Emissions to pass then swap it back out so it doesn’t get stolen if your at high risk
    unstpible likes this.
  2. May 28, 2021 at 7:44 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    That’s the plan
    1997tacomav6[QUOTED] likes this.
  3. May 28, 2021 at 7:45 AM
    1997tacomav6
    Denver
    You will pickup a nice rumble with your exhaust too,
    Coming off the acceleration I have a nice cracking and pop sound coming down from high rpms
  4. May 28, 2021 at 7:46 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    jubei, Digiratus, SwampYota and 3 others like this.
  5. May 28, 2021 at 8:30 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The second that shit starts happening in my neighborhood I'll be posting up with my KSG
    jubei likes this.
  6. May 28, 2021 at 8:38 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Damn. Are those 24's?
    Should get some of these for that bad boy
  7. May 28, 2021 at 8:42 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Do you get downstream o2 codes from not running a cat?
  8. May 28, 2021 at 9:16 AM
    Empty_Lord
    Dan
    LOL. A car hit this thing a few weeks after I got it (I was pissed) but because of having those tires, it didn’t fall over. Just bent a couple drawers... gotta love lube techs thinking it’s smart to drive a car with no brakes into my bay when I’m off...
  9. May 28, 2021 at 9:32 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes, it is a possibility.
    We removed only the upstream cat, leaving the downstream one in place, and I now get an intermittent P0420 code.
  10. May 28, 2021 at 10:19 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Loaded her up. Time to go play
  11. May 28, 2021 at 10:44 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Hit the annual spot up in the Sierras
  12. May 28, 2021 at 11:07 AM
    Eddietech
    Eddietech Well-Known Member
    Dope
  13. May 28, 2021 at 12:51 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Picked up a set of WeatherTech “trim to fit” floormats at Costco. I figured how good can they be for $29 but they fit pretty good and should catch a lot of crud
    Taco critter likes this.
  14. May 28, 2021 at 1:11 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    :cheers:
    Fernando[QUOTED] likes this.
  15. May 28, 2021 at 3:26 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Added handles and L track to my new bed platform. Things done.
    Also added the all pro rear relocation plates to shift my rear axle back to the correct position.
    ToyotaDriver, unstpible and se7enine like this.
  16. May 28, 2021 at 8:13 PM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    Added some tube doors.
    9FE0E906-CA3E-4A65-B67C-A7D539A87CD3.jpg E27A5F5B-4E6A-4AB5-B9A8-CAE0FC95C8A5.jpg
    m3bassman, razhick4x4, jubei and 4 others like this.
  17. May 28, 2021 at 9:15 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Time to update the profile pic....
    Dan8906[QUOTED] likes this.
  18. May 28, 2021 at 9:15 PM
    Empty_Lord
    Dan
    Taco #2 is coming. June 6th if I can line up a trailer and I’ll have yet another double cab. Photos will follow when it’s on the trailer behind the tundra.
    finally something to put all my old parts on! Including the whole damn frame
  19. May 28, 2021 at 9:32 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    Fixed my driver side door window and replaced all 3 lights of the 3rd brake light. It took 20 min to get the right light bulbs as the napa person behind the counter was having a lot of difficulty finding the right bulb... I knew I should of looked them up before I went in. That's what I get
  20. May 28, 2021 at 10:11 PM
    Dan8906
    Daniel
    Concord, California
    Yeah no kidding that picture was probably 4 years ago. Lot has changed
