  1. Jun 3, 2021 at 7:40 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :eek:
    I dont buy the bs that water cant get in via the snorkel head
    unstpible likes this.
  2. Jun 3, 2021 at 7:51 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's not a real snorkel, it's this:
    Ad it's actually held up well for 3 years since I put it in. Problem is the metal part rusted and started breaking at the joint to the plastic tubing. But I've had water up to my windshield before in a water crossing and the box only had a little water in it after that. The other thing to note is that I plugged the drain holes in my airbox after installing this setup.
    In order to get home I took my knife and drilled two drain holes back into the airbox and got a new filter. Truck stopped bogging at high RPM's and got me home but the new filter was still pretty wet from water vapor.
    Thankfully I have a real snorkel in the garage that I haven't had the time to install yet.
  3. Jun 3, 2021 at 8:02 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You going to transfer over your oil cooler to this new engine?
    1997tacomav6 likes this.
  4. Jun 3, 2021 at 8:28 AM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    I've never had water in my airbox, rain or snow.
  5. Jun 3, 2021 at 9:27 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    nah. Just going to delete it. Waiting on some more gaskets and O-rings to arrive and then I’ll be moving the oil filter to the front and the oil cooler block off plate to the back.
  6. Jun 3, 2021 at 9:52 AM
    eon_blue
    Azusa, CA
    That amount of water is crazy, that shouldn't happen with a regular dorkel just driving through rain.
    I've only checked a few times but I have seen a little bit of water in the air box after driving through a big storm on the highway. Not even enough to register on the air filter though, just a few drops in the corners of the box.
  7. Jun 3, 2021 at 10:47 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I like to splash in puddles lile a little kid
    This man knows whats up
  8. Jun 3, 2021 at 2:56 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    New air filter, and replaced the light in the shifter- I was able to get the condom off the old light and put it on the new one.
    Tomorrow is replacing the bushings of the shifter
  9. Jun 3, 2021 at 3:13 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I thought the best part was the next day, when you said, "I'm going to take it easy this time." But you couldn't resist. :rofl:
    ... and then there was "a new noise":
    ... and then, as I recall, a couple hours later... Zane @Speedytech7 saved your ass with some quick thinking.
    What a great trip that was.
    Hiking Death Valley (Feb 2019)
    unstpible and SwampYota like this.
  10. Jun 3, 2021 at 3:38 PM
    puhtronickus
    puhtronickus New Member
    1995 Tacoma 3.4L 4WD
    Replaced the power steering pump. Thank you ebay and Timmy the Toolman at https://www.youtube.com/watch?v=5k61KXRK8bM
    Thing was becoming a bit of a headache, as the rebuilt pump I first installed from O'Reilly's turned out to be a dud.
    Anyone looking for a step-by-step breakdown of how to do a ps pump install and flush on a 1st Gen, check out that vid. It helped me out a lot.
    unstpible and chrslefty like this.
  11. Jun 3, 2021 at 3:39 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :eek:
    m3bassman[QUOTED] likes this.
  12. Jun 3, 2021 at 3:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Do you guys prefer to run Toyota fluid for the power steering? or would a fluid from the vatozone or local store be ok? What about the coolant? For the wifes old lexus I grabbed a red coolant and it worked fine.
  13. Jun 3, 2021 at 3:46 PM
    eon_blue
    Azusa, CA
    Coolant I pick up the big jug from the parts dept at the dealer. Power steering I would use any Dex III ATF you can get at the auto parts store, Yotas use ATF for the PS fluid.
    Fernando[QUOTED] and frenchee like this.
  14. Jun 3, 2021 at 3:46 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    For powering steering I’ve been running the Valvoline red tranny fluid
  15. Jun 3, 2021 at 3:48 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    thanks guys. I'll do a standard brand for the PS and go Yota for the Coolant
  16. Jun 3, 2021 at 3:55 PM
    puhtronickus
    Same here
    Fernando likes this.
  17. Jun 3, 2021 at 5:28 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Got the crusty crud’s out.
    good practice cutting bolts for the Lcas I guess
  18. Jun 3, 2021 at 8:14 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    OK Gents, need your expertise. I have a 2001 2RZ-FE 5-Lug Manual that won't start. If you crank it and stop crank it and stop 3 times, usually it'll fire the third time but will immidiately die. If you hold the RPM's up it'll stay running but die when you let off the gas.
    I was told it could be the IAC, Any ideas? Battery 12v, alt produces nominal 14v when running.
  19. Jun 3, 2021 at 8:23 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Will it run in limp mode if you unplug the maf?
    Digiratus likes this.
  20. Jun 3, 2021 at 8:26 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I will try that next. Right now I’m holding the gas to see if it’ll stay running and idle after a period of time
