  1. Jun 17, 2021 at 4:54 AM
    BossFan
    BossFan Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    Nothing real exciting but I did add a BetterBuilt toolbox to my bed. I used their Grip-Tite system which required me to cut holes in the bedliner. I think that I am now going to look into one of the spray-on bedliner options.
    One of my tailgate cables broke. The cable inside the rubber tubing was rusted through. I ordered a set off Amazon for $17. We’ll see how they do.
  2. Jun 17, 2021 at 5:21 AM
    FlipSideUp
    FlipSideUp Active Member
  3. Jun 17, 2021 at 8:52 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
  4. Jun 17, 2021 at 9:14 AM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    The nostalgia LOL, I still have the 3rd brake light TTORA metal trim cover
  5. Jun 17, 2021 at 9:41 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is awesome. Good to hear he is doing well.
    I recall the thrill of finding Tacoma Territory. It was my first online forum experience. There were all these guys that had a truck just like mine. And all they wanted to do was talk about how they wanted to make them better. So, so cool.
    Somehow this does not surprise me one bit. :hattip:
    PNW chapter member here. 1998 I believe. Still friends with one other guy from that group. Unfortunately, I can no longer find my club cards and plaque. They were lost somewhere in one of the many moves since then.
  6. Jun 17, 2021 at 9:55 AM
    eon_blue
    Azusa, CA
    Speaking of old Toyota forums, I'm sure some of you remember Yotatech
    Back in 2005 I got my first Tacoma, a 1999 Prerunner. Tacomaworld wasn't around yet and somehow Yotatech popped up first when I looked for a forum so I joined there, spent a lot of time on there for a couple years.
    Sold that truck when I went to college. Got my 04 in 2016 and went to see if Yotatech was still around, still was but it's just a shell of what it used to be. Heard the owner sold it off years ago and now it's full of annoying ads and just a few regular posters.
    Akkording, Area51Runner and unstpible like this.
  7. Jun 17, 2021 at 10:00 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    While I'm here, there is always confusion about e-locker swaps.
    A 1st gen Taco e-locker (8") 3rd can not be put into a Taco 8.4" housing or the other way around. The bolt pattern and mount surface/diameter are different.
    The 3rd gen 4R's use an 8" rear for both the open and e-locker but the housings are slightly different. The locker version has a small cut out and 2 longer studs to accommodate/clear the locker/actuator.
    This is where the confusion comes in. It is no big deal to grind a little relief in an 8" 4r housing and drill/tap for the longer studs. ECGS sold a "kit" to do this. It contained an e-locker 3rd gasket and the 2 longer studs that pass thru the actuator. The gasket served as a template for the 2 new stud holes and the area to be ground away.
    It would be a whole lot easier to put an e-locker 3rd from a Taco or 4R into an open 4R housing than to swap an entire Taco e-locker into a 4R and deal with all the suspension mount changes and possibly e-brake changes.
    This is the original diagram for DIY wiring using a simple non Toyota switch with no relay, pretty simple.
    Further poop.
  8. Jun 17, 2021 at 1:08 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Refurbishing these 06 Forester seats for a swap. I’ll never do this again.
  9. Jun 17, 2021 at 3:00 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I got some 2016 Altima seats awhile back, the foam and fabric were in decent shape but dirty and rusty. Such a pain to clean, I kept thinking to myself this is totally not with it. But for $75 and super comfortable seats I couldn't pass it up and have been really happy with them.
    unstpible and JoeyWales[QUOTED] like this.
  10. Jun 17, 2021 at 4:14 PM
    JoeyWales
    SC
    Im a fan of those seats as well. They had a couple of Altima’s but they weren’t in that great of shape.
    I was surprised at how difficult it was to find seats that weren’t leather/vinyl and aren’t power.
    If I don’t like these, they were $90. So no big deal. Planned on keeping my original seats anyway.
    unstpible and nagorb[QUOTED] like this.
  11. Jun 17, 2021 at 5:11 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Yeah I had a hard time as well finding somewhat decent seats. Around here unless you grab em as soon as they come in they're left in the elements.
    unstpible likes this.
  12. Jun 17, 2021 at 5:42 PM
    02 quadcab
    02 quadcab Well-Known Member
    You guys have functioning brakes??
  13. Jun 17, 2021 at 6:57 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  14. Jun 17, 2021 at 7:03 PM
    FlipSideUp
    Me too. Lol
    Still rockin' the slowly disintegrating TTORA windshield banner (actually a replacement of the 1st one, which had "Tacoma" instead of "Toyota"), and quarter panel decals, too!20210617_202323.jpg 20210617_202337.jpg 20210606_002803.jpg
  15. Jun 17, 2021 at 7:38 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    Finally got my new to me ‘98 registered.
  16. Jun 17, 2021 at 7:54 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My truck hasn’t moved since last September
    Beat
    unstpible and ToyotaDriver like this.
  17. Jun 17, 2021 at 8:14 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    may 4th, 2016
    unstpible, riskadverb and BYJOSHCOOK like this.
  18. Jun 17, 2021 at 8:23 PM
    JKO1998
    Utah
    Dwarfs don’t count
  19. Jun 17, 2021 at 8:25 PM
    Empty_Lord
    Dan
    boy, your askin' for a can of whoop ass!
  20. Jun 17, 2021 at 8:26 PM
    JKO1998
    Utah
    Big words for lil guy
