  1. Jun 26, 2021 at 10:08 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
  2. Jun 26, 2021 at 10:12 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wouldn't worry about it. How every other lca mounts from long travel kits(exception being camburg).
  3. Jun 26, 2021 at 10:50 AM
    Running Board Man
    Running Board Man Well-Known Member
    If they were loose shit would move around and develop slop
  4. Jun 26, 2021 at 10:53 AM
    Running Board Man
    What I did was put flat washers between the sleeve and frame mounts
    A plus is now the bushing has a smooth surface to rotate against while still being snug
    Usually the frame has gouges from the original washers on the lca bushings that I feel would chew up the bushings
    ontarioyota and unstpible like this.
  5. Jun 26, 2021 at 4:53 PM
    FlipSideUp
    FlipSideUp Active Member
    Just installed a swing-away hitch mount tire carrier by a local fabricator working out of his garage.
    Not bad! The tire extension is a little too long but he's gonna fab another section for me so the tire doesn't stick out so far, but this will do for now.
    You can't help but notice the carrier sits slightly skewed but that's not the carrier. My hitch receiver is what's actually skewed, which is why it angles out away from the truck. The long extension exagerates it even more!
    Can't complain for $350!
    In either case, now I can actually use the bed of my truck!
  6. Jun 26, 2021 at 5:14 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I only moved it around the yard. I thought for sure it would be sitting on the bump stops but it still had 1.5" to go.
    unstpible and DashMaple[QUOTED] like this.
  7. Jun 26, 2021 at 5:32 PM
    SiberianTacos
    SiberianTacos Well-Known Member
    02 Tacoma Dbl Auto 4wd
    Sick! looks good. Nice truck! What is that bumper ?
  8. Jun 26, 2021 at 5:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Actually ran out of gas yesterday. :oops: First time that has ever happened to me.
    It coughed and died when I turned left onto the road the gas station is on. I was about a block away. Fortunately is fired up again and ran long enough to get to the pump. According to the pump, I was able to put in 18.499 gallons. That is without a 2nd click.
    turbodb, BrownMike, chrslefty and 6 others like this.
  9. Jun 26, 2021 at 5:49 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Getting your monies worth out of that tank eh?
  10. Jun 26, 2021 at 6:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Alright boy, girls and other pronouns
    2 things
    Anyone have any advice on getting the UCA bushings out?
    and for those that have replaced factory brake lines with fancy metal ones, did you just zip tie the lines to the spindle? Mine didn’t come with the bolt bracket
    unstpible likes this.
  11. Jun 26, 2021 at 6:42 PM
    5280
    5280 old school
    Colorado front range
    99 Tacoma TRD
    Trail Gear Front bumper, Warn, Apex Octane rear bumper, SPC, OME 881, Dakars, Raven topper, PIAA fog lights, dog mod and a couple other things...
  12. Jun 26, 2021 at 6:44 PM
    FlipSideUp
    Thanks man!
    Just a scrap piece of structural c-channel. I think it was a C6x10.5
  13. Jun 26, 2021 at 6:58 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Beating my record eh? :p
    I think that pump was lying to you…
  14. Jun 26, 2021 at 7:05 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I've had my bed off doing a small frame repair, patching a 10" x 6" bed rust out, new muffler and tailpipe, rustoleum rust reformer paint, and fluid film. Set and tightened the bed this afternoon. Hope to finish re-assembly tomorrow.
    Owning a tractor makes things so easy. One man job.
  15. Jun 26, 2021 at 7:35 PM
    Reh5108
    Idaho
    Got ya beat, no top off. Didn't stall pulling in either. Afr's were getting lean though.
    MAP gas and let them burn out.
  16. Jun 26, 2021 at 7:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not sure really. I mean it is possible right?
    Honestly, when it stalled, I didn't think it had run out of fuel. It kind of felt like it was a continuation of all that crap that has been happening with my idle and a lot like the trouble I had in Colorado last year. So when the pump said I put in 18.5 gallons, I wasn't sure what to make of it.
    FWIW, I knew I was low on fuel but not that low. The scan gauge, which is normally very accurate, says I should have been able to put in 17.5 not 18.5. So you may be right.
  17. Jun 26, 2021 at 7:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    not by much. :luvya:
    Reh5108[QUOTED] likes this.
  18. Jun 26, 2021 at 8:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    it should not have been an issue. As Dan indicated, there's something up with that pump.
    That would put it more on what's up with the idle, that it stalled but not because it ran out of fuel.
    Maybe it's the heat here. :notsure: the redhead is pretty pampered....
  19. Jun 26, 2021 at 9:01 PM
    Empty_Lord
    Dan
    Shit.. I need to try that when the red one goes under the knife.
    Wsidr1[QUOTED] likes this.
  20. Jun 26, 2021 at 9:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Unknown.
    I did recently swap out the original MAF with a new denso unit. If I was to nitpick, I'd say the original MAF is a little better than the new denso.
