  1. Jul 29, 2021 at 11:39 AM
    eon_blue
    Azusa, CA
    I would verify the leak issue before committing to the expense of new cats
    Does VB stand for Venice Beach in CA? If you're in CA then you need 50 state/carb approved cats. There are quite a few aftermarket options for 1st gens though. 2nd gens+ don't have many carb options other than OEM
    You have a 1998...in CA, 2000 and older vehicles have to get put on the dyno and do the sniff test so if your cats are bad or not 50 state approved they'll be able to tell. Nice thing about the 2001+ years is that you only get a visual and OBDII inspection. Less headache come smog check time.
    I had Magnaflow cats installed 5 years ago and they've been doing great since, much cheaper than OEM. Although cat converter prices have skyrocketed in the last year or so
  2. Jul 29, 2021 at 11:43 AM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    No, I’m on the other side of the country. It’s Virginia Beach, VA. We don’t have emissions checks here. I’ll have to check into after market cats. I think I’ll take it back up to the muffler shop and talk to them too. Thanks man!
    eon_blue[QUOTED] likes this.
  3. Jul 29, 2021 at 11:43 AM
    eon_blue
    Azusa, CA
    Ah yeah then you have much cheaper options you can look into. Or even do the URD sim/O2 sim just to get rid of the CEL.
    K-DubTaco[QUOTED] likes this.
  4. Jul 29, 2021 at 1:33 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Pretty sure you can just buy new foam on eBay as well. I did that with the used 4Runner seats I picked up and it was well worth it.
    Digiratus[QUOTED] likes this.
  5. Jul 29, 2021 at 1:43 PM
    BeLance89
    Brandon
    Huntsville, AL
    agree with this. If it’s not an exhaust leak, it’s the cat. The shaking at idle could be a separate issue.
    K-DubTaco likes this.
  6. Jul 29, 2021 at 1:55 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Or that the O2 sensor is loose. Nuts and studs deteriorate here in the rust belt!!
  7. Jul 29, 2021 at 2:00 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    It's 1999 and older that have to go through the sniff test, fortunately for me.
  8. Jul 29, 2021 at 2:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    From a trusted friend, it is my understanding that the feds have recently started cracking down on sales of defeat components like this. Further evidence is that URD has stopped selling theirs.
    https://www.tacomaworld.com/threads/o2-simulator.730018/#post-26005653
  9. Jul 29, 2021 at 2:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    An interesting idea. Thanks.
    BeLance89[QUOTED] likes this.
  10. Jul 29, 2021 at 3:11 PM
    bobc
    bobc Member
    IMG_20210729_165528068_HDR.jpg IMG_20210729_182526206_HDR.jpgI'm in the process of replacing my gas tank on my 04 found a rotted out vsv on my evap canister replaced it with a doorman 911-601, and finally got to remove what was left of my e-locker .I hate road salt.
    unstpible, nagorb and ontarioyota like this.
  11. Jul 29, 2021 at 3:28 PM
    K-DubTaco
    Ken
    VB
    ‘25 TRD Off Road
    Dang I worry about the salt in the air from the ocean. It’s nothing compared those results!
  12. Jul 29, 2021 at 4:18 PM
    CantCyou
    CantCyou Member
    Aiden
    01 Tacoma TRD Pre runner
    Bumper, lights, wheels, tires, suspension, Easy stuff
    I painted my grill and put in new black enduro headlights and smoked brake lights. I think it looks pretty good
    D6188FED-27D2-440D-9883-FD403478B133.jpg D7010F7D-CEE8-4056-BE39-F9EA1E336CF0.jpg
  13. Jul 29, 2021 at 5:16 PM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    Looks nice, and clean. I notice the bottom of your tailgate, can you drop the bumper down?
  14. Jul 29, 2021 at 5:22 PM
    SkumTaco
    SkumTaco New Member
    Serge
    2004 3.4l double cab Tacoma
    First post here! Bought my taco recently with plans not to change it (lol) now planning on selling the Harley to make some changes to the truck. OEM TRD wheels with 33s, front bumper, and possibly sliders. Need to get a few things buttoned up on her too. Carrier bearing, u joints, and new leafs. Bought it with a fairly new transmission in it, and the rebuilt motor had 600 miles on it when I picked it up from a coworker. Today I looked around here for ideas and inspected a few things that I need to replace.
  15. Jul 29, 2021 at 5:50 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Nice first FLEX post. Welcome
  16. Jul 29, 2021 at 5:54 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    No offense. Buy a black grille!!
  17. Jul 29, 2021 at 5:55 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Does anybody recognize this 5lug ? I’m trying to see what flares they used. They look like OEM 97-00 6 lug flares but I wanna make sure before ordering
    400AB9D7-8587-4A7E-80A5-6059673DF676.jpg 3240BE80-E707-4ED2-92B7-66AB00F01C2E.jpg
  18. Jul 29, 2021 at 5:57 PM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    i wanna know too!
  19. Jul 29, 2021 at 6:21 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    They look like the bigger/newer flares to me
  20. Jul 29, 2021 at 6:48 PM
    CantCyou
    CantCyou Member
    Aiden
    What do you mean “drop the bumper down”?
