  1. Aug 4, 2021 at 9:44 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    It's definitely possible to do as any have said - using Wheelers lines is the way I went originally as well with the Napa Eclipse Calipers (as Mike @Digiratus mentioned). The "problem" with the banjo situation is that (again, as Mike said), you need a machined surface on the caliper for the crush washer setup to work correctly. This means you have to hunt around for calipers that aren't powder coated, or that are machined after coating. (Napa Eclipse are OK for instance - and that's what a lot of folks on here used since they did the work many years ago - but you can't get them at most Napa's anymore - at least, out west.)
    Note: this is in addition to the shortening/drilling of the banjo bolt that many have to do as well.
    The reason not all 13WL calipers are machined for banjo+crush washers is that they were designed for a hard line (since that's how Tundra's came from the factory). So, the safer bet - which means you can use any 13WL should yours fail on the trail - is to use a hardline into the caliper. You don't lose any clearance with the coilovers using this method (again, if you did, all Tundra's and 4Runners would have problems), and it means you can much more easily replace a caliper in the future.
    Here's what happened to me on the trail: IDBDR Pt. 7 – The Curse of the Lolo Motorway
    Here was my evaluation of what happened and why: Rig Review: Idaho July 2019 – What worked and what didn’t?
    Here's where I decided to go hard lines and why: Making It Right: Tacoma-to-Tundra Brake Upgrade
    At any rate, you can make the soft lines work for sure - but doing so only saves ~$50 on the upgrade (~10% of the cost) so for me, is not worth the savings. Heck, it's less than a tank of gas these days.
  2. Aug 4, 2021 at 10:13 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    its funny. because on the tundras the brake lines hit the 2.5" coil overs and running Tacoma braided lines is the fix.
  3. Aug 4, 2021 at 10:14 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Insane… better carry some spare shafts and cvs
  4. Aug 4, 2021 at 10:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is a lot for daily driver. But for many of us, we've been flirting with 6K for a while now when we are loaded up for a 2 week adventure.
    The rear axles are a little vulnerable at that weight but the fronts should be fine.
    malburg114[QUOTED] likes this.
  5. Aug 4, 2021 at 11:12 PM
    Phessor
    Phessor Well-Known Member
    These axles will take a lot of abuse.
    The rear axle in my old Hilux came out of a 2001 Tacoma.
  6. Aug 4, 2021 at 11:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :notsure: I've bent two of them.
  7. Aug 4, 2021 at 11:16 PM
    Phessor
    I guess I've been lucky :fingerscrossed:
  8. Aug 4, 2021 at 11:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Or I unlucky.
  9. Aug 5, 2021 at 5:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Or :burnrubber:
    unstpible likes this.
  10. Aug 5, 2021 at 6:20 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    :eek: you DD at this weight without being loaded, that's insane. Did you box inner and plated the outer rear frame for strength?
  11. Aug 5, 2021 at 7:18 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I always carry spare driveline, CVs, LBJs, OTREs etc. It's actually included in the 5980.
  12. Aug 5, 2021 at 7:27 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    finally… a proper definition of irony.
    unstpible and Empty_Lord[QUOTED] like this.
  13. Aug 5, 2021 at 7:49 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Rear frame is boxed and also has reinforcement plates on the outside. Also spindles are gusseted and I have @eimkeith plates on top of the front shock mounts.
    My "DD" weight isn't exactly "without being loaded." My DD weight being 5980 includes A LOT more of my load out than most people.
    The 5980 includes:
    Spare parts... rear section of driveline, spare CV axles, Spare LBJs, OTREs, and a medium ammo box of small spares like spark plugs/wires, lug nuts, etc, etc, etc.
    Recovery gear... static straps, snatch straps, tree savers, rope, ratchet straps, bow shackles, snatch blocks, etc.
    Fluids... Gallon antifreeze, quart of brake fluid, ATF, Oil, etc
    Tools... essentially everything you need to do pretty much anything you need to do to our truck aside from a specific specialty tool. Along with Milwaukee mini impact, ratchet wrench, etc. (I even carry a torque wrench) Also a bag of electrical, with OBDII scanner, test light, spare fuses.
    I also carry the ARB 50 quart refrigerator, both my 5 pound propane tanks daily (and it's part of that weight)
    The only things I need to "load" to go out is 1 - 50 quart tote, and 1 - 20 quart tote with actual camp supplies (camp stove, cookware etc), 1 - 30 quart cooler with drinks, food, pillows, a backpack for each of us (me and wife) with clothes... and 5 to 15 gallons of fuel/water (typically 5 gal of water, but sometimes we'll take 10 of water 5 of fuel, depending on what we're doing)
    The reason I keep the truck loaded is we go out quite a bit. Whether it be to camp or to day trip, we go out on average more than every other weekend. I keep everything in it because it's easier to not forget things, it takes less effort to get ready, it's easier to pack if everything has a place and stays in that place.
  14. Aug 5, 2021 at 10:13 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Yeah I thought my Tacoma was getting porky at 4500. I also love small light wheeling rigs…I love what Tim Hardy with his zuk and Brennan Metcalf with his flatty are doing by keeping the rigs light with creative ways to pack everything they need without going full overlander.
    I get the having everything ready to go so you can spontaneously hit the road without a ton of effort. I can also appreciate being able to be independent off the grid out west for a week at a time...That just doesn't exist east of the Mississippi. At the same time, loading up a Tacoma to probably 6500 lbs seems like a lot for the platform...a buddy with a caged 80 on 40's comes in at 6460 with a spare 40 with wheel, full of fuel, 2 people and camp gear for 10 days. The 80 handles it fine but the Tacoma platform definitely has boundaries with things like bending housings, cracking bed, cracking coil buckets, etc when you get heavy and run some miles offroad. Either jumping up to an 80 or lightening up your loadout would probably serve you well.
    At the same time, I realize I'm the pot calling the kettle black since I haul in a 40' toyhauler that grosses around 26k with all of my creature comforts at camp :anonymous:. I've driven the Tacoma and camped out of it recently but for out east where you have a base camp, it doesn't make a ton of sense to load it down with stuff when the tow rig is an entire order of magnitude nicer to drive than the Tacoma loaded with gear.
  15. Aug 5, 2021 at 10:25 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, there is some of that too. :anonymous:
  16. Aug 5, 2021 at 10:38 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I think the real answer is you don't need nearly as much shit as you think you need.
    I'm living out of my truck this summer and packed light, and wish I had packed even lighter in a few areas.
    Keep it simple. Learned that the hard way with my 1st gen.
    unstpible, Winkle99, seen20 and 3 others like this.
  17. Aug 5, 2021 at 10:40 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've never needed the fire extinguisher in my truck... and I do keep it simple. It all stays in the truck, so I don't have to pack, unpack it :thumbsup:
    unstpible and schellshocker99 like this.
  18. Aug 5, 2021 at 11:01 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Thanks for the thorough response.
    After doing some more reading and researching, I came across your posts that mentioned the Napa Eclipse calipers are the ones that will work with the soft line due to the machined surface.
    Even though the Napa stores don't carry them anymore, I was still able to get it mailed to me.
    If I encounter issues down the line, I'll swap to the hardlines.
    unstpible and turbodb[QUOTED] like this.
  19. Aug 5, 2021 at 11:17 AM
    malburg114
    Las Vegas, NV
    I kept my tube work simple to keep it light. I’ve never weighed mine but my guess is around or less than 5k on 40s with a full spare and enough spares and tools to get off the trail. 6k is absurd and would have been to much for my last tow rig to handle for sure. 6k is approaching what my new weighs lol.
    Brennan’s packing and bags and way he does things is where I got a lot of ideas for mine. Make everything so you can easily get at any auto parts store and split carrying spares with your buddy. Cuts down on a lot of weight
    jubei likes this.
  20. Aug 5, 2021 at 11:50 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, I have been watching. :cool: But if I do it, it will have to be properly fueled.
