  1. Aug 8, 2021 at 8:05 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    It measures 4x2. I made the frame out of angle steel and then bought a piece of plywood cut to fit inside the frame.
    Wrapped the wood with some carpet. Welded some brackets on the frame to bolt up to factory seat bolt location
    Taco2021LB likes this.
  2. Aug 8, 2021 at 8:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No I don't.
    Because it moves it so far forward you'll then have the same issues just with the front side of the fender/bumper/whatever is in the way. So you'd end up centering the wheel about perfect and you'd still need to tub.
    Even with a 10'' wide tire you'll have to. Just won't be a wide a hole.
    with a BL you'd be probably okay to beat the fuck out of it with a BFH. Maybe. Not sure. I think you'd still have to cut down by the fire wall and outer part of the fender just a bit.
    unstpible and Reh5108[QUOTED] like this.
  3. Aug 8, 2021 at 8:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What tire is 35x10.5? Asking for a friend. :anonymous:
    turbodb likes this.
  4. Aug 8, 2021 at 8:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    there are quite a few options now...but you'd need 17s :luvya:
  5. Aug 8, 2021 at 8:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :pout:
    edit: That's Ok. I hate the idea of tubing.
    unstpible and Speedytech7 like this.
  6. Aug 8, 2021 at 8:58 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'd rather cut up the fender and whatever else than tub. I honestly need to just hack all the sheet metal from the firewall forward off and build my own frame. Finding cracks everywhere.
    I was looking at the Kenda Klever in a 35x10.5r17 I'll probably just stick with a 33x10.5r17. Mickey Thompson has a 255/85/17 that's peaked my interest also but it's on backorder.
  7. Aug 8, 2021 at 9:42 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yes that’s my setup, the BL doesn’t do much in the front really, if anything it helps more in the rear for tire clearance.
    I think with a narrow 35 with the right backspacing, the Solo arms might be enough to prevent you having to tub. You wouldn’t have much adjustability though, and yeah you’d have trim the front of the fenders and bumper, etc.
    Honestly I don’t know what the big deal with tubbing is, mine went very smoothly and has been 100% watertight. Probably stronger than the original firewall.
  8. Aug 8, 2021 at 10:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cutting the hole is easy. Welding the thin steel..not always fun. Haha
    jubei likes this.
  9. Aug 8, 2021 at 10:20 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    A good opportunity to learn how to weld sheet metal. But yeah, not something most people practice on a regular basis.
    Speedytech7 likes this.
  10. Aug 8, 2021 at 10:30 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    I was cut off over the weekend and slammed on my brakes. Now the brakes feel spongy and the parking brake light is always on. Front brakes are less than a year old. Brakes felt fine prior to that. The he brake light being on just mean my rear brakes are bad and need to be changed?
  11. Aug 8, 2021 at 10:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Parking/E-brake light can come on for two reasons typically. It is a low brake fluid indicator and also an indicator when the e-brake cable is engaged.
    chowwwww[QUOTED] likes this.
  12. Aug 8, 2021 at 10:41 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    I’ll check the fluid tomorrow. Didn’t know that the light came on for that. Maybe that might be why the brakes feel spongy.
  13. Aug 8, 2021 at 11:24 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Speaking of....
    These things are beef
    chrslefty, unstpible, jubei and 9 others like this.
  14. Aug 9, 2021 at 7:05 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Holy shit, the video and the detail you are going into with this is awesome!
    :drool::drool::drool:
  15. Aug 9, 2021 at 7:57 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Back to society. The escape was short-lived, but needed.
  16. Aug 9, 2021 at 10:07 AM
    betterbuckleup
    Ian
    Concord, CA
    @cynicalrider @Blackdawg @Reh5108 @Digiratus
    One thing that nobody mentions about the solo arms that you should be aware of is that they limit your steering angle.
    With moving the LBJ forward, you're also moving the OTR mount point forward as well which limits the range of motion the tie rod can move since it has to reach further forward to turn the spindle.
    Not the worst thing, but I can see it getting kind of annoying in some situations on the trail.
    Also could be seen as a positive for keeping you away from full mechanical bind on the CV's. Not to mention possibly a smaller hole in the firewall if you're tubing for 35's.
  17. Aug 9, 2021 at 10:09 AM
    MatosTaco
    MatosTaco Well-Known Member
    96 Toyota Tacoma
    Coilovers, sway bars, wheels, tires, extended studs, intake, head and taillights, seats, short shifter,
    Thanks! I'm trying to get better documentation of this process as there seems to be little information on how to do it.
  18. Aug 9, 2021 at 10:11 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Just added one of these myself. I lost one cup holder to the installation of my ham radio.
  19. Aug 9, 2021 at 10:12 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    out of curiosity, where did you find a poly carrier bearing.
    unstpible likes this.
  20. Aug 9, 2021 at 10:17 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Put up on four jack stands, motor running, and put it in gear, then with 4wd. have someone on the outside listen for the squeak. just remember to brake after having the drivetrain rolling. I thought I had noise in passenger front, turned out to be in rear.
