  1. Aug 11, 2021 at 11:36 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    We should probably all use OEM, I mean if we knew what was good for us.
    I mean, it's the way it was designed by the Toyota Engineers :amen:
    Dan8906 likes this.
  2. Aug 11, 2021 at 11:45 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    While different axle setup I think would be best being that some of us are finding cracks around the spring perches.
    Sniff it.
    Put the wheel on and find something to place next to the rim. Give the tire a spin. Should be pretty obvious to see if the gap varies. All 4 of my old steel wheels had runout. Not sure what is considered acceptable though.
    I chew through those quickly also. Been thinking about making some delrin bushing but that lead to the question of what fails next.
  3. Aug 11, 2021 at 11:48 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Whiteline makes rack bushings. Not that they are any better or worse than Energy or OEM... but it's another option.
    https://whitelineperformance.com/products/w12978-bushing-kit
    I was planning on replacing my LCA bushings this winter anyway. Will probably order the rack bushings along with the LCA bushings, and see what's up.
  4. Aug 11, 2021 at 11:52 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I can’t speak on how they hold up as they’ve been on for a grand total of 200 miles lol. But they are noticeably more stiff than the energy bushings I had on
  5. Aug 11, 2021 at 11:53 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I've got the Whiteline steering rack bushings on my truck now. I didn't notice much difference from the rubber bushings I took out, for better or worse. I replaced mine as part of a 200k mile front end refresh, not because of any specific problem. I've only got maybe 2000 mostly highway-miles on them, so can't comment on longevity.
    I haven't used the Energy Suspension or Total Chaos bushings, and can't compare to those. I remember reading elsewhere on the forum that the TC are better (stiffer, more durable) than the ES, though.
  6. Aug 11, 2021 at 11:54 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Mine seem to be doing fine
    For all 2000 miles they’ve been on :)
  7. Aug 11, 2021 at 12:08 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    The little 5 lug that could lol
    89F04EA1-F1CD-47AB-8896-799BD5AFC306.jpg FC1EF9DD-D237-4989-9B85-142406EF7FAF.jpg
    After unloading
  8. Aug 11, 2021 at 12:11 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've been running the Whiteline LCA bushings for a few years now. They've been good. Planning on replacing them more for preventative maint, as I have my alignment all crossed up to move the wheel as far forward as I can, for tire clearance.
    I'd say I have over 60,000 miles on the Whiteline LCA set I'm currently running... so, I'll give the rack bushings a shot.
  9. Aug 11, 2021 at 12:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I forgot did you do your own rear axle bearings at one point? Or pay a shop? A slow leak like that makes me suspect(if it's actually diff fluid) that the retainer ring is not seated in the right spot on the seal. I'd be curious about that as well over all.
    That said, as Ryan and Brett pointed out. It is VERY easy to spot a bent axle by just driving around and looking in the side mirror. The rear wheel will shake a lot. Franks is bent pretty bad now and does this.
    Total Chaos's bushings are by FAR the best I've found. Everything else is too soft. The ES bushings were a joke when I bought them. I just reused my TC ones instead they were so soft and floppy. Would go that route for sure.
    Dan8906[QUOTED] likes this.
  10. Aug 11, 2021 at 12:59 PM
    6P4
    Colorado Springs
    To clarify (because I'm not sure which way you read it) I was talking about the steering rack bushings, but I also installed the Whiteline LCA bushings at the same time. I've edited my original post to be more specific.
    My thought process was the same as yours... people seem to like the Whiteline LCA bushings, so I figured the steering rack bushings deserved a chance.
  11. Aug 11, 2021 at 1:03 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Right on :thumbsup:
    Ya, I thought you were talking about the LCA bushings. But definitely keep us up to date on your thoughts on the rack bushings as you get more miles on them. I'll probably order them in October, because I don't plan on doing them until Nov, Dec, Jan (somewhere in there). Would love to get more feed back before I order them.
  12. Aug 11, 2021 at 3:51 PM
    CruisD64
    CruisD64 Well-Known Member
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Line-X, LED Gauges, Bluetooth Stereo, TracRac, OME 2.5 Lift, Relentless Fab rear bumper, Shrockworks front. Bleh. So much good stuff.
    Did these a while ago but installed Ethan's stainless skid plate and a tailgate backup camera. Love both! :)
  13. Aug 11, 2021 at 3:58 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    how are you liking that roof rack?
  14. Aug 11, 2021 at 4:02 PM
    Trigo
    Rodrigo
    San Diego
    1st gen
    Radio before airbags ? Seems legit
    I’ve had this double din sitting on a shelf for like 3 years waiting to put it into something and now it found its use lol
    DAA838AF-FED8-42BA-8B68-D41FB8B3D97C.jpg 6E059EC9-8F2A-4170-83C4-47EC5FFFA677.jpg
    unstpible and SwampYota like this.
  15. Aug 11, 2021 at 4:03 PM
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    In all honesty I regret putting it on. I mean it looks cool but isn't nearly as functional as it is on 2nd and 3rd Gens since it's basically sheet metal holding it up. It barely holds any weight and can dent your roof quite easily. For little things like maxtrax it's fine but you definitely can't stand on it.
    unstpible likes this.
  16. Aug 11, 2021 at 4:05 PM
    Toyoda213
    Jimmy
    SoCal
    good to know
  17. Aug 11, 2021 at 4:21 PM
    Jbend
    Jbend Well-Known Member
    Where does one get one of those skids? Had to saw mine off the other day...:annoyed:
  18. Aug 11, 2021 at 4:23 PM
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Jbend[QUOTED] likes this.
  19. Aug 11, 2021 at 4:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the larger diameter of the wheel will show smaller variances more of course. So I'd do that first.
  20. Aug 11, 2021 at 4:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha well if its bad it'll wobble pretty good.
    Also did you see my last post asking about the retainer rings?
