  1. Aug 13, 2021 at 3:25 PM
    eon_blue
    Azusa, CA
    How do your CV boots/angles look at ride height after you installed the lift? In the first photo it looks like its sitting pretty high, might just be the stock size tires though.
    If the CV boot fins are touching at ride height, they will rub apart in no time. Been there done that, got a bunch of torn CVs in my storage to prove it
    Dan8906 likes this.
  2. Aug 13, 2021 at 3:30 PM
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    Yes it’s bc if the stock 15” wheels/tires. I plan on installing 17”.
    At full droop the spring was rubbing the spindle/upper ball joint.
    My CV boots are already torn so I’ll have to replace them.
    Which CV boots did you go with to stop them from tearing?
  3. Aug 13, 2021 at 3:30 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    My first set up was 3” Eibach coils on the lowest setting of the 5100’s. I tried the middle setting. It was way too much. You want the spring to create all the lift anyways.
    Depending on what size coils you have. The 5100’s might need to be dropped down.
    Good luck
  4. Aug 13, 2021 at 3:34 PM
    eon_blue
    Azusa, CA
    I just recommend OEM boots, no matter which boots you go with they will tear if they rub. If they aren't rubbing then they shouldn't tear, at least not until age/mileage does them in or something jumps up and bites them on the road.
  5. Aug 13, 2021 at 4:38 PM
    schellshocker99
    schellshocker99 Well-Known Member
    Toronto, Ontario, Canada
    2002 Toyota Tacoma Pre-Runner
    Taillights, headlights, Line-X box liner, fender flares, tonneau cover
    thanks! Bigger tires with 2” spacers
    K-DubTaco[QUOTED] likes this.
  6. Aug 13, 2021 at 4:50 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    How-to: Rebooting a Tacoma CV Axle
  7. Aug 13, 2021 at 7:42 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    100% as I use Krown on my truck and I have the same thing if you don’t wipe off the oil spray. Mine was built up on the lower door sill below the interior door panels.It is much better than rust! :canada:
  8. Aug 13, 2021 at 7:46 PM
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    turbodb[QUOTED] likes this.
  9. Aug 13, 2021 at 8:10 PM
    MitchHamwich
    MitchHamwich Well-Known Member
    Mitch
    SLC, Utah
    2004 double cab SR5 TRD sport 4x4
    Got my CB installed today fit perfectly in the ashtray spot, just need to get an antenna! Any recommendations on which type and where to mount it?
  10. Aug 13, 2021 at 9:11 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    unstpible and nagorb like this.
  11. Aug 14, 2021 at 5:11 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    More progress, taking my time since my AC bearing won’t get here until Monday
  12. Aug 14, 2021 at 9:12 AM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    I'll be watching the AC bearing job with a lot of interest. I think mine is going south as well, but haven't even had the time to assess it properly. :anonymous:
    DashMaple and BYJOSHCOOK[QUOTED] like this.
  13. Aug 14, 2021 at 12:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Finally changed out my dome lights for LED. Should’ve done it years ago.
    E3C68AB3-4F9C-458C-9E30-13793A10AA41.jpg D4240E1E-EFA2-4D62-9923-A1CDFBF447FB.jpg 9E41A606-AD6B-4F85-BB83-1EF4D6CEE493.jpg
    chrslefty, unstpible, nagorb and 3 others like this.
  14. Aug 14, 2021 at 12:40 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    u didnt need to solder resistors??? why i havent done mine, p sure my brother has a soldering iron but meh
  15. Aug 14, 2021 at 12:46 PM
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
  16. Aug 14, 2021 at 1:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The SuperBrightLED lights look like the have internal logic built into them. There’s capacitors and diodes built into them from what I saw.
  17. Aug 14, 2021 at 2:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Replaced my sheared leaf spring center bolt. It was not doing great..
  18. Aug 14, 2021 at 2:59 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    For those of you with the Cadillac alternator did you have the belt flush with the front of the pulley or the back of the pulley? Getting conflicting info via Google and I can't remember what I did first
  19. Aug 14, 2021 at 3:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    pretty sure I did the front. Let me see if I have photos
    BYJOSHCOOK[QUOTED] likes this.
  20. Aug 14, 2021 at 3:05 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'm assuming same pulley that came on it? Just read a thread where somebody changed the pulley but then I saw Mike post up using the same pulley so I think I'm good with the front
    Digiratus likes this.
