  1. Aug 16, 2021 at 4:54 PM
    eon_blue
    Azusa, CA
    I keep forgetting I need to do this. Which is funny because mine haven't worked in the 5 years I've had the truck. I've just gotten used to it I guess. Would be nice to not have to hold the door open on everything but flat ground.
    unstpible likes this.
  2. Aug 16, 2021 at 5:45 PM
    schellshocker99
    schellshocker99 Well-Known Member
    Toronto, Ontario, Canada
    2002 Toyota Tacoma Pre-Runner
    Taillights, headlights, Line-X box liner, fender flares, tonneau cover
    Painted my original bumper. Had to remove the rubber rocker guard first. I originally sprayed over the rust.
    BEFORE PHOTO’s
    Sanded down version before the paint
    AFTER PHOTO’s (tried my best to remove the dent as well with a rubber mallet)
    F0F469B3-4A06-4C05-8666-BAE078D91EDA.jpg 80236D14-2031-4E9E-A2DC-4F34F1918EC6.jpg
  3. Aug 16, 2021 at 6:04 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Exactly!! I designed it so if I ever wanted to make it a dual swing out I can. The arm is about 2ft I think.
    I decided to make my own swing rather than use there because I didn't like the idea of using 2 heim joints as a hinge.
  4. Aug 16, 2021 at 6:06 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    chrslefty and unstpible like this.
  5. Aug 16, 2021 at 6:14 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Did some proof of concept spacers on @Box Rocket old roof rack to get it level with my shell rack. I’m now about a 1/4” high on the front rack but not a big deal since it was an 1” lower before hand. I’ll get some steel or aluminum spacers next weekend and get everything finalized.
    Also got my RCI engine and trans skid finally mounted after cutting the front lip off the engine one. Needed to get a few replacement 40mm skid plate bolts since I was missing some in my rci hardware bag. Nice to have some actual protection underneath.
    And the best part of the afternoon was noticing my carrier bearing was completely trashed. I saw a tear in the rubber when putting the trans skid and pushed on the drive shaft thinking it would show some play and to my surprise the entire rubber pice is completely separated from the housing. It’s just bouncing around in there. That’s what I get for letting it slip down the maintenance list.
  6. Aug 16, 2021 at 6:16 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    noticed a leaking from my front half moons today... just recently replaced my valve cover gaskets, thought i did a well enough job sealing those up
    i guess not
    :bananadead::bananadead::bananadead:
    im assuming theres not a good way to fix that besides pulling the valve covers again
  7. Aug 16, 2021 at 6:17 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Easy fix!!
    Captain Magma[QUOTED] likes this.
  8. Aug 16, 2021 at 6:20 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I know I know, I just don't want to. It’s to hot haha
  9. Aug 16, 2021 at 6:23 PM
    eon_blue
    Azusa, CA
    If it helps, I think I knocked out the carrier bearing in a little over an hour taking my sweet time. Keep the driveshaft attached and it's a quick job.
  10. Aug 16, 2021 at 6:50 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Translation of these Petroglyphs we found.
    El Taco Diablo was here :rolleyes:
    That's what rock rings are for, right? :notsure:
  11. Aug 16, 2021 at 7:45 PM
    schellshocker99
    Changed my old “yellow OEM interior” light for “New bright White LED” dome light
    BEFORE
    AFTER
  12. Aug 16, 2021 at 7:50 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wut
  13. Aug 16, 2021 at 8:02 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    My wheel rubbed the rock and made art.
    :rofl:
    Fernando likes this.
  14. Aug 16, 2021 at 8:03 PM
    JKO1998
    Utah
    Oooh
    I thought you made it with the rocks under it.
    I was gonna tell you to save yourself, delete it now.
  15. Aug 16, 2021 at 8:17 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    You left a Child in your truck!
  16. Aug 16, 2021 at 8:22 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    The saga of Toyota frame rust continues! Saw a flatbed tractor trailer with three bare frames pulling in at the local dealership today!
    unstpible and Jase like this.
  17. Aug 16, 2021 at 8:54 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Wife took the picture of the Petroglyphs... left them on hardbrake hill (first segment) in one of the 2 places I smacked my passenger rear wheel lol
    https://youtu.be/fPNCHWWXqmc
  18. Aug 16, 2021 at 9:01 PM
    eon_blue
    Azusa, CA
    Had to be 2nd gen frames then yea? 1st gen frame replacement program ended in 2019 for 2004s. Was a 15 year window to be eligible if the other requirements were met
  19. Aug 16, 2021 at 9:06 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Stocking up for the wave of 3rd gens
  20. Aug 16, 2021 at 9:08 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I'm guessing 2nd gen.
    3rd gens aren't worth saving...
