  1. Aug 17, 2021 at 2:18 PM
    ALi3___
    ALi3___ New Member
    '96 2.7 White/Copper Nugget
    Finally fixed the relentless squeaking of my clutch pedal. After greasing everything that could possibly move it had done exactly 0 to fix the problem. I noticed the linkage to the clutch could shift a little bit where it attached to the pedal and it turns out it only squeaked when pushed to one side. Threw a greased 5/16's washer between the linkage and the left side of the pedal and it appears to have fixed the problem, finally!
    DarkWoods04, turbodb and ontarioyota like this.
  2. Aug 17, 2021 at 6:01 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Dropped the rig off at the shop today for rear u joint, center support bearing, slip yoke grease. Come to pick it up later and they ended up doing all 3 joints… not what I was expecting especially when I saw the total price was over DOUBLE what it was suppose to be. But apparently all 3 joints were toast anyways so that’s why they did what they did. Overall I’m ok with it I guess since its satisfying to know it’s all done but I still would’ve liked a warning call about it cus what if I didn’t have the funds for it? Luckily I did but usually I don’t for this price. Oh well, she does ride smooth again now and the slip yoke clunk you get when you come to a stop is GONE. Smooth stops!! So that’s a huge relief since I’ve been dealing with that for 6 years. I think I’ll drain the tran oil next. Here’s a pic from few weeks ago at Fiesta Island in San Diego.
  3. Aug 17, 2021 at 7:19 PM
    crakumskull
    crakumskull Well-Known Member
    tony
    Oregon
    2000 tacoma stock as $#!+
    Modified my clutch spring if that counts
    Finally replaced .y entire clutch hydraulic system. Minus the metal lines. Have been having a problem with rubber sediment that will eventually blow out the master cylinder and or the slave cylinder. So i pulled everything and went back to OEM aisin parts. This better fix it, else i may just kill it with ! ! In tired of fuck8n with this clutch
    unstpible likes this.
  4. Aug 17, 2021 at 8:42 PM
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    New Monroe Coilovers came today (I know, I’m a dumbass. But it’s all I can afford right meow)
    Hopefully they’ll last at least a couple years till I can get the 4600’s. No lift and stock wheels + tires so I think they’ll hold up ok.
    I’m wondering if I can cleanup my original coils to use when I get the 4600’s since they’re still in decent shape.
  5. Aug 17, 2021 at 8:44 PM
    Jbend
    Jbend Well-Known Member
    How have the moog LCA held up?
  6. Aug 17, 2021 at 9:16 PM
    snaxr
    snaxr Well-Known Member
    Just bought a set of OEM lower ball joints, and Moog LCA's. Gonna be a fun weekend. Not.
    turbodb likes this.
  7. Aug 17, 2021 at 9:29 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Bought a DoggoRamp from Desert Armor. We'll see how it works out.
    Bailey went up and down, no problem on the test run.
  8. Aug 17, 2021 at 9:59 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I'm semi interested in this concept. Not quite sure how these guys (125-135lbs each) would do with a blanket on a ladder...
  9. Aug 17, 2021 at 10:42 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Anyone running a Skidrow transfer case skid? I think it should work with my RCI skids, but wanted to confirm a measurement before ordering
  10. Aug 17, 2021 at 11:01 PM
    eon_blue
    Azusa, CA
    I run the Skidrow tc skid. It should work, it's only about a foot and a half (?) wide and doesn't go far enough forward to interfere with the IFS skid. I used to run a Budbilt IFS in front of it, which is a big skid. Worked fine
    Edit - if you're running a transmission skid too though it might interfere
    Captain Magma[QUOTED] likes this.
  11. Aug 17, 2021 at 11:35 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I'm running the rci engine and trans skid, what makes me think the skidrow one will work is that it share the same mounting points to the trans crossmember as the rci one. Based off all the photos I can find they should line up almost perfect. Next time you're under there would you mind measuring center to center of the crossmember mounting holes?
  12. Aug 18, 2021 at 7:49 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Them are some big puppers! Not sure how it would work for them, but the canvas used is pretty thick, surprisingly strong, and is supported by the ladder (which makes a frame work underneath).
    Not sure which user it is, but I have seen someone on Insta that uses the DoggoRamp for a Saint Bernard though.
  13. Aug 18, 2021 at 7:55 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I run 4xInnovations IFS and Trans skid with the SkidRow Tcase skid. The only modification I had to make was to the SkidRow skid. I drilled the holes for the transfer case crossmembers out (slightly) so the bolts for the 4xInnovations skid would fit through.
  14. Aug 18, 2021 at 8:17 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Have fun. Before you get too far into everything, you should see what kind of condition your LCA misalignment cam sleeves and bolts are in. I (like a lot of folks) wasn't able to get mine out without cutting. Of course, that means you then need to replace them all, since you can't uncut them.
    The parts you'll need are these, and it seems like it's good to have a set of four on hand just in case:
    Also, for cutting, this blade (exactly this one, there are several carbide variants that aren't as beefy) that @Speedytech7 recommended was awesome. One blade, all four cams for me.
    Lastly, if you want a step-by-step on the process, I took photos of everything as I did mine. Also lists the tools needed, and whatnot. Obviously you'll skip the bushing replacement part and just do "install" right after "removal," since you have new LCAs.
    Step-by-Step Lower Control Arm Bushing Replacement on a 1st Gen Tacoma
  15. Aug 18, 2021 at 8:34 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I put 75w90 in my t-case, same as what I used to put in my diffs before I regeared. My difs now get 85w140.
    I have the redline in my tranny too, but it's not much different than normal gear oil.
  16. Aug 18, 2021 at 8:46 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Same as @betterbuckleup 75w90 goes in my Tcase
  17. Aug 18, 2021 at 8:46 AM
    betterbuckleup
    Ian
    Concord, CA
    Yea I had the same experience. Not much difference from when I had 75w90 in there last.
    tntacomaguy[QUOTED] likes this.
  18. Aug 18, 2021 at 9:27 AM
    Bubba’sTaco
    Spencer
    Ogden Utah
    Toyota XJ
    You probably already know but the gear oils STANK so don’t wear your favorite shirt.
  19. Aug 18, 2021 at 10:01 AM
    Gen1FTMFW
    For some it's like Fluid Film, I actually don't mind the smell...
  20. Aug 18, 2021 at 10:05 AM
    eon_blue
    Azusa, CA
    I don't mind the smell of brand new gear oil at all, doesn't smell bad to me.
    Used gear oil that hasn't been changed in 2 decades/250k miles, that's another story
    Pyrifera, unstpible and Bubba’sTaco like this.
