  1. Aug 22, 2021 at 11:54 AM
    MatosTaco
    MatosTaco Well-Known Member
    96 Toyota Tacoma
    Coilovers, sway bars, wheels, tires, extended studs, intake, head and taillights, seats, short shifter,
    Oops, I may have opened the high pressure valve at some point in my frustration lol. In any case, the low pressure side should be reading 21.76-36.26 psi while the high side reads 198.7-227.7 psi.
  2. Aug 22, 2021 at 12:00 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Truck on the trailer coming home
    [​IMG] [​IMG]
  3. Aug 22, 2021 at 12:01 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Frame toast?
  4. Aug 22, 2021 at 12:12 PM
    Empty_Lord
    Dan
    Yea. Not as bad as the other.. I can at least take this one to the DMV.
    Tour991[QUOTED] likes this.
  5. Aug 22, 2021 at 12:12 PM
    Empty_Lord
    Dan
    The supercharger sounds great!
    YotainOregon and vonellis like this.
  6. Aug 22, 2021 at 2:58 PM
    YotainOregon
    YotainOregon Well-Known Member
    Oregon
    1st gen Tacoma TrD
    If that’s the case then you be blowing cold air and compressor would be running. To properly diagnose you would need to have correct pressures and check of superheat and subcooling.
  7. Aug 22, 2021 at 2:58 PM
    snaxr
    snaxr Well-Known Member
    Update: Was able to get an alignment today. Camber is still an issue, although definitely better than it was before replacing the LCA/bushings. Even though I had no problem taking out the cam bolts, apparently my cam sleeve/washers need to be replaced as they arent holding enough. The washer is spinning a bit on the sleeve where its supposed to be factory pressed together I guess? I did notice that while reassembling. Either way, driver's side adjustment is maxed out and its still like 2.3something positive camber. So still gotta hold out on new tires even though these are getting worn on the insides pretty bad. Set of 4 of everything cam bolt related I think I found for $140 plus shipping.
    On the bright side, the shop will honor the alignment for a few months and said they would replace the bolts/sleeves/washers for me no charge if I bring them the parts. That would save me a ton of trouble... I'm not sure they know what they are in for haha
    I kinda like how much softer the ride is with the sway bar delete. Havent hit the real winding backroads yet though.
    And the squeal/squeak went away on the drive over there.
    unstpible likes this.
  8. Aug 22, 2021 at 2:59 PM
    YotainOregon
    Oregon
    1st gen Tacoma TrD
    What size pulley does it have? I’m jealous
  9. Aug 22, 2021 at 3:01 PM
    YotainOregon
    Oregon
    1st gen Tacoma TrD
  10. Aug 22, 2021 at 3:06 PM
    Empty_Lord
    Dan
    It’s just as it was when the blower was installed in 1998-9
    So stock
  11. Aug 22, 2021 at 3:08 PM
    YotainOregon
    Oregon
    1st gen Tacoma TrD
    You want to sell the SC’er?
  12. Aug 22, 2021 at 3:10 PM
    Empty_Lord
    Dan
    She’s staying on the ol girl. Going to lightly restore this one. Enjoy it as is.
    Actually going to try and locate TRD headers and cat back for it. If I’m lucky
  13. Aug 22, 2021 at 3:11 PM
    YotainOregon
    Oregon
    1st gen Tacoma TrD
    She should be fun to romp on.
  14. Aug 22, 2021 at 3:16 PM
    Empty_Lord
    Dan
    Once it’s fixed up it’ll be a good one
    next step on this is getting the frame in Cali to here
  15. Aug 22, 2021 at 3:20 PM
    Empty_Lord
    Dan
    That’s what the other supercharger is for. (If I ever get my shit back from the machine shop)
    m3bassman[QUOTED] and unstpible like this.
  16. Aug 22, 2021 at 3:20 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
  17. Aug 22, 2021 at 3:48 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    That frame is probably better than mine
  18. Aug 22, 2021 at 3:55 PM
    Empty_Lord
    Dan
    Extended cab? Extent of rust?
  19. Aug 22, 2021 at 4:00 PM
    unstpible
    Derek
    Cedar City, Utah
    I attempted to get these ANZO taillights wired up correctly. Tested the drivers side and everything was functioning properly so I soldered both sides and plugged them in however when the passenger side was installed everything started acting funny so I have the stock passenger side and the ANZO on the drivers side for now.
    It looks terrible but it's functional and that will have to do for the time being.
    For now I need to track down the source of my CEL codes.
    P0441
    P0442
    P0446
    SwampYota and BYJOSHCOOK like this.
  20. Aug 22, 2021 at 4:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    All are emissions, evap system related. Verify your gas cap is seated correctly.
    That taillight looks good.
