  1. Aug 22, 2021 at 4:18 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  2. Aug 22, 2021 at 4:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When did the codes start? And did they all come at once?
    unstpible[QUOTED] likes this.
  3. Aug 22, 2021 at 4:30 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’d still check it then
    Digiratus likes this.
  4. Aug 22, 2021 at 4:52 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Dam, I do good just keeping up with 1. must be nice to have multiple trucks to play with, but that could get quite expensive in the long run.
    unstpible likes this.
  5. Aug 22, 2021 at 4:58 PM
    unstpible
    Derek
    Cedar City, Utah
    P0442 first showed up in March of this year and then came back in early June with a PO446 code. After that I replaced the fuel filter and gas cap (autozone gas cap) (O'Reillys fuel filter) and cleaned the codes.
    In mid June I did the valve cover seals, spark plugs, wires, PCV valve, and both plenum gaskets all with OE parts from a local dealer.
  6. Aug 22, 2021 at 5:00 PM
    unstpible
    Derek
    Cedar City, Utah
    I even tried putting a paper filter back under the hood instead of the K&N for a few weeks but had no changes
    P0441 has only showed up the one time I believe and that was yesterday.
    I've driven the truck about 2,000 miles since the CEL fist showed up
  7. Aug 22, 2021 at 5:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Replacing all that other stuff (valve cover seals, spark plugs, wires, PCV valve, plenum gaskets, paper filter, etc, etc.) is all good, but has nothing to do with your emission control systems.
    I've seen several threads about these codes because the problem is complex. Sounds like you've got some reading to do.
    m3bassman and unstpible[QUOTED] like this.
  8. Aug 22, 2021 at 5:21 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Dlbc surface rust only great shape.
  9. Aug 22, 2021 at 5:21 PM
    unstpible
    Derek
    Cedar City, Utah
    @Digiratus And read I shall. I did the seals and stuff for other reasons but figured it might be helpful to have a little more background info. I appreciate the feedback
  10. Aug 22, 2021 at 5:25 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Damn. I gotta move mounts then.
  11. Aug 22, 2021 at 5:26 PM
    Empty_Lord
    Dan
    I’m just dumb. I’m funding these with money from cars I buy and sell
  12. Aug 22, 2021 at 5:29 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    so what your really trying to say, is your an entrepreneur, and good at it.
    unstpible and Empty_Lord[QUOTED] like this.
  13. Aug 22, 2021 at 5:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    turbodb likes this.
  14. Aug 22, 2021 at 5:42 PM
    Empty_Lord
    Dan
    Being a mechanic I run across good cars that die that people are just done throwing money at it. I buy them cheap, fix em and sell em
  15. Aug 22, 2021 at 5:46 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I looked for one with one of the brass filters. I really have no data to prove that they’re any better than any other design. But in my unprofessional opinion they work better.
  16. Aug 22, 2021 at 5:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have any more info on what you are using?
    It looks like the one I linked is using some sort of steel mesh media as its filter. :notsure:
  17. Aug 22, 2021 at 6:01 PM
    JKO1998
    Utah
    The 02 turned 260k today
  18. Aug 22, 2021 at 6:01 PM
    Shortman5
    Supercharged TRD
    This (2 port) is what I’m using. The steel wool acts in a similar way that the baffles and brass breather works in mine.
    It’s just give the oil a lot of surface area to stick to so it won’t just mist right in through to the intake.
    https://www.amazon.com/Sporacingrts-Universal-3-Port-Reservoir-Outlet/dp/B08FDD1RPJ?th=1
    robblacktpre03 likes this.
  19. Aug 22, 2021 at 6:04 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    got the bed off. ready to start boxing frame in.
    jubei, unstpible, SwampYota and 5 others like this.
  20. Aug 22, 2021 at 6:04 PM
    JKO1998
    Utah
    chrslefty likes this.
