  1. Aug 23, 2021 at 10:22 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Replaced my AC clutch and then installed a Champion radiator. After adding the SC, I had switched to the 2.4L radiator which is only 18”-ish tall but VERY skinny (I have a V6 w/auto trans). I didn’t want to have the super tall OEM radiator that hangs below the frame. I was getting operating temps around 195-205 even with a 170 degree T-stat I stalled. I thought the cheap-o 18” radiator would be fine, but the temps were too high for my liking. Hopefully the Champion radiator will perform a lot better than the 18” one. Btw… I think the core on the 18” one is around 5/8” thick and the Champion is about 3” thick.
  2. Aug 23, 2021 at 10:36 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Yeah, $600 for a very nice but overpriced piece of metal vs $60 and some gumption. What do you need it to do? Does it need to look pretty? Get some heavy paper, borrow your dad’s jigsaw and take a few trips to the hardware store and if it’s crap you’re out your time and some minor dough and you learned what you’d do different next time. My two cents not worth a dime
  3. Aug 23, 2021 at 10:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Spotted...
  4. Aug 23, 2021 at 11:55 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Thank you!
    Jiveydude[QUOTED] likes this.
  5. Aug 24, 2021 at 5:35 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I just replaced all four of mine about a month ago. Wow, no more scratched arm hanging out the drivers side window. Plus it looks sooooo much nicer.
    Bubba’sTaco[QUOTED] likes this.
  6. Aug 24, 2021 at 7:43 AM
    BeLance89
    Brandon
    Huntsville, AL
    Well, the results are in. Champion radiator is performing as good as I’d hoped.
    BEFORE: Temps with factory sized 2.4L radiator
    AFTER: Temps with Champion radiator
    On the interstate, both the Trans and Engine temps were reading consistently at 180. Very happy with the upgrade so far.
    Dan8906 and SwampYota like this.
  7. Aug 24, 2021 at 8:20 AM
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    Much mo betta! :D
    It’s kinda deceiving how easy they are to replace. Not sure I ever would’ve changed them if I didn’t stumble on this site.
  8. Aug 24, 2021 at 8:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hope it lasts man. Mine didn't make it past 20ish k. Good luck!
  9. Aug 24, 2021 at 8:44 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I agree, it was so easy even a caveman could do it.
  10. Aug 24, 2021 at 8:46 AM
    BeLance89
    Brandon
    Huntsville, AL
    I'm hoping it will last as well; i've seen they are hit and miss as far as the quality goes. If it craps out, I might give the Koyorad a shot even though it's taller than the Champion. Cooling is definitely more important than hanging below the frame rails, but man... i'd really like to be above the frame rails if possible.
  11. Aug 24, 2021 at 8:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    shit QC. The thread on here that had a lot of people try it I don't think anyone still has it haha. Some lasted 50-60k Others 5k. They would replace them but then the replacements would fail.
    So..not worth it overall I'd say. Mine blew a seam and left me on the side of the highway.
    m3bassman and High Noon like this.
  12. Aug 24, 2021 at 8:54 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Is there a fuel system cleaner that’s actually worth a damn? Sea foam?
    my injectors(I think) seem loud asf, at 260k they probably need replaced or sent off and cleaned or whatever, but that’s gonna have to wait till next summer.
  13. Aug 24, 2021 at 9:00 AM
    Bubba’sTaco
    Spencer
    Ogden Utah
    Toyota XJ
    I saw that radiator thread and quickly ran the other way. Does champion have a legit R&D department or are they just modifying a different truck’s radiator to fit ours?
  14. Aug 24, 2021 at 9:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No clue. Don't care honestly haha was shit, probably never try it again from them.
  15. Aug 24, 2021 at 9:08 AM
    JKO1998
    Utah
    I read dumping a big bottle of zippo lighter fluid is basically the same thing
  16. Aug 24, 2021 at 9:09 AM
    Bubba’sTaco
    Spencer
    Ogden Utah
    Toyota XJ
    so you’re telling me there’s a chance?:rofl:
    Yetimetchkangmi likes this.
  17. Aug 24, 2021 at 9:14 AM
    JKO1998
    Utah
    You said you were coming to the Basin on Tuesday? We can try it then
  18. Aug 24, 2021 at 9:53 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Speaking of gas tanks, I'm gonna have my bed off at some point before getting my topper next month to do some prep and was thinking it would be a good idea to do some preventative maintenance and maybe replace the fuel pump and/or seals on the gas tank.
    Outside of the fuel pump bracket gasket, anything else I should consider?
    For fuel pumps I was thinking this one: https://www.amazon.com/dp/B012HRFKTE/?coliid=I1S07MK0XZD0NR&colid=3ESYMS3TDFE82&ref_=lv_ov_lig_dp_it
    I'm not boosted or anything, but I figure it would be good to just get a higher performance one so if I ever do wanna do boost down the line I won't have to mess with it again.
    @Digiratus don't you have the same one?
    I'm staying away from Walbro since I've heard they're kind of loud and some people have problems with them.
  19. Aug 24, 2021 at 10:21 AM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
  20. Aug 24, 2021 at 10:22 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yessir! That's the one I am running. 22K so far without any issues. Though not totally silent, you can barely hear it on a hot day out on the trail, it is way quieter than my buddies walbro in the same situation. But to be fair, he's had no trouble with his.
    m3bassman likes this.
