  1. Sep 4, 2021 at 6:24 PM
    Gcass3030
    Gcass3030 Member
    Cassidy
    NOCO
    1st Gen extended cab Taco
    Toytech adjustable coilovers w/Bitstream 5100s in the front, 3" blocks w/ an add-a-leaf in the back, Warn manual locking hubs. Trailgear Rock Defense front bumper.
    Front diff oil change, Transfer Case oil change, transmission oil change. Plus replaced a few cracked old hoses. I didn't pull the rear diff out as suggested but tomorrow I will be pulling the drive shaft off to do the center support bearing and the u-joints. I suppose I will pull the rear diff out then.
    unstpible likes this.
  2. Sep 4, 2021 at 6:36 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    What coils did you guys use? We put the OME soft ones in the back of my son's. It rides really nice but there not gonna hold any weight.
  3. Sep 4, 2021 at 6:47 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    It's not difficult, but a pain in the ass. You've got to pull the axles to pull the diff. And.... might as well replace the seals and possibly bearings if they are original. At least that's usually my though process, which always leads me down a path of craziness
    unstpible and chrslefty like this.
  4. Sep 4, 2021 at 6:49 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    OME 861
    They ride good. But he has no weight back there. So his truck is going to have quite a rake till we do his rear bumper, and add some weight back there.
    They are specifically for lift + added weight.
    unstpible and chrslefty[QUOTED] like this.
  5. Sep 4, 2021 at 6:50 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Don't forget the gears and locker since you have it out and open anyways. Because let be honest who wants to pull it a second time. Oh it's also way easier to change the motor mounts with the diff out.
  6. Sep 4, 2021 at 7:25 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Also, finally got my son's T4R legal.
    Replaced the Cat with a Walker Evens cat. Legal for CA install on his truck. Has a CA Executive Order number for most 3rd Gen 4 Runners and some 1st Gen Tacomas.
    Around 400 bucks from Summit.
    Made quite a difference in the numbers.
    Before
    After
    unstpible, chrslefty and ontarioyota like this.
  7. Sep 4, 2021 at 7:26 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Totally.
    And sounds like a good time to do a refresh on the drums. Well shit time to do u joints as well.
    Edit
    I'm pissed I didn't do the mounts when I pulled the front, but I went down that rabbit hole of since I'm in there and spent way too much time at the time doing other things. I think the truck was out of commission for over a month.
  8. Sep 4, 2021 at 7:44 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I have a 96 in my 01 and all i needed to swap over was the neutral safety switch
    malburg114[QUOTED] likes this.
  9. Sep 4, 2021 at 7:57 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What does everyone use for tailgate handle locks? The only one I could find is the Pop & Lock and it doesn’t have very good reviews.
    I’m finally installing my old SnugTop Tonneau on the truck. Had to do some fiberglass work, and tomorrow I’m doing base coat + clear coat. I’m too cheap to buy another quart of Metallic Black, so it’s getting painted Mercedes-Benz Tiefscwartz which I had leftover from my E320.
    Also, commercial clothing racks are really good Tonneau cover dollies lol
  10. Sep 4, 2021 at 8:03 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    When you close and lock the cover it will make it inposable (within reason) to open the tail gate.
  11. Sep 4, 2021 at 8:05 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s good to know - just wanted to make sure I don’t get anything stolen haha. What did you use for locks on the tonneau?
  12. Sep 4, 2021 at 8:13 PM
    Tour991
    James
    South Reno/Tahoe
  13. Sep 4, 2021 at 9:15 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I feel your pain and suffer from a similar affliction. I did my motor mounts. Lol
    unstpible and nagorb[QUOTED] like this.
  14. Sep 4, 2021 at 9:42 PM
    Gcass3030
    Gcass3030 Member
    Cassidy
    NOCO
    All of this is why I doubt I do anything with the diff until next spring. Yes the 1/4" of gear tooth stuck to my plug is a bit worrisome. But it's not a daily driver. I am going to take it on a handful of hunting trips starting next weekend so I will hope for the best on those.
    Next spring I think I am going to do an Eaton Trutrack and a Yukon ring and pinion. Right now time and money are not on my side for any of that so I will take care of what I can now and upgrade in the future.
  15. Sep 4, 2021 at 9:50 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    could just get a cap like your twin truck
  16. Sep 4, 2021 at 9:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I had a cap for a while, also made by SnugTop. Wasn't a huge fan of the lack of visibility, so I gave it away.
    Plus where I live the windows would be broken in (5) minutes if I left anything in the bed.
    unstpible and Tour991 like this.
  17. Sep 4, 2021 at 10:06 PM
    Empty_Lord
    Dan
    live in a state where people think twice before breaking into a vehicle because they may be shot if they do
    nagorb and BeLance89 like this.
  18. Sep 5, 2021 at 11:18 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Any tips on bench bleeding a master cylinder? Are the little plug kits required?
    Burro, unstpible and chrslefty like this.
  19. Sep 5, 2021 at 11:24 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    What came in the package? There's typically a bleeder set with the MC.
  20. Sep 5, 2021 at 11:26 AM
    JKO1998
    Utah
    I don’t know yet, it’s still 6 hours away.
    I hope that’s the case, shitll be easy
