  1. Sep 10, 2021 at 12:05 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You need a vacuum bag
    jubei likes this.
  2. Sep 10, 2021 at 1:44 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    That looks nice.
    Definitely building my own. Hoping to not add any more weight than a factory bed but I'm not sure if thats feasible with steel.
  3. Sep 10, 2021 at 6:18 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What’s a sign of air in the master cylinder?
    I was bleeding brakes and got all the way to the front passenger and nothing was coming out of the bleeder or the brake line.
  4. Sep 10, 2021 at 6:29 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    could be a bad rubber line.
    unstpible likes this.
  5. Sep 10, 2021 at 6:29 PM
    JKO1998
    Utah
    All stainless
  6. Sep 10, 2021 at 6:29 PM
    Empty_Lord
    Dan
    ABS?
  7. Sep 10, 2021 at 6:30 PM
    JKO1998
    Utah
    Abno
  8. Sep 10, 2021 at 6:32 PM
    Empty_Lord
    Dan
    what have you done to the truck that youre now bleeding the brakes? new lines?
  9. Sep 10, 2021 at 6:33 PM
    JKO1998
    Utah
    Welllllll
    New calipers, new master, new booster.
    Only the passenger side doesn’t have fluid coming out, no kinks in the hard line.
  10. Sep 10, 2021 at 6:38 PM
    Empty_Lord
    Dan
    front one im guessing? i'd fill the res up and leave the bleeder open for 5-10 minutes and see if it starts dribbling out.
  11. Sep 10, 2021 at 6:41 PM
    JKO1998
    Utah
    Alrighty
  12. Sep 10, 2021 at 6:53 PM
    JKO1998
    Utah
    How hard should the brake pedal be to push down when the trucks off?
  13. Sep 10, 2021 at 7:00 PM
    JKO1998
    Utah
    Said Ef it
    big o can attempt it in the morning
  14. Sep 10, 2021 at 7:03 PM
    Empty_Lord
    Dan
    It should firm up and not sink to the floor
  15. Sep 10, 2021 at 7:04 PM
    JKO1998
    Utah
    Mine feels like it has something blocking it until you put enough pressure on it to go over whatever it is
  16. Sep 10, 2021 at 8:30 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    :rofl:
  17. Sep 10, 2021 at 10:52 PM
    96Tacoma4WD
    96Tacoma4WD Well-Known Member
    So Cal
    1996 Toyota Tacoma V6 2dr Extended Cab 4WD SB
    Alpine head unit and CD changer
    Just noticed one of my drivers leafs broke on my 96 4wd. It is the center leaf with the spring clip on it.
    I replaced the OEM springs in 2013 for a set of Triangle springs which came recommended as factory replacements from Deaver. Truck is a west coast truck no rust.
    Is this common on 1st gens? I’ve never heard of this issue.
    Anyone know of a quality factory replacement?
    unstpible and SiberianTacos like this.
  18. Sep 11, 2021 at 12:28 AM
    Empty_Lord
    Dan
    Not normal at all. I think people recommend general spring these days? I can’t speak for their quality. I put new OEM ones under my fathers truck.. but $$$
  19. Sep 11, 2021 at 6:40 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I have 2 95.5 model 4x4s, both of which had one broken spring when I got them. Both were broken right in the center, at the axle.
    On one, I bought new General Springs for both sides. Went with the OEM replacement variation, but wish I had gone up one step. I was adding a flatbed and thicker frame rails at the same time. The roughly extra 300lbs or so is a bit much for the OEM grade replacements from General.
    For the other truck, I bought 1 replacement from O'Reillys. It was about $180, which was same as General cost since there was no shipping. That spring ride height matches the OEM still on the right side. The original spring on the right side has 269,000 miles on it and still seems fine.
    I use these trucks mainly just for road duty, with only a little off road. Nothing more than mudholes, so take my experience in that context.
  20. Sep 11, 2021 at 12:52 PM
    Reh5108
    Idaho
    Any other suggestions other than a wheel bearing?
    Vibrations change or disappear when turning right and get worse when turning left. There is 0 play at the wheel. Temperatures are within a couple degrees of each other at the spindle.
    DashMaple likes this.
