  1. Oct 17, 2021 at 4:37 PM
    Soxs
    Soxs Member
    I've recently added a bullbar, Westin-Wade deflector. Just finished installing rally lights today...IMG_20211017_154251418~3.jpg IMG_20211017_154326948~3.jpg
  2. Oct 18, 2021 at 9:14 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  3. Oct 18, 2021 at 10:15 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Oh, that's smart. I have the same issue and I was just going to stick a nut on the other side and call it good until I inevitably forget the next time I need to remove it.
  4. Oct 18, 2021 at 11:26 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    How were you planning on getting a nut inside the frame though?
  5. Oct 18, 2021 at 11:59 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    That happen to be an m8 rivnut? I’m thinking about doing the same exact thing for my mount right near the passenger rear cam tab. Just need to figure just what size drill bit to drill it out with
  6. Oct 18, 2021 at 12:33 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's actually not a riv-nut at all. It's a M10 flange nut with the nut portion inside the frame, and then I welded the flange all the way around to the frame. I am not sure I would trust something that see's heavy impact on a riv nut. I have stripped the internals of a riv nut way too easily before just trying to install them. What I was actually surprised most about this project was that the bottom portion of the frame is actually much thicker than the sides. It seems to be almost 3/16" while the sides of the frame are closer to 1/8". It was a fairly large pain in the dick drilling the holes out upside down.
  7. Oct 18, 2021 at 12:45 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Couple of small "to-do's" on the slug.
    Got a new deckplate bc I lost the last for my air intake.
    New obd2 reader for long distance trip peace of mind and code reading if any errors arise.
    Finally changed my shattered shell window, thanks to @Phessor ! Re sealed the rear window, need to seal cab to shell still.
    Anddd. Found me a leaky leak, guess thats one more reason to open up the rear and weld it! :stirthepot::stirthepot::stirthepot:
    Johnny_Mac, unstpible, Paseo and 3 others like this.
  8. Oct 18, 2021 at 12:55 PM
    2Runner
    2Runner Well-Known Member
    Scott
    So Cal
    2002 Regular Cab 2.4L MT 2WD
    Had a bundle of fun melting tires off at the autocross this weekend, and took 2nd in the novice class out of 16 drivers!
    Old Trudy sure is fun and holding on strong, she needs some more tires soon though!
  9. Oct 18, 2021 at 1:16 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    All good info, very solid point about the impact vulnerability. I’ve never messed around with rivnuts before so maybe I’ll look back at drilling and re-tapping or poping a nut ontop since I can get in that spot luckily.
    Also, it shows how sharp I am today thinking “why did he grind down his rivnut head……..” Jesus I need a beer or coffee haha
  10. Oct 18, 2021 at 1:38 PM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    I got my winter tires on, and found some snow:thumbsup:
  11. Oct 18, 2021 at 2:35 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Hey I think you need some wider tires man. Those don't look to have enough of a contact patch for snow wheeling lol
  12. Oct 18, 2021 at 2:45 PM
    POSTacoMike
    Red Deer AB
    “Pizza cutters” :rofl:Man, at 10psi, I couldn’t feel rocks or anything!! Gonna be fun at 1psi!
    unstpible likes this.
  13. Oct 18, 2021 at 3:00 PM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Well, not the exact same issue; my stripped threads are on the cross frame.
  14. Oct 18, 2021 at 3:31 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I'm running M8 rivnuts there on my mid skid and they've been just fine. Those are only two of six anchor points on mine, however. YMMV of course.
  15. Oct 18, 2021 at 3:59 PM
    Jbend
    Jbend Well-Known Member
    Idk where you're running at, or how much or little driving experience you or the other drivers have but....you beating an s2k by nearly 3 seconds and 2 M2 competition's by 6 and 10 seconds.....veryyyyy interesting. I'd be so mad if I was those m2 people $60k+ for a car and they can't even drive:annoyed:
  16. Oct 18, 2021 at 5:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    little of that but id also guess it a little of not wanting to wreck a 60k car either. 6k taco? Fuckin send it! lol
    still impressive for sure.
    Jbend[QUOTED] likes this.
  17. Oct 18, 2021 at 5:53 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Who has made a wiper fluid reservoir out of ABS/PVC and relocated it? Had to remove my OEM finally today, and would like to see photos/positioning/construction.
    Thanks!
  18. Oct 18, 2021 at 6:36 PM
    Phessor
    Phessor Well-Known Member
    I made one out of ABS that worked great, but I will have to find a picture of it.
  19. Oct 18, 2021 at 6:38 PM
    Phessor
    The only one I have. The pump was on the bottom and the low level sensor was on the side.
    unstpible and nagorb like this.
  20. Oct 18, 2021 at 6:43 PM
    Jbend
    Agreed. But I do remember seeing him post about a road course. Don't buy a 60k car if you can't afford to wreck it. Buy a 6k taco and a 30k s2k, that's just me though.
