  1. Oct 21, 2021 at 4:29 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No just James
    Oops wrong thread
    unstpible, Fernando and BYJOSHCOOK like this.
  2. Oct 21, 2021 at 4:30 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Why not rebuild it before throwing oil in it? If bearing material was found its not going to magically fix itself.
    unstpible likes this.
  3. Oct 21, 2021 at 4:31 PM
    eon_blue
    Azusa, CA
    Head over to the 3.4l supercharger thread, lots of talk in there about rebuild services. Jon Bond, HighSpeedLab, SuperchargersOnline...those are the three I know of. There was another one mentioned in that thread not long ago I hadn't heard of but people were saying good things.
    How did the whine change? Is it rattling/knocking loudly at idle?
  4. Oct 21, 2021 at 5:13 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Lots of cutting in preparation for bumper...
  5. Oct 21, 2021 at 6:33 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Now that's a flashback, same wheels and everything. Looks good!
  6. Oct 21, 2021 at 6:43 PM
    boshak
    AG
    CA
    Oh wow. My twin! What bumper did you go with?
  7. Oct 21, 2021 at 8:09 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I built one out of 2x4x3/16" rectangular tubing, and 2x2x1/8" for the swingout.
  8. Oct 21, 2021 at 8:35 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Not the same color... but definately having flashbacks lol
    Been there done that a couple more times now.
  9. Oct 21, 2021 at 10:06 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Have you replaced the gas cap?
    unstpible and loudboy like this.
  10. Oct 22, 2021 at 5:21 AM
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    Spark plugs, fuel pump, fuel pressure regulator, faulty fuel injector or wiring to injector…
    Silver02Taco likes this.
  11. Oct 22, 2021 at 6:20 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ya'll really making me itch for a Coastal rear with side tubes. I have grown to hate the lines of my 4x bumper over the years.
    Compared to:
    [​IMG]IMG_3290 by Michael Halat, on Flickr
    The upwards angle has always driven me nuts. Increased departure angle would be a bonus.
  12. Oct 22, 2021 at 7:25 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I had it tuned when I was up in Washington on an AEM FIC, it’s getting more boost now. My peak used to be 4.5-5, and now it reaches 6-7 PSI on a 7.5 PSI pulley. There’s this strange whine at idle that changes with engine RPM (different from the SC whine). I noticed the nose cone was leaking, so it could be super low on oil.
  13. Oct 22, 2021 at 7:26 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah, that’s what I’m starting to realize. It’s got an unknown amount of miles on it. I want to run a 10 PSI pulley, but that definitely can’t be done till I rebuild it.
    I’m not sure where the bearing material originated from. It could be the engine or the supercharger. But I guess the SC is the place to start.
    Reh5108[QUOTED] likes this.
  14. Oct 22, 2021 at 10:45 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    You could definitely build one yourself, or even modify your existing bumper. I think rear bumpers are a good place to try out fabricating new ideas because they’re fairly straightforward.
    You had the SC oil tested, or the engine oil? If there is bearing material in your engine oil, that is almost certainly not from the SC bearings. It’s pretty common to get accelerated wear on the crank bearing journals with an SC.
    It’s a good idea to get it rebuilt before adding a smaller pulley.
  15. Oct 22, 2021 at 11:02 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Mines was definitely a fun project, lots of welding and grinding but over all I'm very happy with it. I went with the 4x tire swing out instead of the coastal one.
  16. Oct 22, 2021 at 11:05 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes, engine oil. Should I be worried about the accelerated bearing wear on the crank?
  17. Oct 22, 2021 at 11:42 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Well, there’s nothing you can do about it short of removing the SC, so I wouldn’t spend too much time worrying about it. I get a Blackstone report once a year or so just to track the trend, but I’ve never heard of bearing failure due to wear from the SC.
    Change your oil more frequently and send it.
  18. Oct 22, 2021 at 12:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Sounds like a plan. I do 3k service intervals on the engine oil. How often does the SC oil need to be changed?
  19. Oct 22, 2021 at 12:25 PM
    eon_blue
    Azusa, CA
    I try to do mine every 25k or thereabouts, once a year. I know some people do 40/50k intervals on it in the 3.4l supercharger thread.
  20. Oct 22, 2021 at 12:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    How has yours been treating you!
