  1. Oct 24, 2021 at 2:10 PM
    Soxs
    Soxs Member
    Oem switch for rally lights finally arrived
    unstpible and SwampYota like this.
  2. Oct 24, 2021 at 3:22 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Installed some Toytec 3 degree axle shims and Durobumps today. The shims eliminated 90% of my driveline vibrations, so it was thankfully worth the effort. Also gave the rear leaf springs and axle a coat of Fluid Film.
  3. Oct 24, 2021 at 3:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Then..eh. idk. Will help. A new radiator is better than old. Every off the shelf aluminum one ive seen so far has died in 20-60k
  4. Oct 24, 2021 at 10:16 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    How often do you need to fill it? I’m currently running a 2.7 L model tank. But I’ve wanted to see if I can move it and fit my twin arb compressor there rather than in my bed. 8E735B55-385B-4FDC-A03C-6D5098DE3D49.jpg
    unstpible likes this.
  5. Oct 25, 2021 at 8:19 AM
    Jbend
    Jbend Well-Known Member
    Are those factory painted fender flares?
  6. Oct 25, 2021 at 8:38 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Couple weeks ago, but I recently visited a little town of Greenville, California, which was consumed by the Dixie Fire about 2 weeks earlier. The fire was still active at the time, and there were crews extinguishing hot spots. Quite an eye-opening scene, and this 1st gen didn't make it.
  7. Oct 25, 2021 at 9:49 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Partout?
    Looks like a TRD with progressive coils.
  8. Oct 25, 2021 at 9:49 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They progressed all the way to static
  9. Oct 25, 2021 at 10:07 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Since it is smaller at 32 oz, I do make sure it's topped off. But I have never run out either. I am guessing that it is about half the capacity of the OEM bottle.
    Pretty sad sight...
  10. Oct 25, 2021 at 2:31 PM
    turbodb
    Dan
    PNW
    AdventureTaco
  11. Oct 25, 2021 at 2:39 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Oh damn. Hopefully Alcan warranties that
    turbodb[QUOTED] likes this.
  12. Oct 25, 2021 at 2:45 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Dang man! First a leaky axle tube and now this? The rain needs to stop for you!
  13. Oct 25, 2021 at 3:10 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    That sucks.
    What make and how many miles?
  14. Oct 25, 2021 at 3:18 PM
    betterbuckleup
    Ian
    Concord, CA
    They're custom alcan packs
  15. Oct 25, 2021 at 4:12 PM
    Dan8906
    Daniel
    Concord, California
    I put some new bushings and center pins into my alcan springs today. I new the pins were bent but geez is this a common issue? 01C35625-0065-481C-89EF-655B668410E3.jpg
  16. Oct 25, 2021 at 4:40 PM
    Phessor
    Phessor Well-Known Member
    Wow!
    I have NEVER had a bent center pin ion any vehicle I have owned.
    Dan8906[QUOTED] likes this.
  17. Oct 25, 2021 at 4:48 PM
    eon_blue
    Azusa, CA
    I've changed out my leaf springs/bushings & bolts a few times and have never seen that either.
  18. Oct 25, 2021 at 4:50 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  19. Oct 25, 2021 at 4:56 PM
    Dan8906
    Daniel
    Concord, California
  20. Oct 25, 2021 at 5:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My alcan bushings were pretty chewed up when I swapped them with summer.
    I think it happened to mine because I chose to ignore the torque spec and tightened till it didn’t tighten any more.
    Edit:
    I lied, they’re just a little wore out
