  1. Nov 2, 2021 at 1:49 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    For home shop stuff, nothing beats a portaband. Way more versatile, and cleaner.
  2. Nov 2, 2021 at 1:57 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I've been hearing this, I like the idea of a portband, portaband pro jig, and swag table. 3 hella useful tools.
  3. Nov 2, 2021 at 2:01 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Kwikvette likes this.
  4. Nov 2, 2021 at 2:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Nov 2, 2021 at 2:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  6. Nov 2, 2021 at 2:20 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @Pella (he's very rarely on here, and mostly sticks to the CA forums and some 3rd Gen stuff) has that band saw. I've used it a few times when the two of us are working on shit at his place. That thing is a definite game changer. Slow as hell, but I'm just hell of impatient.
    Band saws are accurate, but they sure aren't going to win any chain saw races lol.
  7. Nov 2, 2021 at 2:23 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Yup.
    Honestly for home use I would just go with a portaband and a table mount. Horizontal band saws are nice, but the cheaper ones are a pain to get square, and hardly ever stay true. .
    Speedytech7 likes this.
  8. Nov 2, 2021 at 5:35 PM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Today/yesterday I did upper/lower ball joints, tie rod ends, sway bar bushings, and CV axle rebuilds. Lots of fun with stuck fasteners including an adventure drilling out/re-threading the passenger side ABS bracket bolt hole and a bonus round chiseling off the differential drain plug.
    Tomorrow when my new drain plug arrives I'll fill up the diff and hope to see no leaks :fingerscrossed:
    Jiveydude likes this.
  9. Nov 2, 2021 at 5:51 PM
    5280
    5280 old school
    Colorado front range
    99 Tacoma TRD
    Trail Gear Front bumper, Warn, Apex Octane rear bumper, SPC, OME 881, Dakars, Raven topper, PIAA fog lights, dog mod and a couple other things...
    Finally, sliders on :fistbump:
  10. Nov 2, 2021 at 6:14 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Has anyone had luck wrapping parts of their truck DIY? I’m thinking about wrapping my rear bumper black. I’m curious as to how hard it is.
  11. Nov 2, 2021 at 7:52 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    portaband pro jig should do the same thing as the swag table, no?
  12. Nov 2, 2021 at 7:57 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I did vinyl wrap on the portion of my hood that gives me glare when I'm running the light bar. The wrap it's self wasn't that difficult.
    The vinyl is coming back off the hood and I'm going to paint that matte black.
    Vinyl wrap on a hood that isn't insulated on the under side doesn't work, in case anyone is curious. The heat rises and heats up the hood and shrinks the wrap. It will eventually get all wavy around the edges and look like crap.
    This is what it looked like right after I did it.
    Logans2001[QUOTED] likes this.
  13. Nov 2, 2021 at 8:02 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Anyone deal with popping noise in front suspension? I feel like it just started when I switched to these quick disconnect sway bar links
  14. Nov 2, 2021 at 8:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    probably that then. The sway bar is known to make a chunking sound. Disconnect it and drive it for a day or two to see if it goes away.
    Wulf and Dalandser like this.
  15. Nov 2, 2021 at 10:42 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    That saw - or really, saws very much like it - is sold by several vendors. Grizzly sells one that I have. HF sells a saw that looks identical for a fraction of the price ( ). Works great both as horizontal and vertical. I cut all my material for bed racks with it.
    Floor space isn't too bad since it's easy to roll around, and at $300, the price is certainly right.
  16. Nov 3, 2021 at 8:28 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'm not familiar with the Grizzly. But the HF saw is not anywhere even close to the Jet. As I said earlier, I've used the Jet quite a few times when working on collaborations with @Pella, I've also used the Harbor Freight version. My neighbor across the street has one. My neighbor is a machinist and he has done some extensive modifications to his. Replacing the junk blade that comes with the HF version, first of all... but also reinforcing the legs, reinforcing the armature because it had a lot of lateral slop, etc.
    Even with all the modifications Chuck (my neighbor) has done, his band saw isn't even in the same neighborhood as Josh's (Pella). The tolerances on the adjustment cranks are tighter, the motor runs smoother, the base is more stable.
    Harbor Freight has really improved on some of their tools, but on this one, it's apparent that HF still makes a lot of their stuff by copying others. Just because it looks the same, looks can be deceiving. The gauge metal they use for the stand could be thinner (I believe it is) the threads on the adjusters aren't machined as well, the motor is probably less efficient... things that at first glace seem to look the same, aren't.
  17. Nov 3, 2021 at 10:41 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Goddamn that truck is so clean.
    Derp, didn't even realize that. Even better.
    All packed up for 4 days wheeling/camping in MA and VT.
    [​IMG]Untitled by Michael Halat, on Flickr
    I feel like reorganizing my bed to remove the tool box and make space for my dual sport really streamlined the way I am now able to pack shit up.
    5280[QUOTED], jubei and ToyRyd04 like this.
  18. Nov 3, 2021 at 11:07 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That HF saw is the unsung super versatile hero of my shop. It's been making accurate cuts for at least 15 years, straight and curves with next to no mess. The capacity is actually 5x7 @ 90 deg with the stock clamp and significantly more with "creative clamping". Also cuts non ferrous metals, wood and plastic. Did a compound miter on 2x6 rectangular tube for a rear bumper.
    There was quite a "cult" following for these things at one time with near endless modifications. There is no doubt, out of the box they are pretty "rough" but bang for the buck is way up there. Google 4x6 bandsaw.
    This fellow was out the door for <$190 back then and treated to a few of the popular mods that made a huge difference.
    Oversize tires, thicker rear axle, trussed axle housing. This made the leg assembly super rigid, way more than expectations
    Intercooler and gear box breather.
    Motor fan replaced by separately switched 120v unit. Motor doesn't even get warm, 100% duty cycle when cutting that 3/4" thick flat bar or railroad track for that matter.
    Creative clamping.
    Not seen is removal of the residual sand/slag chunks in the gear box from the sand casting and a deburring/polishing of the gears along with 140wt gear oil.
  19. Nov 3, 2021 at 11:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's great info, I have a newer Grizzly that I will plan to do the same modifications to as well
    malburg114 likes this.
  20. Nov 3, 2021 at 11:42 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Threw together a little bolt on mount for either a moto gas tank for trips that require more than 5 gallons of gas (have a Death Valley trip coming up that I need it) and also works with my newer 10 lb propane tank that I have been bringing camping to fuel my propane fire pit(super nice to have to use during fire bans). Both just get strapped in with a racket strap.
    unstpible, nagorb, Burro and 3 others like this.
