  1. Nov 5, 2021 at 8:31 AM
    eon_blue
    Azusa, CA
    At first glance I thought you cut a jagged piece out of your dash lol
  2. Nov 5, 2021 at 8:39 AM
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    Yup. Looks pretty ugly and I'm a little ashamed as I'm pretty anal about the stuff I put on my trucks. Anyhow, it's hidden pretty well until I find something better. Function over form for now!
    unstpible and eon_blue[QUOTED] like this.
  3. Nov 5, 2021 at 9:16 AM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Trying to remove and clean my idle air control valve, but my throttle body doesn't look like any that I can find example videos about.20211105_111403.jpg
    Where is it?
  4. Nov 5, 2021 at 10:11 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    You don’t have one on that TB
    unstpible likes this.
  5. Nov 5, 2021 at 10:12 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    While cleaning your TB, be sure to remove the top plate and clean the pass thru Holes in there too
    unstpible and Bluecord like this.
  6. Nov 5, 2021 at 10:20 AM
    Bluecord
    Jeff
    Louisiana
    Wonder why my engine doesn't have one? Did they stop putting them on the 5VZ-FE at some point and why? Simply not needed? Anyway, I'll remove the top plate and clean. I see a little gasket there that I don't have a replacement for so I'll have to take it easy.
  7. Nov 5, 2021 at 10:22 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Different design of TB starting sometime in 2003.
    I replaced the 4 jis screws with Allen head screws from HD, makes it’s easier when removing them
  8. Nov 5, 2021 at 10:58 AM
    Bluecord
    Jeff
    Louisiana
    Can I pull and replace this cracked tube with a silicone one?
  9. Nov 5, 2021 at 11:00 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Absolutely!
    unstpible and Bluecord[QUOTED] like this.
  10. Nov 5, 2021 at 11:34 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    03-04 got an electronic controlled TB(fly by wire) vs a mechanical one. There is still a cable on them for "back up" but its electronic otherwise. Also why you don't have or need a CC module on the passenger side of the engine bay.
    Bluecord[QUOTED] likes this.
  11. Nov 5, 2021 at 1:57 PM
    Bluecord
    Jeff
    Louisiana
    The plastic cover on my wires cracked all to hell so it's Tesa tape and maybe a wire loom for me.
    Made a little progress on the passenger's side valve cover as well.
    SwampYota and unstpible like this.
  12. Nov 5, 2021 at 2:08 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    I have a magnetic quick release on my keychain since I don't like to have a bunch of weight on the ignition. Once disconnected, the magnet attached to the Toyota key can stick to the metal of the ignition and you're rattle free.
  13. Nov 5, 2021 at 2:12 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I'm the same way. Single key for ignition, especially when wheeling. Prevents the constant "jingle" of keys. Also, that weight (although seemingly small) can easily wear out the ignition as it's bouncing around.
    Badknees likes this.
  14. Nov 5, 2021 at 2:31 PM
    Badknees
    Kenny
    Anderson, SC
    Good idea and I’ll check into that. Like the bottle opener too! :thumbsup:
  15. Nov 5, 2021 at 2:45 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I feel like that's a good way to loose your other keys imo
  16. Nov 5, 2021 at 3:00 PM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    unstpible and Badknees[QUOTED] like this.
  17. Nov 5, 2021 at 3:02 PM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Other keys stay in my pocket or go in the cup holder and the strong magnet links them back up whenever they're anywhere near each other. YMMV
  18. Nov 5, 2021 at 3:06 PM
    Badknees
    Kenny
    Anderson, SC
    My other keys would stay on my carabiner attached to my belt. My only concern would be the magnet strength and knocking the Taco key off accidentally as I’m not too stable some days…
  19. Nov 5, 2021 at 3:49 PM
    Badknees
    Kenny
    Anderson, SC
  20. Nov 5, 2021 at 4:08 PM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    The magnet from the guy I linked to is really strong; I highly doubt you'll knock it off accidentally. The quick disconnect is also really handy when handing your key to a shop or valet.
    :thumbsup:
    Badknees[QUOTED] and unstpible like this.
