  1. Nov 22, 2021 at 6:56 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    To each their own. FF and the like usually come with wand kits, helps to get inside the frame (where most rust starts). Undercoating, especially the rubberized stuff, shouldn't be coated multiple times over. I would recommend doing the prep and undercoating or paint once, then FF moving forward.
    Just my preference. FF can be a mess and isn't for everyone though. Really just depends on how bad rust is in your area.
  2. Nov 22, 2021 at 7:13 PM
    Phessor
    Phessor Well-Known Member
    It's not hard to end up there anymore...
  3. Nov 22, 2021 at 7:26 PM
    NC2CATaco
    NC2CATaco Member
    R2
    2000Taco4x4.2.7cyl
    Full paint, Ceramic, LED head and tail lights, interior dynamat, interior under lighting, subwoofer, tweeters, headunit,console, billstein and OME leaf springs
    Latest. Finally completed my 2000 Tacoma renewal. 265/70/17. 2021 4Runner wheels.
    total lift from OEM 4.5”. No modification needed. 2.7 4cyl manual 4x4. Since primarily road driven to many downsides to larger tire for my use. Thanks to all for the input.
  4. Nov 22, 2021 at 9:48 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    It looks like the coating in the pic is similar to FF.
    Gen1FTMFW[QUOTED] likes this.
  5. Nov 22, 2021 at 10:06 PM
    Gen1FTMFW
    You're right. I didn't see the overspray before.
  6. Nov 23, 2021 at 6:17 AM
    coldaccord
    coldaccord Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    I don’t want to diy my undercoating, a few years back my business partner did it on our lift and he had some time cleaning up the mess
    RustKote is a petroleum based product. Get it coated in fall, wash it off in spring.
  7. Nov 23, 2021 at 7:02 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  8. Nov 23, 2021 at 7:35 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    From what I've read if the noise goes away in 4th gear then it's the input bearing.
  9. Nov 23, 2021 at 7:40 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    My guess is the TOB... so while you're in there, replace the pilot bushing and rear main seal.
    I don't have a manual trans in my Tacoma but have had old muscle cars that did. Check for side to side, up/ down movement on the input shaft.
    Good luck.
  10. Nov 23, 2021 at 9:09 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Either way needs replaced haha
    Does it go away when you slightly push the clutch in? Or slightly let it out?
  11. Nov 23, 2021 at 10:12 AM
    BigSam1991
    BigSam1991 Well-Known Member
    Sam
    Threw some crispies on her... Still riding like a dream at 180k
  12. Nov 23, 2021 at 10:24 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Got my hoist mounted to pull the tent on/off. Still need to tweak the cable lengths on the front end but it’s still super handy
    E7FAA08B-585C-4057-BA8A-1653E3916FF7.jpg 4CDEE1FD-2635-40B8-8AEB-595B0B6AC9F8.jpg
  13. Nov 23, 2021 at 11:49 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Any one running a KOYORAD radiator? I like that the inlet and outlets are almost .4” bigger than the Denso replacement.
    betterbuckleup likes this.
  14. Nov 23, 2021 at 3:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Pulled the Kings off today..... Daayuum. They need a rebuild bad. Lower bearings are shot and they were super gunky. Excited to go to 650s and a fresh rebuild.
    Kinda glad the 4runner has OME. They ride great. But then again, she stays on the black turf
    Phessor likes this.
  15. Nov 23, 2021 at 3:52 PM
    Gen1FTMFW
    Thats one of those shelf systems right? I did the same thing in my last garage. Just be careful when you take the tent off. The cables want to untension with no weight and get all out of place. The cables eventually fall off the pully's if there's no weight to keep them in place on the ends of the arms and are a pain to get back on right. Mostly a problem when you take the tent off and want the rack to sit up by the ceiling.
    I wonder if it's the same one. Not sure if your handle is the same, but i found that mine would fit in a drill. Made it super easy to lift and lower. Here is mine, looks pretty similar...
    unstpible likes this.
  16. Nov 23, 2021 at 3:53 PM
    Phessor
    I need to pull mine off and get them rebuilt, kinda scared of what they are going to look like.
  17. Nov 23, 2021 at 3:56 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I drive like a maniac offroad. Lol
  18. Nov 23, 2021 at 3:57 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  19. Nov 23, 2021 at 4:00 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Replaced the steering rack, rebooted both CVs, changed the oil, and got an alignment. Should be good to go for death valley trip tomorrow.
  20. Nov 23, 2021 at 4:03 PM
    Phessor
    Me too, I'm surprised how well my old truck has held up.
    Fernando[QUOTED] likes this.
