  1. Dec 24, 2021 at 9:31 AM
    5amStevens
    5amStevens Well-Known Member
    Gilbert, Arizona
    2000 Tacoma 4x4 Prerunner TRD
    https://www.pirate4x4.com/threads/t...0-r151-r452-dyna-5th-gear-swap.2000978/page-3
    chrslefty and unstpible like this.
  2. Dec 24, 2021 at 9:42 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Dec 24, 2021 at 10:18 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Right on. It looks great. Keep us up dated on how it's doing over time.
    unstpible likes this.
  4. Dec 24, 2021 at 11:06 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    ireymon, 45acp, Taco critter and 2 others like this.
  5. Dec 24, 2021 at 12:16 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    You got any pictures?
    I put my All Pro bumper on hold until after the holidays but I'm itching to get started with the installation. I believe you said a few days back you had some issues with the fitment at first so if there's any lessons you learned the hard way that could save me a little bit of hassle I would be grateful.
    There's evidence of a front end collision under my hood and I know that might create some hassle for me
    I know I'm going to have to do some extra work to get the Low Range tank skid installed because 2 of the 4 stock skid bolts are snapped off inside the weld nut. Hopefully I can get those out without a problem but I do have a welder. Was it @El Taco Diablo I recently saw fab up some alternative mounting points for the tank skid?
  6. Dec 24, 2021 at 12:17 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Wasn't me.
    I put on a Low Range gas tank skid a few months ago. But mine bolted up with no issues.
    unstpible[QUOTED] likes this.
  7. Dec 24, 2021 at 12:56 PM
    unstpible
    Derek
    Cedar City, Utah
    Well at least I got it half right haha
  8. Dec 24, 2021 at 2:42 PM
    AbbyNormal
    AbbyNormal Active Member
    99 4x4 extended taco
    tundra brakes, more to come..
    Ok, Did a tundra brake upgrade on my 99 taco. I used these calipers https://www.amazon.com/dp/B01EDCBKE0?ref=ppx_yo2_dt_b_product_details.. FYI for those whom would like to do this conversion, you will have to grind on a bit on these so they wont rub the back of your rims. (found out the hard way) was wondering why the wouldn't turn when I mounted them.. All good now, just be aware.
    Front end alignment next week. Then time to pull the motor.. Runs great, but seems to leak from every seal. Has anyone here used this kit? https://www.ebay.com/itm/282013417185 . just wondering the quality..
    45acp, unstpible and turbodb like this.
  9. Dec 24, 2021 at 3:19 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’m thinking that was @slander
  10. Dec 24, 2021 at 3:45 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    What wheels are you running that you needed to grind the calipers? For future reference, here's a list of wheels that fit the 13WL calipers. None with grinding, though some require spacers: https://adventuretaco.com/which-wheels-fit-the-tundra-brake-upgrade-on-a-tacoma/
    As for the timing belt kit - that seems pretty low cost to me. The aircabinman kit on eBay is known to be high quality Toyota (and Toyota OEM supplier) parts, but obviously costs more. Still, when you're talking about a job like that, which you don't want to redo on a regular basis; spend a bit more for quality parts.
    And, for doing that job, here's a step-by-step guide. Note that you'll need a few other parts and supplies, and there are some specialty tools that can make the job a whole lot easier. They pay for themselves easily in a single timing belt/water pump job, and even more if you help a friend out with their truck after doing your own!
    Step by Step Toyota Tacoma Timing Belt Replacement for 3.4L V6 5VZFE
  11. Dec 24, 2021 at 4:14 PM
    AbbyNormal
    I used these, the American racing before I found that article. Bought from tire rack mounted and balanced. The amount of the caliper I had to grind was really not that much, only about 1/16th of an inch.
    Thanks for the feedback on the timing parts, I'm turn on trying to keep this motor going or just go ahead and do a diesel swap. Still keeping my options open as in 4k for a rebuilt 3.4 or a 1kz-te turbo diesel for $3700.00.
    Toyota 1KZ-TE Turbo Diesel 3.0L
    turbodb[QUOTED] and unstpible like this.
  12. Dec 24, 2021 at 4:17 PM
    Which Way Out
    Which Way Out Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    New tires last week
  13. Dec 24, 2021 at 4:45 PM
    WTORRES141
    WTORRES141 Active Member
    2004 Tacoma std cab
    Had a bad bulb on the cluster, so I did the four there, the three on the temperature controls, LEDs ...fixed a bad ashtray and shifter bulb too....did not see a glovebox light. PXL_20211224_160752290.jpg
    unstpible, Paseo and SwampYota like this.
  14. Dec 24, 2021 at 4:49 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Keep us posted. The high rpms are kill my mpg . I guess it's time to slow down. Problem is trying to keep up with the 2nd and 3 gens.
    Thanks !! Definitely gonna give that a read .
  15. Dec 24, 2021 at 7:36 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    I don’t have any pics of the original mount up. As for fitment issues. The 2 front facing bolts, that go into the box end of the frame were my issue. They just did not line up, so I had to take the die grinder to them probably only about 1/8” reemed out. Not too bad.
    My issue tackled this week was, the 4 (2 on each side of the radiator) bolts on the underside of the frame. One side I had issues removing the oem bolts originally on the one side. Like they were over torqued in or cross threaded. When I originally put the bumper on I could only get 1 to go in. I left it for then, then later when I went to remove the plate to drain my coolant it just stripped and stuck… I tried the other one with a Helicoil, but that did nothing more than piss me off for wasting my money/time lol. I did snap one pic of the section I cut out. It was a bitch to weld back in, but I feel pretty confident it’s on there good.
  16. Dec 24, 2021 at 10:07 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    It was me, search my build thread
    jubei and unstpible[QUOTED] like this.
  17. Dec 25, 2021 at 5:58 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Seasons Greetings, from the edge of the frontier.
  18. Dec 25, 2021 at 10:24 AM
    slander
    Hickory, NC
    To further expand a bit more, that skid is surprisingly strong, I had the entire weight of the truck on it wedged against a rock and I creased and bent the frame on the pax side. The skid held up good, but I did rip the 3 bolt mounts on the frame where the gas tank bolts to the horse collar. This area was previously damaged. I am going to replace the rear frame rails with new sections in the spring or fall next year and my plan is to raise the tank, and build some tabs to mount the skid directly to the horse collar and make a mount in the rear to bolt it right to the cross member. Basically the fuel tank straps will only support the fuel tank and the skid will have its own mounting system.
    unstpible[QUOTED] and jubei like this.
  19. Dec 25, 2021 at 4:27 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    20211223_164615.jpg 20211223_180352.jpg 20211225_131209.jpg 20211225_153306.jpg
    I love working with sheet metal
  20. Dec 25, 2021 at 6:21 PM
    nchiker1
    nchiker1 Well-Known Member
    Installed a wheelskin steering wheel cover I got for Christmas today! Lacing it up was more of an expert level project than I expected. Not sure I'd do it again, but sure am happy how it turned out.
