  1. Dec 27, 2021 at 10:00 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Once you plugged in the MAS did you clear codes with your reader?
    unstpible likes this.
  2. Dec 27, 2021 at 10:02 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Once I plugged it back in I don’t believe it was throwing any codes.. just idling a little high and rough. Now I have codes this morning. Drives perfectly fine.
  3. Dec 27, 2021 at 10:04 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I did also tighten the throttle cables because I think they had some slack. Is that ok?
  4. Dec 27, 2021 at 10:05 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    As long as they return all the way to closed throttle, better to be a little loose than too tight
  5. Dec 27, 2021 at 10:12 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Now we are getting a bit convoluted here and out of the context of my original comment. When installing an external cooler, it it wise to run Trans - to ext cooler - to radiator especially if you are in a colder climate.
    Bypassing that "cooler" or even worse cooling after the "cooler" in the radiator is not a good idea.
    Whether you want to believe it or not, the "cooler" in the bottom of the radiator helps your ATF come up to operating temperature faster in cold climates. Once you are driving that "cooler" may help SOME. But it is not a very good "cooler" by any stretch of the imagination... Which is exactly why external coolers for our Auto Trans, in these trucks, is so often a topic of conversation.
    The "cooler" does an exponentially better job helping the ATF get to operating temp, than it does cooling the ATF. Which was the point I was making.
  6. Dec 27, 2021 at 10:16 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @Speedytech7 beat me to it.
    He is correct. Better to be a bit slack, than too tight. If you tightened them too much, THAT is very possibly the reason you're idle is too high.
  7. Dec 27, 2021 at 10:27 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    The primary purpose of that heat exchanger is to be a cooler. It would help very little with fluid coming up to temp, because heat exchanger efficiency is a function of the difference in temperatures between the two sides of the exchanger. In 20 degree climates, fluid running through a 70 degree single pass exchanger is going to gain very little heat, and much less than the TC and gear movement create.
    However, it will do a pretty decent job of cooling 200F+ fluid when the bottom of the radiator is 90F
    The cooler does a much better job preventing overheating of the fluid than it does getting the fluid up to temp, which is the point I was making
    Wsidr1 likes this.
  8. Dec 27, 2021 at 10:47 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    LMFAO.... This is a 1st Gen Tacoma thread. EVERYONE who has done anything to these trucks knows how whoafully inadequate a job the "cooler" does at preventing overheating.
    So... the reason we talk about external trans coolers, so often, is... the "cooler" pretty much doesn't do it's job, of "cooling" at all.
    Therefore, if it doesn't do that job. It's not a very big stretch that it does the job of "warming" up to operating temp better. Because all it has to do is be halfway decent at that, to be better "warming" than it is at "cooling"
    But who am I? I mean it's not like just about every resource, talking about external coolers, doesn't suggest placing the external cooler BEFORE the radiator for precisely the reason I'm talking about. :notsure:
    You keep talking about the inefficiency of the heat exchanger, saying the warming properties of a 120-190 degree radiator warming up ATF (To operating temp... meaning when the truck was just turned on, and you are just beginning to drive it) from at or below freezing is inadequate to warm the ATF up.
    Somehow the 120-190 degree coolant absolutely can not warm up cold ATF... BUT... 120-190 degrees coolant does an impeccable job of cooling 190 degree ATF?
    Just so we are clear... When I say warming up the ATF. I mean initially, when you just begin to drive your truck. Once it has reached operating temperature, and the truck is driving (even in cold climate) I realize the transmission, it's self is going to keep it warm through friction and normal operation.
  9. Dec 27, 2021 at 10:54 AM
    OpeCity
    Long Beach, CA
    indeed, it’s not great. That doesn’t make it a heater as a primary function.
    it isn’t halfway decent at warming. Not even close
    the temperature of the bottom of the radiator is not the temperature of the coolant temperature sender. Go drive your truck, stop, and touch the bottom of the radiator. You’ll be surprised how cool it is. That’s why they put the cooler there.
    so yes, 70-90 degree coolant does a much better job of cooling down fluid 100F hotter than the other side of the heat exchanger than it does warming fluid 50 degrees colder than the heat exchanger. An exponentially (quite literally, since it scales with the square of the difference) better job
    but it doesn’t actually do that, and the thermodynamics of heat exchangers proves it.
    if it was designed in any way to be a heater, it wouldn’t be in the lowest, coldest spot of the radiator
    Reh5108 likes this.
  10. Dec 27, 2021 at 11:13 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The thermodynamics of heat exchangers is literally based on theory that when you run fluid of differing temperatures through chambers together, Those fluids will try to equalize temperature.
    So, the exact reason you are saying the coolant will cool the ATF when the ATF is hotter than the coolant, says the coolant will warm the ATF when the coolant is warmer than the ATF.
    The coolants don't know what the vessel they are in are named (Cooler/Warmer) the laws of physics says they will try to equalize temperature.
    I guess if you specifically want to argue with this I'll change my original statement (although the context of this discussion makes it abundantly clear what I meant by it) from.
    The trans "cooler" in the bottom of the radiator is there more so to heat up the trans fluid in cold conditions than to cool the fluid in hot conditions.
    To
    The trans "cooler" in the bottom of the radiator DOES A MUCH BETTER JOB heating up the trans fluid in cold conditions than to cool the fluid in hot conditions.
  11. Dec 27, 2021 at 11:24 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Who loves road salt?
    Added a few more miles to the truck last weekend and saw some great views along the way
    We took the southern route into AZ on our way out and the blue northern route home.
    Max coolant temp was °212
    Max trans temp was °213.
    highest point in the trip was just shy of 10,000ft
    Cheapest fuel we saw was $2.64/gal and I felt disappointed that we only needed half a tank when we got there.
    Tour991, Reh5108, jubei and 3 others like this.
  12. Dec 27, 2021 at 11:26 AM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
  13. Dec 27, 2021 at 11:27 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Absolutely love these tail lights
    unstpible[QUOTED] likes this.
  14. Dec 27, 2021 at 11:35 AM
    Speedytech7
    Not sure what you're talking about, I just see one poor fella having a conversation with himself.
    Anyway, I love road salt...
    Area51Runner, 45acp, drr and 2 others like this.
  15. Dec 27, 2021 at 11:37 AM
    unstpible
    Derek
    Cedar City, Utah
    I think I love them even more because I had such a hassle at first getting them wired correctly so it was extra rewarding when it finally came together. I even took them to a local car audio place and the owner tried to tell me the stock vehicle wiring was incorrect even though my stock lights were working as they should. :crazy:
    DashMaple[QUOTED] likes this.
  16. Dec 27, 2021 at 11:46 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    What? You don't want to join in on the discussion on the theories of Thermodynamics?
  17. Dec 27, 2021 at 11:47 AM
    OpeCity
    Long Beach, CA
    except this is incorrect. Run with no cooler for a fun experiment to prove it
  18. Dec 27, 2021 at 12:02 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lmao... I'm running a twin fan Hayden cooler looped to a location under the bed, adding over a quart and a half of ATF to the system.
    Because the "cooler" in the radiator, does a crap job.
    BUT... I have it running from the ACTUAL (Hayden) cooler, through the "cooler" in the radiator, and back to the transmission... for reasons we have already discussed.
    robblacktpre03 likes this.
  19. Dec 27, 2021 at 12:22 PM
    OpeCity
    Long Beach, CA
    My bet is that if you ran back to back with only the factory cooler and with no cooler at all, you’d realize that the factory cooler does a LOT, even if it’s not enough
  20. Dec 27, 2021 at 12:25 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Actually, correction. It's a Derale, not a Hayden
    With an added filter. Mostly for the purpose of adding more fluid to the system.
    45acp likes this.
