  1. Jan 14, 2022 at 7:27 AM
    chainslap
    chainslap Well-Known Member
    Prescott, AZ
    95.5 SR5 V6 5spd 4x4, 2020 Tundra TRD DC
    Finished welding up the True North bumper. Just need to blend the corners and drop it off for powder coat. Been a decade plus since I did any real fabrication or welding, it’s slowly coming back.
  2. Jan 14, 2022 at 8:17 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I finally got the Tacoma moving...
    With the power of the ever mighty HF engine hoist haha
    Needed some more room to set up a table and finish weld some brackets
  3. Jan 14, 2022 at 9:11 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well considering there isn't really anything that makes the front coilovers side specfic other than lining up the top bolts, I'd say they are a bunch of dumb asses and I wouldn't want them to touch a single vehicle I own or any one I know either.
  4. Jan 14, 2022 at 10:19 AM
    Pscdouglas
    Pscdouglas Wish you weren't so awkward Darry.
    Stu
    Glens Falls, NY
    2004 black Tacoma Xtracab 4WD TRD AT, 2020 Black Tacoma ACLB 4WD Sport MT
    Then my converter must be ready to die, I've replaced that PITA O2 sensor with OEM at least three times. Love those rusty nuts, in that heat shield.
    unstpible likes this.
  5. Jan 14, 2022 at 1:58 PM
    Soxs
    Soxs Member
    At the end of December, my air outlet servo began clicking and slipping. Ordered a new one and replaced it. I don't know WHY one just can't buy a replacement servo without having to buy the servo with metal bracket assembly.
    Anyhow....the air mix blend door servo just started grinding and clicking. So replaced that today. Contortionist repairs to be sure....
    unstpible, chrslefty and SwampYota like this.
  6. Jan 14, 2022 at 2:28 PM
    badboypro
    badboypro Well-Known Member
    Sunnie
    Pittsburgh, PA
    1997 Tacoma SX
    adapted the mount for my ashtray coin organizer to fit 1/4" bolts... testing out a few ram ball options...
    Akkording, ireymon, BrownMike and 6 others like this.
  7. Jan 14, 2022 at 2:53 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Took apart the j shift case today. A lot more shit going on inside than a gear drive. IMG_2946.HEIC.jpg IMG_2945.HEIC.jpg
    scofflaw and unstpible like this.
  8. Jan 14, 2022 at 4:11 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Same. But then I woke up in paradise.
    01x4, ireymon, jubei and 7 others like this.
  9. Jan 14, 2022 at 4:14 PM
    Speedytech7
    I should have done this weeks ago
    unstpible and Taco critter like this.
  10. Jan 14, 2022 at 4:30 PM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    Installed a 3 degree axle shim to hopefully remove driveshaft vibration after a recent suspension upgrade / lift. It's kind weird that the emergency brake cable now rests on the leaf spring, I don't remember it being like that pre-shim. I wonder if there's a fix.
    SwampYota and unstpible like this.
  11. Jan 14, 2022 at 5:03 PM
    eon_blue
    Azusa, CA
    OME sells a relocation bracket for that I believe. Common after their springs install for the trucks with that ebrake cable location
  12. Jan 14, 2022 at 5:04 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Dude! Don't strain so hard! Take it easy, sheesh. That's like 10 seconds of "work"...
  13. Jan 14, 2022 at 5:28 PM
    foothill96tacoma
    The ones I'm finding are for the brake proportioning valve, not the e-brake line / guide. Hmmm...
  14. Jan 14, 2022 at 5:37 PM
    m3bassman
    Green truck
    Amazon has a two pack of trickle chargers for $40, and they seem to be working so far.
  15. Jan 14, 2022 at 5:38 PM
    Speedytech7
    Pretty good deal actually. But I've got a couple, I just keep forgetting to actually hook em up haha
    unstpible and m3bassman[QUOTED] like this.
  16. Jan 14, 2022 at 5:38 PM
    Speedytech7
    I have a couple I made you can have if you want em
  17. Jan 14, 2022 at 5:42 PM
    m3bassman
    Green truck
    That's half the battle. Our mini seems fine but the others are dramatic when in gets cold. The AMG dig deep to fire last week. The Tacoma has its own drama.
  18. Jan 14, 2022 at 5:43 PM
    Speedytech7
    My BMW was the same way, leave it for a week and it's a slow cranker... Leave it for two weeks and you need another vehicle to jump it haha
  19. Jan 14, 2022 at 6:07 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Ive got a craftsman riding lawn mower I always have to jump if it sits more than two weeks. I think a solar panel would be perfect for a trickle charger that doesn't need an outlet
    nagorb likes this.
  20. Jan 14, 2022 at 6:11 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    So I know the oem aluminum skids are discontinued but does anyone know if the brackets for them are also or are those still available? Thanks gents.
