  1. Jan 21, 2022 at 8:42 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Do your speakers sound any better?
    unstpible likes this.
  2. Jan 21, 2022 at 8:45 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    The sound is great. The sub gave it the missing piece. Very happy!
    unstpible and chrslefty[QUOTED] like this.
  3. Jan 21, 2022 at 8:52 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Ah. Goes hand in hand with the old "I don't need safety glasses as long as I can blink fast enough" method.
    Safety squints = Safety shuffle
  4. Jan 22, 2022 at 5:08 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Those are great!!
    I have a new mantra when grinding. Safely squint .. safety shuffle... It's almost like bobbing and weaving.
    unstpible and Gen1FTMFW[QUOTED] like this.
  5. Jan 22, 2022 at 11:09 AM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    Finally got to drive the Taco today after this (plus a hellish fuel pump replacement project). All the vibration is gone! :)
  6. Jan 22, 2022 at 11:17 AM
    Kwe1982
    Kwe1982 Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    New idler pulley, this one appears broken.
  7. Jan 22, 2022 at 11:34 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
  8. Jan 22, 2022 at 11:48 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Expensive tires ordered. Now to see how long this national backorder lasts. And decide on wheels.
  9. Jan 22, 2022 at 12:01 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Mike’s name is Dan now too?! We’re taking over
    :thumbsup: Good choice on size, I’m digging the slightly narrower tire so far. Price has gone up since September quite a bit though
  10. Jan 22, 2022 at 12:33 PM
    Squeaky Penguin
    Brett
    Yeah, not cheap. Was considering the Toyo ATs in the same size/load range as they were quite a bit less, but figured going back to an MT for what I plan to do with the 1st gen was the right choice.
    Plus as the rate I drive the 1st gen they'll last until they're dry rotted. :oops:
  11. Jan 22, 2022 at 12:36 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Shoot my 285s were $1200, and the 285 nitto trail grapps were $1350
  12. Jan 22, 2022 at 12:37 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    You gonna tub it out for those or think they’ll fit with the solo arms?
    Or are they in preparation for a SAS? :stirthepot:
    unstpible and jubei like this.
  13. Jan 22, 2022 at 12:58 PM
    Squeaky Penguin
    Brett
    I bet they're not much bigger than the current 285/75r17s, so I'm guessing they'll fit without tubbing. Granted I've hammered the firewall as much as possible.
    That's also with the exception of under the battery and airbox. With the solo arms I started rubbing there hard. I'll cycle and cut what I need to for them to clear cleanly. Was planning on moving the battery to the bed anyways.
    SAS is not on the table at the moment, but might still get there.
  14. Jan 22, 2022 at 1:20 PM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    Finally got the lift done yesterday. Torqued down the UCAS, got to the shop for alignment and the ball joints on the ucas jarred loose. Shouldn’t have skipped on better quality. Absolute garbage machining work on the eBay ucas. Should’ve known. So decided to Order replacement JBAs which should be in in 4 days. Still can’t drive her yet:mad:.
    sure looks good though. At least I can go take a peek whenever I want until the jbas come in lol. Def the biggest project I’ve done on the truck myself.
  15. Jan 22, 2022 at 1:34 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah the nittos seem to run on the small side, mine weren’t much taller than my worn out 315/75r16 MTRs.
  16. Jan 22, 2022 at 3:13 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
  17. Jan 22, 2022 at 3:44 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’ve been wanting to do this for a while, since the 315s required more than a little hammering up front. The added benefit would be getting all that mass closer to the COM of the truck, if not maybe biased to the passenger side a bit to help with my taco lean. Would be cool for sure.
  18. Jan 22, 2022 at 4:05 PM
    Squeaky Penguin
    Brett
    I've already hammered there too, and closer to the battery than I would like, so I think it will need to be moved. Plus what's left of my inner fenders is falling apart, so less weight up there can't hurt.
    jubei[QUOTED] likes this.
  19. Jan 22, 2022 at 4:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nittos! Those are pricey for sure.
  20. Jan 22, 2022 at 4:46 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Both my batteries are in the bed now, although I’m starting to over-index on weight in the rear as my rear axle is carrying about 60% of the weight of the truck.
